Datsun 1200 has a service brake system with the handle conveniently located between the two front seats. Also known as "emergency brake" or "hand brake" (the primary brakes are called the "service brakes").
74965 Handbrake cover is called by Nissan the "parking brake lever COVER".
36310 Hand Brake Lever Assembly (comes in black, brown and grey)
36315-H1001 Hand Brake Handle
36402 front handbrake cable
36400 rear cable (complete set)
UTE: Parking Brake Cable goes out the back wall
Hand Brake Cover
B210 cover also fits.
Top: replacement part, same as B210 | Bottom: original B110 design
ブレーキカバー
Cable Routing
Front half is same for all 1200
Ute - cable comes out the cab lower rear panel
Dash-top Indicator Lamp
Some utes had a PARK BRAKE lamp on top of the dash that lit up when the handbrake was activated and IGN was ON.
Light Switch
See main article: Brake Wiring#Hand Brake Switch
Also see: Hand Brake Part Numbers
- 74965-H7300 BOOTS-HAND BRAKE [Large style]
- 74965-H1000 COVER ASSY-PARKING BRAKE LEVER B120 8910-
- 74965-G1060 B120 7804-8910 [Brown]
- 36011-89901 SWITCH-HAND BRAKE USA
- 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
- Also fits B210 USA
- Also fits B210 JAPAN from '75-4
Aftermarket Cable
- 48-1/4" Overall Length, 2 Per Car
- RAYBESTOS BC92888 $39.79
- ACDELCO 18P154, 18033072 $48.79
B140
2005 bakkie with Bench Seat has the hand brake lever next to the door.
