A strut tower bar is a cool-looking piece of hardware that ties the two strut towers together. Also known as strut bar, dampener, damper bar, strut brace, or Monte Carlo bar. The performance theory is that it reduces chassis deformation on hard cornering.
B110 strut-top bolt circle is the same as other Nissans: 122mm diameter
Track 1200s will crack at the back of the strut towers. Not needed on a street car.
The brace can be as simple as a single piece of tubing
Low and high versions * Flat bar * Round bar * Round with taper ends * Square section tube
high mounts point for extra clearance
Vendors
Titan
eeeCustoms
Nissan Prince Sporty Kit
boofhead
Nismo
Cusco
Cusco Type ST steel shaft クスコ タワーバー (part number 204 510 A) - clears A14/A15 engine
Mad Dat
Maddat Strut Brace
Maddat Tri-bar Strut Brace
Fumiya
Toyota
Dimensions
1200 strut-top bolt circle: 122mm diameter
B110/B120 strut width center-to-center: 936 mm (36.85 inch)
Adjustable
Stiffening Bars
frankthedolphintrainer - extra clearance for CA18DE
strut brace, tower bar,strut bar,dampener,damper bar,brace,Monte Carlo bar not steering
