Nissan produce two different A13 engines. The first was used in the 1974 USA B210, and was a tall-deck engine that proceeded the A14 by one year. The newer A13 came in 1980 as an A12-based engine.
A13 (1974)
The 1974 A13 is a 1288cc engine with new tall-deck block casting. It has 73mm bore like the A10 and A12 before it, but with stroke increased to 77mm. This one-year-only model was designed for the American market, to keep the same relative performance with new B210 which was considerably heavier than the B110. Compression ratio reduced to 8.5:1 to help meet US emission control standards, yet the increased displacment resulted in 75hp. To accomodate the longer stroke, the 1974 A13 features a "tall-block" casting with a deck height 15 mm (0.59 inch) higher than previous A-series engines.
Applications:
- 1974 Datsun B-210 (USA and Canada)
A13 (1980)
The 1980-1982 A13 used the same block as the A12 and same stroke of 70 mm, but with a 76 mm bore for a slight increase in displacement to 1270cc. Aside from powering Datsun cars, this engine was used as the base for TS Cup racing and a number of Formula Pacific & Formula 3 race engines
Applications:
- 1980-1982 Datsun Sunny B310 Asian markets (Japan and Southeast Asia)
A13 Racing Engines
Prior to 1980, TS racing cars (1300cc class) used an A12 engine bored out to just under 1300cc.
