Weber 32/36 Carburetor
Revision as of 05:15, 25 November 2006; view current revision
Category: Fuel System
The Weber 32/36 is a two-barrel progressive linkage downdraft carb. It runs on the smaller venturi for better economy and throttle response until the throttle is pushed down to about half way, at which point the larger throttle starts to open. At full throttle both side are wide open. Italian design. High fuel-economy. Excellent top-end power. Tunable. Available. Easy to work on. Did I mention inexpensive?
Also see these articles:
Weber DGV Models
They are available in different venture sizes:
  • 330 CFM <li>26mm primary venturi: 270 CFM <li>23mm primary venturi: 235 CFM (1979-82 Fords) </ul> 798.jpg4764.jpg881.jpg
    Weber 32/36 models
    DGV manual choke
    DGEV automatic (electric) choke
    DGAV automatic (water heated) choke
    DFEV/DFAV mirror-image to DGV series
    Holley 180 Australian licensed version of Weber 32/36
    Holley 5200 US licensed version of Weber 32/36
    Holley G180/Holley 5200
    In Oz, the G180 is a licensed version of the Weber 32/36 and fitted to:
      <li>2-liter Ford Escorts <li>2-liter Ford Cortinas
    In the US this carb is named the "Holley 5200". It came on the:
      <li>1970-1980 Pinto and Mustang 4-cyl and 2.8 V6 <li>1979-1982 Ford Courier pickup 2-liter engine <li>1979-1982 Fairmont/Granada/Mustang/Capri/ 2.3 liter 4-cyl <li>Chrysler 1.7, 1.6 & 2.2 engines <li>Chevrolet Vega and Chevette, Pontiac Sunbird and Astre
    Inside the carb it actually says "Weber", but outside there is a different brand name.
    Holley 6200
    The Holley 6200 is a feedback version (electronically controlled jet system in conjunction with a an O2 sensor). Holley used to sell an electronic "dial a jet" package that would plug into a feedback carb, bypassing the oxygen sensor, and letting you control the amount of fuel through a dial on the dashboard. I would like to get hold of one of these control modules. reference: Aaron
    Progressive vs. Non-Progressive Carburetors
    For a discussion of the progressive 32/36 vs. the synchronous 38/38, the IDF (Solex 40 style) and the DCOE racing series see Which Weber is right for me?.
    The 38mm DGAS carb should be the only consideration if the engine is in the future or currently going to have any level of additional engine modification. Such as headers, free flowing exhaust, a cam, or rebuilt engine. Usually these motors will be improved over stock with oversize pistons and towing cam. The 38 will enhance the improvements of any of these items ... It will provide considerably more initial torque and acceleration but the top end performance will not be significantly improved over the 32/36 when used on a stock [4.2 liter] motor.
    Note, that is better torque -- but not better throttle response. The 32/36 should be smoother than the 38/37 for a small street-going motor like the A14.
    Electric Choke?
    The electric choke works great and hooks up the stock Datsun electric wire. Take the choke off and make sure the spring still has "springiness" to it. If not, replace it. To test it, the choke should just barely close the throttle in the coldest of mornings. After several minutes of running the engine, the spring should heat up and fully open the choke. If it's weak, just get a new one. The Holley chokes fits the Weber carb. Electric chokes come on the Chryslers and Chevrolet Chevette, so should be readily available from any parts store.
    DGAV - Automatic choke, water heated DGEV - Electric choke DGV - manual choke
    Does yours have a non-adjustable electric choke? Simply drill the face off the rivet, push them through and add screws (it's probably already threaded). Now you have an adjustable choke.
    Fords and Vegas had a water heated choke which could be used instead of an electric choke.
    The electric choke on the 1200 (1972 and up have electric choke) has power supplied from the ignition switch circuit. However, this is switch on/off by the choke relay from a signal put out by the alternator/regulator "N" wire. This means the choke only gets power when the ignition is ON and the alternator is putting out power (engine running). Other makers use an oil pressure switch for the same purpose. For a 1971 car, you could simply hook it up directly, the downside would be if you let the car sit with IGN on for a while before starting the choke would open up, even if it is cold outside, possibly preventing the engine from starting.
    See: engine wiring
    Throttle linkage
    Get a kit if you have the money to spare. But if you want to save money, I used the stock Datsun throttle cable, and modified the Weber linkage, which was for another type of engine, and used some thin strap steel to make a bracket. This was by far the hardest part.
    Book and manuals
    Where to buy?
