Stock Wheels
- 12" diameter
- 4-inch wide
| wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
| size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
| offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
| tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
| balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
| lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
B310 Wheels
ホイール
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
S13 Rims
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole USA * Base: 195/60R15 * SE: 205/60R15
10-hole Spare 15" x 4", 4 Lug, 4.5" Bolt Pattern
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Pursuit/chaser" style wheel may be used on Datsun 1200.
See main article: Pursuits
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See main article: TRX Wheels
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the offest must be reduced from +30.
- Rear: +30 offset works best with Datsun 1200.
Rear
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
Wheel Adapters
Wheel Spacers
If the offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
Wreckers are your best bargain here ... lots of 13, 14, 15, 16 and 17" wheels and tires.
Manufacturers
- SSR Speed Star Wheels sells new and classic designs
- http://www.panasport.com
- Konig makes a retro-style wheel with the proper offset for RWD application. Konig Rewind
- Minilite Wheels - The real deal! alloy racing wheels 12x5 only $159 each in Silver, Black, White. Gold and Anthracite also available.
Mail order
- tirerack.com
- http://classicdatsun.com has Panasports
