Nissan Z Engine
Revision as of 05:16, 7 June 2012; view current revision
Category: Nissan Engines
Z18ET turbo, Z20, Z22. These crossflow-headed engines are based on the L-series. All install into a 1200 more or less the same way.
79.JPG Z20 NAPS-Z engine
825.jpg Supercharged NAPS-Z engine
829.jpg Turbocharged NAPS-Z engine
Z24 in Datsun 1200
Z18 Turbo
The nice thing about the Z18ET is its a factory setup, legal in most Australia states for a 1200. The downside is how available is it, including the wiring harness?
43.jpg Z18T Turbo Engine
Sources
Z-series was a common engine in the larger Datsuns, as it replaced the L-series engine starting in 1979.
Z16S
Z18E/Z18S/Z18T
Z20D/Z20S/Z20E
Z22S
VEHICLE APPLICATION
720	Z16S/Z18S
910	Z16S/Z18S/Z18E/Z18T/Z18P/Z20S/Z20E
C120 	Z20S
C31 	Z18P/Z18S/Z20S
D21 	Z16S/Z18S/Z20S
E23 	Z18S/Z20S
E24 	Z20S
F22 	Z16S/Z20S
F30 	Z18S
H40 	Z20D/Z20S
R30 	Z18S/Z20E
S110 	Z18E/Z18S/Z18T/Z20E
TC22 	Z20S
W40 	Z22S
WE24 	Z20S
8-plug (twin-plug head)
E24	Z20
WE24	Z20S
910	Z16S/Z18S/Z18P/Z18E/Z18ET/Z20S/Z20E
C120	Z20
C31	Z18S/Z18P/Z20S
E23	Z20
F30	Z18S
R30	Z18S/Z20E
S110	Z18S/Z18E/Z18ET/Z20E
4-plug (single-plug head)
720	Z16/Z18
D21	Z16S/Z18S/Z20S
TC22	Z20S
W40	Z22S
910	Z16S
E23	Z18/Z20
E24	Z20
F22	Z16/Z20
H40	Z20D/Z20S
R30	Z18S
North America
Z20S/Z20E
Z22S/Z22E
Z24S/Z24E/Z24I
S = single carburetor
E = multi-point injection
I = throttle body injection
VEHICLE APPLICATION
720	Z20S/Z22S/Z24S/Z24I
D21	Z24S
WD21	Z24I
GC22	Z24I
S110	Z20E/Z22E
4-PLUG (SINGLE-PLUG HEAD)
S110 Z20E FED (CAL used 8-plug)
Swap Notes
Z-series is the 2nd generation of the L-series engine. So oil pans and mounting is the same as fitting an L-series engine.
Also see L-series Engine Swap crossmember, sump sections.
Transmission
Z-series uses the same transmissions as the KA-series engines. The bolt pattern is the same as the L-series but the lean is different.
See Transmission section of KA Engine Swap
Crossmember & Sump
Stock 1200 crossmember may be used unmodified:
Vanette Z-22 sump fits stock crossmember too:
Engine Mounts
