1967-1972 Datsun model series 510 was marketed as Bluebird in the home market, as 180B in the worldwide market. 510 was Datsun's compact car (C-segment), being larger and heavier than the Sunny 1000 subcompact (A-segment).
Body Styles
BODY STYLES 510 4-door Sedan 510R 2-door Sedan K510 2-door Coupe (semi-fastback design) V510 4-door Van (Wagon)
Datsun model series 510 was marketed in Japan as the Bluebird, in America as the 510 and in some countries as 1300/1400/1600 depending on engine (L13, L14 or L16).
510 was the first Bluebird with unit-body construction (model 410 had an old-fashioned full frame). 510 had modern suspension with front McPherson Struts and IRS (Independent Rear Suspension) on most models. It was the first Datsun light car with Overhead Cam Engine (L-series engine).
510 was Datsun's compact model, being 0.6 inches wider than the sub-compact B210.
ENGINES 510 1300 L13 engine N510 1400 L14 engine P510 1600 L16 engine H510 1800 L18 engine
The 510 was Datsun's most successful sedan racer
4-door Sedan
2-door Coupe
2-door Sedan vs 2-door Coupe (semi-fastback}
K510 Coupe is a fastback 2-door
K510 Coupe (silver car) at DATNATS 2011
2-door Sedan
510R - 2-door Sedan is a notchback 2-door
Wagon
Custom Convertible
Hainz Washington roadster. Sold by Hainz in 2017 for $5,000 USD.
Following data is complied from the old Ozdat web site
Datsun 1600 convertible owned by Hainz Perry. This was created from a 1969 4-door 510 by Andy Aker in Renton, Washingtonᵂ USA in the early 1980s. An unknown owner had the top cut and frame reinforced inside & underneath. Hainz purchased this car frome Eric Edwards [sometime prior to 2001] and had the car rebuilt (front end) after a collision.
- Owner: Hainz Maui Perry - Kent/Covington, Washingtonᵂ USA
- L18 engine with flattop pistons
- A87 cylinder head
- NISMO Comp (1.5") Manifold with Mikuni PHH44 carburetors
- Neely Motorsprt box flares kit
- 510 SSS grille
- 2-bulb turn signals
- KOENIG Seats
- Autopower roll bar
- Datsun 510 4-speed transmission 63-series
- Datsun 240Z R200 LSD
- Wheels: COMPOMOTIVE 3pcs wheels 8x15 front, 10x15 rear
- Tires: Yokohama AVS tires
Custom Ute
One-off custom 510 Coupe Utility
Custom
SR Turbo 510 (SRT510 plates)
Stamm-mobile
RED DEVIL Stamm-mobile with 15" Simmons V4 wheels
CA18-powered 510
510 with CA engine swap
FJ Power
FJ20 Turbo engine
