You can add rear disc brakes to H145 with a Australia-built R31 Skyline/Pintara setup. Fits over 13" steel wheels.
H145
It will also fit H150 as H145/H150 housing ends are the same.
Click each photo to read the comments and find more detail.
Use a Brake Proportioning valve to set the balance. These are large rear brakes.
R31 Caliper bracket modified to fit H145
Holes re-drilled for H145 housing pattern
Remove the axles. Cut the axle bearing retainers and remove the axle bearings. Now you can remove the drum backing plate, and but more importantly will be able to fit the adapter over the axles. New bearings can then be fitted.
Lay H145 drum brake backing plate over Adapter, mark the holes to drill
Finned R31 caliper bolts to the adapter
The factory adapter is thin, but adequately strong
Consider use appropriate shims inside of the caliper bracket to prevent the bearing from moving. The stock H145 setup using shims between backing plate and housing.
Handbrake Considerations
Fit the calipers facing forward so you can run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
You can use one of the R31 cables to do the RH side but the LH side is not the correct length. Have a brake shop make a new cable or mix-match at the wreckers
H165
R31 rotors on H165 ute axle housing
GM calipers fitted (for a handbrake-less setup)
