Bed
Revision as of 08:23, 25 May 2012; view current revision
Category: Sunny Truck
Datsun 1200 B120 pickup came with integral cargo well (pickup bed). This bed/tray is once piece with the body. Most dirt bikes fit with about half the tire hanging over the tailgate.
See Also
Bikes
From little bikes to big bikes, the 1200 ute has got guts.
See B120 Bike Carrier
Hauling
500kg payload
See Hauling
Capacity
Loading Capacity Label '最大積載量500kg' (Maximum payload 500kg), see Badges
B140 Net Load Capacity 591 kg.
GCM 1750 kg
GVM 1349 kg (Standard LDV)
GVM 1360 kg (Champ)
In New Zealand it was marketed as a 1/2 Tonne:
Measurements
The Long Body 1200 tray is 295 mm longer than the regular Short Body.
LoadBox 1518 x 1285 x 415
Length Short Bed
  • at bottom of tray: 1670 mm; 2060 mm tailgate down
  • level with tray top: 1565 mm length
Length Long Bed
  • at bottom of tray: 1960 mm
  • level with tray top: 1860 mm
Depth:
  • 415 mm regular bed
  • 420 mm Long bed
Inside Width
  • 1285 mm
  • Between wheelwells: 980 cm
Bed height from ground
  • 795 mm regular bed
  • 575 mm long bed
Rope Hooks
The tray hooks are welded on 4 each side. Long body has 5 each side.
The tray "lip" is part of the body inner side panel, not part of the quarter panel (outer side panel).
Removing
Your typical de-hookian operation involves:
  1. Cut off the tray lip
  2. Weld inner panel to outer panel
  3. Cover weld with smooth body putty
  4. Re-paint
Or you can grind the hooks off, but leave the lip:
You can also put new hooks out of site:
Sometimes the Rain Gutter is shaved at the same time:
Sometimes the Tailgate handles are shaved and gate welded into the body:
