Console
Revision as of 22:34, 18 December 2014; view current revision
Category: Body
Datsun 1200s were fitted with various consoles including full-style and auto/ute style.
Full Size
Full size console was usually fitted with a Clock, as the Tachometer was rightly fitted into the dashboard. But you can put a tach in the console if you so choose.
21477.jpg Foam block on underside
21478.jpg Brackets
592.jpg w/o heater
6595.jpg SSS 2129.jpg GX
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
  • 74980-H2010 ASS'Y-CONSOLE BOX [full, fitted to GL manual models]
  • 74980-H2020 ASS'Y-CONSOLE BOX [full, fitted to GL automatic models]
1971-12 Japan [Facelift] catalog
  • 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL 4-speed
  • 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
1971-4 Japan catalog
    • 79482-H1801 FINISHER-console box
  • 27389-H2300 SPACER-rubber (fixing clock to console box) (op.) ALL
USA Catalog
  • 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
  • 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
  • 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
Mask
'Sunny'
25005-H1800 MASK-tachometer [instrument panel]
74990-H2021 MASK-clock [console]
 85-13412-1 SCREW 3
 89-15434-1 WASHER-plain 3
'Datsun'
25005-H1810 MASK-TACHOMETER "DATSUN" [instrument panel]
74990-H1800 MASK-CLOCK [console]
 08513-41212 SCREW 3
 08915-43410 WASHER-PLAIN 3
Excellent
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also these unique 3-gauge versions. For more, see: PB110
2010.jpg PB110
9020.jpg 1971
7712.jpg PB110s could also come with regular-style gauge layout
460.jpg 1972 Facelift
Short Console
The short pocket-type console was fitted to:
  • USA Automatic 1200s
  • JAPAN non-GL automatic (GLs autos used a full console)
  • JAPAN 3-speed column shift OPTION
  • B120 Pickups as standard equipment (except STD models)
Console Boot for shift lever (aftermarket)
シフト ブーツ
Full and short consoles use the same shifter boot.
  • G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
1971-4/12 Japan catalogs
  • 74980-H1801 ASS'Y-CONSOLE BOX, with bracket 4-speed (ex. GL, GX)
    • 74982-H1801 FINISHER-console box
    • 74986-H1801 ASS'T-BOOT
  • 74980-H1021 ASS'Y-CONSOLE BOX, with bracket A-all (ex. GL)
North America catalog
  • 74980-H1921 ASSY-BOX CONSOL SEDAN AUTOMATIC
  • 74982-H1021 FINISHER-CONSOL BOX SEDAN AUTOMATIC
B120 1974 Catalog
  • 74980-H1801 BOX ASS'Y-console, with bracket [Black]
    • 74982-H1801 FINISHER-console box [chrome trim]
    • 74986-H1801 BOOT ASS'Y
    • 08510-61642 SCREW (8)
    • 08915-43642 WASHER-plain (4)
    • 01241-00061 NUT-spring (4)
B120 1997 Catalog
  • 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET 7510-7803 [Black]
  • 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
  • 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
  • 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910
  • 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
  • 74982-H1801 PANEL-CONSOLE A 7510-8109 [trim]
  • 74982-G1900 PANEL-CONSOLE A 8110-8910 [Chrome trim] K504
  • 96930-95W00 PANEL-CONSOLE A 8910- [gray trim]
  • 74986-H1801 BOOT-CONSOLE 7510-8109
  • 74986-G1160 BOOT-CONSOLE 7804-7907 DARK BROWN
  • 74986-G1660 BOOT-CONSOLE 7908-8910 BROWN
  • 96935-95W00 BOOT-CONSOLE 8910- GRAY
  • 74987-H1801 BRACKET-CONSOLE FRONT
    • 08510-61642 SCREW (2)
      • 08961-13240 NUT (2)
    • 01241-00061 NUT (2)
      • 08510-61697 SCREW (2)
  • 74988-G1160 BRACKET-CONSOLE REAR
Fibreglas
Glassfibre versions
Aftermarket
Amco aftermarket/dealer installed
Custom
Portugal 1200s. Are the custom consoles?
Documentation
1555.jpg JDM 2209.jpg USA
Alternative Sources
Honda Civic
Barina
Barina
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
838.jpg 1350.jpg 834.jpg 3069.jpg 4748.jpg 4823.jpg 4939.jpg 5619.jpg 9471.jpg 21466.jpg 21467.jpg 21471.jpg 21472.jpg
click
click
click
keywords: コンソール
