<-- back to Interior
Datsun 1200 original upholstery was a very lightweight material. Colors available varied by market. Most common was black vinyl seats and door panels, beige headliner and interior panel trim, and blue rubber floor mats.
Color
Japan * black vinyl * yellow vinyl * cloth with various patterns & color (GL and GX trims)
USA * black vinyl * beige vinyl
Australian-assembled sedans were offered with a variety of seat colors including red and blue.
1973 USA upholstery to meet USA fire-resistant regulations. White or blue at first, and in mid-year black became available.
STD/DX Vinyl Leather
GL Tricotᵂ insert
GX plaid fabric insert
Pillar Trim
Van B-pillar trim (CLOTH-CENTER PILLAR)
ピラー 内張り生地
Headliner
ASSY-CLOTH,HEAD LINING WIRE-LISTING INSULATOR-ROOF FRONT INSULATOR-ROOF REAR
Ready made
- eBay sellers offer Datsun headliners with the bow-stay loops in them (custom fit for the specific car model)
- Headliner is pre-sewn, ready to install. In each sewn seam a pocket is sewn in for your bows to slide in to, same as original.
DIY
- off-white perforated with 1/8" integrated foam backing
Insulated headliner with room lamp removed
Sunny Truck
(注) 73930 G3930-89900 INSULATOR-ROOF (1040x70x10) cut to fit 73930-H1100 -8503 INSULATOR-ROOF 73930-G1900 8504- INSULATOR-ROOF
73910 73910-G1000 CLOTH ASSY-HEADLINING GRAY -7803 73910-G1060 CLOTH ASSY-HEADLINING BEIGE 7804-8011 73905-G1900 CLOTH ASSY-HEADLINING BEIGE 8012-8503 73910-G1900 CLOTH ASSY-HEADLINING BEIGE 8504-8910 73910-95W00 CLOTH ASSY-HEADLINING GRAY 8910-
73921 73920-H1001 WIRE-LISTING, HEADLINING (3)
73220M 73968-G2560 COVER-ROOF BOW -8503 BEIGE (4)
73938 73911-G1000 PAD-ROOF FRONT RAIL (2)
Panel Trim
* Body Side Finish * Floor Side Trim * Rear Wheel House Trim
Similar to
- Adrenaline Wave "White Cap" $15/yard 54" wide
Dashboard
Would this "stretch" vinyl work for recovering a dash? It stretches 100%.
- Stretch Vinyl $24/yard 54" wide
Leather wrapped dash pad with red stitches
Below-door Trim
This trim is on the floor pan sides, below the doors. H11 is designed for B110 Deluxe.
74921-H1100 COVER-FLOOR SIDE FRONT RH [BLACK] 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LB-211 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LH-20 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LH-20 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 74922-H1100 COVER-FLOOR SIDE FRONT LH 74922-H7000 COVER-FLOOR SIDE FRONT LH (BLUE,LB-211
NOTE: H70 is for 1973 USA #fire-resistant materials
2-door models (coupe & sedan) 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 74925-H7001 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 74925-H1300 COVER-FLOOR SIDE REAR RH 74926-H1300 COVER-FLOOR SIDE REAR LH 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13
74921-H1100 COVER-FLOOR SIDE FRONT RH [black]
Seats
Datsun 1200 lightweight vinyl.
Original Type
Covers are made from two vinyl materials:
- inserts: 1/2" square pattern vinyl cut on 45° angle
- perimeter cloth: Leather-like vinyl
The Sedan seats have five wide pleats sewn down the center.
The Coupe seat have five thin pleats sewn down the center.
For a replacment, these are similar:
- Perimeter: Symphony Classic Faux Leather Black $20/yard 29oz/yard @54" wide
- Insert: ?
- Seat Piping: Automotive Welt Black $0.75/yard
Seat covers fold under and are attached via hog rings (hook rings)
Truck
1971-1978 Black
1989-1994 Gray
Custom Upholstery
RATDAT3 sedan seats and matching parcel shelf
B210 rear seat fabric differs.
Leather-grain is much finer than B110
Similar to:
- Perimeter: Allegro $13 USD/yard
- Insert: Shock Carbon Fiber "Carbon" Graphite Grey $14/yard 54" wide
Door Interior Lining
Door Cards were available with black, blue, brown, grey, yellow, red, and taupe covering.
Most common was black.
Headliner
- perforated white with integrated 1/8" foam backing $59 USD/yard
Recoloring
Vinyl surfaces can easily be recolored by using a "vinyl and fabric" spray paint.