    Weber "Kit "
    Kits run around $250-$350 USD and include:
      <li>New carb <li>adapter <li>air filter <li>throttle linkage
    You can get a kit for your specific application, or a generic one with "universal" throttle linkage, etc.
    Used Webers run around $50 for a bare carb to $200 for a pristine used kit. If you buy a used one, unless it came from an A-series engine, plan on making or buying the linkage and adapter.
    Performance Jetting kits
    You will need this. A selection of jets to fine tune your power and fuel efficiency. You don't want to be one of the yahoos driving around belching black smoke all the while feeling proud that your car actually runs -- you can have power and economy both with a little bit of effort.
    Parts Suppliers
    Adapters
    589.JPGAdapter
    Adapters for many models are available for sale, but I made my own adapter for the Nissan A12 engine out of a block of aluminum.
    Custom machined adapter (left) and kit-provided cast adapter]
      <li>Dimensions: 1 x 2.75 x 5 inches (minimum would be approximately 10 x 6.7 x 11.4 mm) <li>Using a Nissan gasket as a template on one side, and the Weber gasket on the other, mark the holes. <li>Drill two bores ~30mm and 27mm to match the intake manifold. You might have a machine shop do this; I had access to a lathe with a large bit chuck into it. <li>Drill and Countersink holes for stock Nissan pattern using a drill press to get them straight. <li>Thread holes for Weber pattern <li>Use a round rasp file to smooth out the transition from the small Nissan bore holes to the larger Weber holes you drew from the template
    500.jpgWeber Adapters
    Carburetor Tuning
    Float setting notes
      <li>Fuel pressure is critical to float spillage. Redline recommends 2.5 to 3 lbs <li>For aggressive off-road float drop should be limited to 44 .5 mm max drop
    Reference: http://www.redlineweber.com parts_breakdown
    Carburetor set-up and lean best idle adjustment
    Baseline settings (to get your engine started)
      <li>Speed Screw 1 to 11/2 turns <li>Mixture Screw 2 turns
    See http://www.redlineweber.com/html/Tech/carburetor_set_up_and_lean_best_.htm
    How to hook up the crankcase breather?
    See engine question?? discussion in the main forum.
    Jetting
    Tuning is a Must If you buy a kit for your specific engine, it will run fairly good out of the box, but should still be tuned to match your engine. If you obtain one second-hand, count on swapping jets, emulsions tube and other tuning parts to make your engine run right. Black smoke, smelly exhaust, jerky acceleration and poor fuel economy is what you get before you tune it. It may "feel powerful", but you can make it run even better with some patience and the right parts. You can get the tuning parts from Redline.
    Jets, emulsion tubes and throttle pump nozzles
    Top-End Performance of Hollywood sells Redline Weber kits. Here is the jetting they list for the performance 32/36 kit for A-series engine. Presumbly this is for a stock engine:
    Carb: 32/36 DGAV or 32/36 DGEV
    Part #: 22680.033B
    Venturis: 26/27 (compare to Optimum Carburetor Choke Size)
    Auxiliary venturis: 3.5/3.5
    Main jets: 140/140
    Emulsion tubes: F50/F50
    Air correction jets: 170/160
    Idle jets: 60/50
    Jump jet: 50
    Needle valve: 2.00
    anb008 had his standard A12 with Weber 32/36 carb rejetted and dyno'ed. The jet settings are:
    Primary mentioned first, then Sec...
    Air Correction: 175/145
    Fuel: 120/145
    Emulsion Tube: F66/F66
    Choke Tube: 3.5/4.5
    Idle:
    50/55
    2924.jpg Weber 32/36 jets
    Weber D**V tuning as a systems engineer
    B210sleeper:
    I've had a weber dfav ( holley 5200 whatever ) for about a year now, and I thought that the procedures for getting it running right were needlessly obscure. Baselines
    main jet140/145
    Air Corrector165/175
    E-Tubef6/f6
    Idle jet.45/.50
    Idle Air1.50/0.70
    idle mixture screw2 turns CCW from bottom
    Idle speed~ 1 1/2 turns from first contact
    ** these values = +/- one step are a baseline. The car will run like this, not ideally but you could.
    Definitions: I feel that some explaination of the jets would be helpful.
    Main Jet: This is in the fuel bowl, it controls the maximum amount of fuel to enter each circuit . It has final control over the mixture at WOT, since if it's too small you will always be lean no matter what you do. Likewise too big and you'll be rich to the point that you can't compensate.
