Datsun 1200s were fitted with various consoles including full-style and auto/ute style.
Full Size
Full size console was usually fitted with a Clock, as the Tachometer was rightly fitted into the dashboard. But you can put a tach in the console if you so choose.
SSS
GX
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
- 74980-H2010 ASS'Y-CONSOLE BOX [full, fitted to GL manual models]
- 74980-H2020 ASS'Y-CONSOLE BOX [full, fitted to GL automatic models]
1971-12 Japan [Facelift] catalog
- 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL 4-speed
- 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
1971-4 Japan catalog
- 79482-H1801 FINISHER-console box
- 27389-H2300 SPACER-rubber (fixing clock to console box) (op.) ALL
USA Catalog
- 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
- 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
- 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
Mask
'Sunny' 25005-H1800 MASK-tachometer [instrument panel] 74990-H2021 MASK-clock [console] 85-13412-1 SCREW 3 89-15434-1 WASHER-plain 3
'Datsun' 25005-H1810 MASK-TACHOMETER "DATSUN" [instrument panel] 74990-H1800 MASK-CLOCK [console] 08513-41212 SCREW 3 08915-43410 WASHER-PLAIN 3
Excellent
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also these unique 3-gauge versions. For more, see: PB110
PB110s could also come with regular-style gauge layout
Short Console
The short pocket-type console was fitted to:
- USA Automatic 1200s
- JAPAN non-GL automatic (GLs autos used a full console)
- JAPAN 3-speed column shift OPTION
- B120 Pickups as standard equipment (except STD models)
Full and short consoles use the same shifter boot.
- G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
1971-4/12 Japan catalogs
- 74980-H1801 ASS'Y-CONSOLE BOX, with bracket 4-speed (ex. GL, GX)
- 74982-H1801 FINISHER-console box
- 74986-H1801 ASS'T-BOOT
- 74980-H1021 ASS'Y-CONSOLE BOX, with bracket A-all (ex. GL)
North America catalog
- 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC
- 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC
B120 1974 Catalog
- 74980-H1801 BOX ASS'Y-console, with bracket [Black]
- 74982-H1801 FINISHER-console box [chrome trim]
- 74986-H1801 BOOT ASS'Y
- 08510-61642 SCREW (8)
- 08915-43642 WASHER-plain (4)
- 01241-00061 NUT-spring (4)
B120 1997 Catalog
- 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET 7510-7803 [Black]
- 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
- 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
- 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910
- 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
- 74982-H1801 PANEL-CONSOLE A 7510-8109 [trim]
- 74982-G1900 PANEL-CONSOLE A 8110-8910 [Chrome trim] K504
- 96930-95W00 PANEL-CONSOLE A 8910- [gray trim]
- 74986-H1801 BOOT-CONSOLE 7510-8109
- 74986-G1160 BOOT-CONSOLE 7804-7907 DARK BROWN
- 74986-G1660 BOOT-CONSOLE 7908-8910 BROWN
- 96935-95W00 BOOT-CONSOLE 8910- GRAY
- 74987-H1801 BRACKET-CONSOLE FRONT
- 08510-61642 SCREW (2)
- 08961-13240 NUT (2)
- 01241-00061 NUT (2)
- 08510-61697 SCREW (2)
- 74988-G1160 BRACKET-CONSOLE REAR
Fibreglas
Aftermarket
Armco aftermarket/dealer installed
Custom
Portugal 1200s. Are the custom consoles?
Documentation
Alternative Sources
keywords: コンソール
