The 63a transmission is a large strong transmission. It was adapted by Nissan to fill a marketing need in USA for a 5-speed (to compete with the Corolla SR-5) and so the existing 63A for the L-series L14 was modified to fit the small A-series A14 engine. This has two special significances:
- It is strong, suitable for overbored, supercharged or turbocharged A-series engines
- Its successor, the 60-Series Transmission 5-speed is much lighter and so a better fit for A14 and A15 naturally aspirated engines. The 60 is also smaller than 63 and so a better fit in Datsun 1200s.
The 63A came in two versions:
- 63A to fit L-series engine
- 63A to fit A-series engine
So check the bellhousing bolt pattern.
The 63A 5-speed debuted:
- 1973 for L16 PB210 JDM
- 02 1976 for L14 B211 JDM
- 02 1976 for A14 B211 JDM
- 04 1976 for A14 B210 USA
Datsun boxes are numbered by the distance between the centres of the countershaft and the main shaft. The 63-series has 63 mm between the shaft centres.
The "A" indicates the transmission revision, not the engine type it fits. ? my casting has a 63A#1 cast were there different versions?
- 63A
Dogleg 5 speed overdrive 5th Slave cylinder is on the left side Uses AT prop shaft
Source
The 63-series 5-speed for Nissan A Engine came in 1976-1/2 to 1978 Datsun B210 with A14 engine. USA and Japan markets had such cars.
Clutch
63-series take the L-series type input shaft, but small-diameter (standard diameter) A-series size clutch disk. The 63A was first available in USA in April 1976, and only in Coupe.
- 30100-K0500 ASSY-DISC,CLUTCH 5-SPEED(COUPE) B210 USA, JDM $66.07 USD
- superceded 30100-H5801
- 30210-N1600 ASSY-COVER,CLUTCH 5-SPEED(COUPE) B210
http://www.rockauto.com/catalog/x,carcode,1210813,parttype,1996,partGroup,15
Specifications:
- 180mm Diameter (7-1/8") -- same as smaller transmissions (it fits the standard A12 or A14 flywheels)
- 24 Splines [56-series and 60-series use 18 splines]
63-Series 5-speed Swap Notes
It's easy to get the 63 in if your 1200 was originally an automatic with a wider transmission tunnel. Use the auto tranny mount and make an adapter plate that will move the mounts to the right spot.
For manual 1200, remove the factory mounting bosses from the tunnel, and fabricate new ones:
63a crossmember
Note that the factory crossmember mounting brackets have been removed from inside the tunnel. This crossmember bolts to the floor.
Get a Datsun 810 speedometer cable, it's about 150 mm longer.
You'll need a prop shaft from an AT equipped 60 series tranny as it uses the same output shaft.
Tunnel Mounts Removal
Discussion: Tunnel mount removal?
The rear engine mount (gearbox mount) brackets are spot-welded on. Don't drill them right out. There is a special spot weld removal drill bit. Go to Mitre 10 or a decent Hardware they will have them. Grab a wire wheel or coarse sand paper sand around the mounts so you expose the spot welds a bit better and then carefully drill with the bit it will leave little lumps and you can file or coarse sand them down smooth. The last thing i would want is more holes in the body and floor -- they are thin enough already.
The only problem is that the spot weld drill bit insanely high-priced.
Gear Ratios
| Gear | F5C56A GX5 | F5C56A Opt. 1 | F5C56A Opt.2 | Overdrive 5 | Overdrive 5 | FS5W60A A14 | FS5W60A A15 | FS5W63A A14 |
| 1st | 3.757 | 3.757 | 2.676 | 3.513 | 3.513 | 3.513 | 3.513 | 3.382 |
| 2nd | 2.374 | 2.374 | 1.691 | 2.17 | 2.17 | 2.17 | 2.17 | 2.013 |
| 3rd | 1.659 | 1.659 | 1.398 | 1.378 | 1.378 | 1.378 | 1.32 | 1.312 |
| 4th | 1.254 | 1.291 | 1.181 | 1 | 1 | 1 | 1 | 1 |
| 5th | 1 | 1 | 1 | 0.875 | 0.825 | 0.821 | 0.821 | 0.854 |
| Rev | 4.04 | 4.04 | 2.877 | 3.764 | 3.764 | 3.764 | 3.764 | 3.57 |
| Note | Stock B110 & B210 GX-5 | wide ratio PN 32010-H7251P | close ratio PN 32010-H7220N | ? | ? | 1980 NA shop manual | 1980 NA Shop manual | 1978 NA Shop manual |
Also see: 4-speed gear ratios at end of article 5-Speeds
For A-series Engine (FS5W63A)
- 32101-H7320 Transmission Case, 1976-1978 5-speed B210 Coupe
- 32130-N5809 Rear ASSY-EXTENSION, 1976-1978 5-speed B210 Coupe
For L-series Engine (FS5W63A)
- 32101-N6810 Transmission Case, S10 (formerly 32101-N6800)
- 32130-N6809 Rear ASSY-EXTENSION, S10
- 32101-N6810 Transmission Case, 1977-0679 A10 (formerly 32101-N6800)
- 32101-W0411 Transmission Case, 0779-up A10
- 32130-N6809 Rear ASSY-EXTENSION, -0679 A10 USA
- 32130-N9009 Rear ASSY-EXTENSION, -0679 A10 Canada
- 32130-W7100 Rear ASSY-EXTENSION, 0779- A10 USA
Front Case
Front case contains the bell housing and cover the first half of the gearset.
S10: 32101-N6810 CASE-TRANSMISSION L20B USA * superceded 32101-N6800 B210: 32101-H7320 CASE-TRANSMISSION USA B211: 32101-N6700 CASE ASSY-TRANSMISSION A14S JDM B211: 32101-N6800 CASE ASSY-TRANSMISSION L16S JDM PB210: 32101-N9001 CASE-transmission L14 (from '74-9) JDM * replaced 32101-N9000 (to '74-8)
Gearset
From 1978 B210 parts catalog (Japan Market version)
- 32604-P0100 RING-BAULK (5) FS5W63A 5-speed JDM B210
- Same number listed in USA catalog
