Factory Stripes
S1 Stripe
Option 'Datsun' Side Strip
K5040-00067 wide stripe USA 'D A T S U N'
From the OPTIONS catalog (April 1971): K5040-00067 TAPE-masking (10 m) Coupe
GX Side Stripe
From 1970-1971 Catalog ?unlisted?
GX-5
Tape stripe looks similar but differs for Sedan & Coupe.
GX-5 Black and Red
Nissan Part Numbers from 1972 JDM catalog:
Sedan 76820-H7200 STRIPE SET-accent * 76822-H7200 SHEET-accent stripe (R.H.) * 76823-H7200 SHEET-accent stripe (L.H.)
Coupe 76820-H7210 STRIPE SET-accent * 76822-H7210 SHEET-accent stripe (R.H.) * 76823-H7210 SHEET-accent stripe (L.H.)
Factory brochures show a Black & Yellow stripe, which is not in the catalog:
GX-5 Coupe Brochure
PB110
GX
Sedan & Coupe use the same stripe sets
76821-H2703 STRIPE SET-accent (black & yellow) (L.H.) SGX, CGX 76820-H2703 STRIPE SET-accent (black & yellow) (R.H.) SGX, CGX![]()
76821-H2702 STRIPE SET-accent (white & yellow) (L.H.) SGX, CGX 76820-H2702 STRIPE SET-accent (white & yellow) (R.H.) SGX, CGXtopic
GL
- K5040-00195 TAPE-marking (960mm) as req. S-GL
- K5040-00196 LABEL-marking (R.H.) S-GL
- K5040-00197 LABEL-marking (L.H.) S-GL
Bustle Stripe
Bumblebee Stripe
Lightning Stripe
Classic Double Rally Stripe
Single Stripe
BRE Stripes
Also See BRE paint schemes
