The Timing Chain drives the Camshaft.
Also see: Timing Cover
- We have seen a couple of single link timing chains on A12, which is probably the original A10 single row chain. Insist on the factory specified double-chain, like Nissan did for later A10s.
- A rattle can be the trait of a stretched timing chain. Pinging/pinking has also often been mistaken for timing chain rattle
A-series engine has a short timing chain -- and with an automatic adjuster -- it rarely stretches or goes bad.
Compare to the loooooong chaing used in the Nissan KA24E engine:
Replacement
Alignment
Check the cam gear alignment. It should be exactly like this:
If it is not, see Camshaft#Timing.
http://datsun1200.com/modules/myalbum/photos/thumbs/3640jpg
The timing chain kit (timing set) includes: Cam, Crank, Chain, Tensioner
- CLOYES Part # 94054S RockAuto.com $35.79
- CLEVITE/PERFECT CIRCLE Part # 92602
Cam Sprocket
(38 teeth)
- CLOYES Part # S47 RockAuto.com $9.41
Chain
- CLOYES Part # S478 RockAuto.com $9.40
- BECK/ARNLEY Part # 0240226
Tensioner
- CLOYES Part # 95005 RockAuto.com $3.90
Crank Sprocket
19 teeth
- CLOYES Part # S477 RockAuto.com $8.87
