The Hitachi D4R electronic distributors are used by the early E-series engines. These can these be modified to work in A-series engines. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior High-Energy Ignition Unit![]()
Compare to older Exterior Matchbox (Hitachi D4K) photo
Also see: E-Series Distributor
Hitachi D4R series Electronic Ignition distributors are used by E-series Datsun/Nissan, such as the E15 Pulsar. This can be modified for use in a Datsun 1200. It has a much-improved advance bearing plate, which was the bane of the 1974-1982 D4A points distributor, as well D4F and D4K EI distributors. This new D4R type uses a screw-on cap and improved rotor.
E-series shares basic distributor features with A/J/E/L distributor (shaft diameter & length) but uses an L-series style tang drive instead of A-series gear drive. The hold-downs vary, otherwise the cast body is the same.
One-piece Ignitor & Pickup
Hitachi D4R type dizzy e.g. from N12 Pulsar
* Hitachi E12-61 * Nissan 22020-15M00, 22020-15M20 * NOTE: Hitachi D4N module looks similar but has more than two connectors * BWD CBE507 $110 O'Reilly Auto * SMP LX515 ** Nissan 22020-15M00 ** Honda 30120-PA0661, 30120-PH4005 * 12336248 * 30120PA0661 * 30120PH4005 * 491467401 * 8942433440 * 94243344 * E1922
Stator has only two poles (compared to the previous "teethed" stator with 4 poles) but the magnet appears to be stronger.
22163-15W00 STATOR 22136-D4700 PLATE ASSY-BREAKER 22162-15M01 CAP ASSY-DISTRIBUTOR * 22162-15M02, 22162-15M03, 22162-15M04 22157-H9560 ROTOR-HEAD
Variations
D4R air gaps
D4R80
22162-15M01 CAP ASSY-DISTRIBUTOR N10 E15S USA, N12 E16S USA, B11 E15S+E16S 22157-H9560 ROTOR-HEAD 22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-21M00, 22136-D4700 PLATE ASSY-BREAKER 22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00 SHAFT ASSY [weight & spring shaft] 22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
D4R82
Appears to be very similar to D4R80.
0882-0588 B11 E15S+E16S USA, 0285-0986 N12 E16S USA
0882-0986 N12 USA DISTRIBUTOR ASSY * 22100-32M01,22100-32M01 HITACHI D4R82-24 * 22100-32M03,22100-32M04 HITACHI D4R82-24 W/VENT * 22100-33M01,22100-33M02 HITACHI D4R82-12 * 22100-33M03,22100-33M04 HITACHI D4R82-12 W/VENT * 22100-34M01,22100-34M02 HITACHI D4R82-13 * 22100-34M03,22100-34M04 HITACHI D4R82-13 W/VENT
22162-15M01 CAP ASSY-DISTRIBUTOR 22162-15M02 CAP ASSY-DISTRIBUTOR 22162-15M03 CAP ASSY-DISTRIBUTOR 22162-15M04 CAP ASSY-DISTRIBUTOR 22162-52A01 CAP ASSY-DISTRIBUTOR
22157-03A00 ROTOR-HEAD 22157-H9560 ROTOR-HEAD 22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-D4700 PLATE ASSY-BREAKER [22173] * 22159-11M00,22159-11M03,22159-11M05,22159-15M00 * HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00, 22108-11M03 SHAFT ASSY [weight & spring shaft] 22020-15M20 TRANSISTOR IGNITION UNIT
22132-33M00 CAM SET 22132-33M03 CAM SET 22132-34M00 CAM SET
D4R83
D4R83 is a great Hitachi distributor, used on 1980s Nissans and Hondas. The austin boys swap them into A-series engines too.
For Hitachi D4R Distributor
22162-15M01 CAP ASSY-DISTRIBUTOR 22162-15M02 CAP ASSY-DISTRIBUTOR 22162-15M03 CAP ASSY-DISTRIBUTOR 22162-15M04 CAP ASSY-DISTRIBUTOR 22162-52A01 CAP ASSY-DISTRIBUTOR ** Master Pro 2-4870A ** BWD C708 ** Beck/Arnley 174-6861 ** ACDelco E303E
CAP & ROTOR KIT * Bosch 06089 Fits these USA models ** 1982 Datsun 310 (N10) E15 ** 1983 Datsun Pulsar (N12) E16 ** 1983-1986 Datsun Pulsar NX (KN13) E16 ** 1982-1986 Datsun Sentra (B11) E15S,E16 ** 1983-1984 Subaru Brat 1800,1800 Turbo
N10 E15S USA, N12 E16S USA, B11 E15S+E16S 22157-H9560 ROTOR-HEAD ** Master Pro 2-3774 ** BWD D575 ** BWD D680 "Nascar" Fits: * 1976 Accord * 1975-1975 Civic * Many Datsun. See B-210_Electronic_Distributor_Swap#Rotor
22163-15M00 STATOR [Sheet metal type] 22115-15M00 SIGNAL ROTO ASSY [Reluctor] 22136-21M00, 22136-D4700 PLATE ASSY-BREAKER 22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring] 22108-15M00 SHAFT ASSY [weight & spring shaft] 22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT 22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine 22132-21M00 CAM SET
D4P
Source Vehicles
- Chevrolet S10/Blazer 1982-1985 1.9/2.0
- GMC S15/Jimmy 1982-1985 1.9/2.0
- Honda 1980-1990
- Isuzu 1986-1995
- Nissan 1983-1987 E-series, CA16DE
- Subaru 1981-1989
- 22100-24B01 JDM Nissan March K10 with MA10S.AT (PK10) 8901-
- Looks similar to E-series dizzy and engine. PLASMA is 1.0 liter range
Subaru uses same part code as Nissan (22100 for distributor) as stamped on the distributor body.
Isuzu D4R uses a different case hold-down
Australia
This looks like D4R electronic distributor, which was found in Australia:
This has the one-piece ignitor & pickup (ignitor part number Nissan 22020-15M00/22020-15M20)
Advance Bearing Plate
It has a simplified design compared to the earlier D4 distributors. The plastic bearing race contains 4 ball-bearings (up from 3) and slightly beefier design.
The bottom race is similar to the older Hitachi, but slightly smaller.