    Air Corrector: This controls how much air flow it takes to activate a circuit. Means if you should keep changing these down till you develop a flat spot in the throttle. there can be as many as 3 distinct flat spots, you'll probably only ever experience 2, the first caused in the primary at about 80% throttle and extending to lower percentages as it gets exceedingly larger. The second is in the secondary the remaining % of throttle range starting at WOT and extending down as it continues larger. The third is caused by those idle air correctors, but those should never be messed with, you can't even order them. But if you had a pesky idle problem, you might want to find them and make sure they're installed, not blocked,etc... A flat spot around 2000 rpm would be idle jets too small.
    E-Tube: Misunderstood emulsion tube, it's a complicated part that regulates the A/F ratio the numbers of holes and where they occur work it's magic, they are found directly under the air correctors and shouldn't be mucked with. Make sure they're baseline.
    Idle jet: It's the idle jet, it controls how much fuel is delivered at idle. It won't significantly effect the AF ratios for driving. Fix idle problems here. One thing... If you've reached a very small idle jet you might want to use larger ones and lean down the main jets ( tiny idles plug easily and that would be annoying ) A flat spot around 2000 rpm would be idle jets too small.
    Idle Air Corrector: Suppose your car just won't idle but otherwise ran fine, this would be why. It also might be responsible for cars that idle at 2000 rpm and can't be slowed, because it's missing or plugged. You shouldn't need to touch these.
    So now you understand what the parts do.
    Setup priorities:
      <li>eliminate vacuum leaks <li>install a secondary fuel filter of some kind to capture tiny particles that seem to end up in the carb no matter what. <li>set advance. Webers seem to like lots of advance, so give it all you can ( don't detonate, don't give it 30 deg static, be reasonable, I have 7 static and it's pretty good, as much as 12 ) <li>make sure you're using ported vacuum (off the carb body ) if you're not using it understand why. <li>Set idle mixture screw = 2 turns out <li>set idle speed 1 1/2 turns out <li>try to start the car <li>let the car warm up... a challenge perhaps, but it needs to be warmed up <li>if it runs turn idle mixture screw clockwise till the car runs worse, then turn counter clockwise till the idle speed picks up, somewhere in there will be a point that sounds best. If that point is making it idle super fast turn the idle speed down, you should be able to get the idle down ( if not that's a symptom of something. )Don't worry too much about how much in or out the screw is, the sharpness of the point at the end of it has changed over the years, so if it's more than 2 1/2 turns out it may not be as bad as it once was. If the car is making a noise like sucking the bottom of a cup with a straw, then your fuel bowl level is too high, either the needle valve is stuck, or it's leaking or someone didn't tighten everything down, but it'll be running too rich and the gasket will probably be wet when you take it apart. <li>so you've made it past idle setup, now blip the throttle a bit in neutral, do it slow and mind your rpm, does it gain rpm smoothly and not bog or have other issues up to 1/4 throttle? If so then you can try to drive it, don't go far, don't go in traffic, go down the block, take notice of how the car responds from a dead stop, you probably wont get past 1/2 throttle, any flat spots? if the flat spot is idle - 2000 rpm then it's likely that your primary idle jets are too small. if there's a flat spot further up in the range it's the primary air corrector being too large. Don't worry about WOT now! <li>Go home of wherever and make adjustments needed based on that road test, take note of how the car shuts off too. Webers without anti dieseling solenoids are fussy and tend to run-on. But shouldn't backfire, or afterfire ( one's out he carb and the other is out the tail pipe, having a catylitic converter make make this a problem ) <li>Having an EGT ( exhaust gas temperature ) gauge will help with this part, otherwise it's butt dyno or the real dyno. You can also use O2 gauge if you have one [a/f meter]. You've made it this far you're almost there. Now is secondary circuit tuning, you can only do this at WOT, so take that in mind when choosing a place. Your air correctors default value is from a 2 liter engine, so you will need to make them smaller, just keep making them smaller till that WOT flat spot goes away. Your smaller engine needs less fuel than the 2l default values, so you'll want to make the fuel jets smaller too that will make the mixture leaner. If your idle jets are really small, make the fuel jets smaller instead, and bring the idle jets back up a size or 2.
    You should now have a car that is quite a bit snappier, it may be very touchy now, i suppose the final call comes out to what you like to drive, but you'll understand how to change things now.
    At this point you may want to take the car to somewhere with a wide band emissions monitor and a dyno and perfect it, but you'll have a running car in any case.
