Early A-series Datsun engines (1966-1973) feature a front-distributor design. The A Engine Redesign of 1973 moved the distributor back to mid-engine, and moved the motor mounts back about 20 cm.
Block Oiling
Head Oiling
Early blocks have oil coming up through the head gasket to the cylinder head. 1974-up blocks have this hole plugged, and instead the oil comes up the center head bolt hole.
Pickup
Oil Pickup Location & Dipstick
Dimensions
A10 Deck Height: 179.1mm A12/A13/A12A Deck Height: 189.1mm A14/A15 Deck Height: 204.1mm Length (all): 393-394 mm block proper (less timing cover)
A10
B10 Sunny "Datsun 1000" came with A10 engine, 998 cc, 3-main bearing block. All other engines except A10 have 5-main bearings.
JDM Catalog 11010-18000 ALL Except Coupe * uses 13035-18000 ASSY-COVER TIMING CHAIN 11010-18001 from E/# A10-184228 * uses 13035-18001 ASSY-COVER TIMING CHAIN [updated to Double timing chain & pressure tensioner] < 13035-H1000 from 0570 [Fits all B10 blocks] 11010-25700 Coupe
Some B10 was fitted with NIKKI carburetor.
A12 Original
B110 A12 engine, five main bearing (so not interchangeable with A10 engine).
- 11010-H1000 JDM, USA -0470
- 13035-18001 ASSY-COVER TIMING CHAIN [single mark, pulley has multiple marks]
- 11010-H2300 GX, USA non-GX from 0570-
- 13035-H1000 ASSY-COVER TIMING CHAIN [multiple marks]
- [chain tensioner and bolts changed 0570]
A12 from 1974
1974 engine redesign (From October 1973), accessory mounts and engine mounts not compatible with earlier A12 engine.
More bolt holes for more accessories.
Engine mount bosses are 35 mm farther back (in photo, mount is forward, on accessories mounts)
B210 JDM
- 11010-H5000
- 11010-G1600 From June 1975 (?)
- Both use 11110-H5000 PAN ASSY-OIL
- Both use 13035-H1000 COVER-timing chain
B120 JDM (from Oct 1975)
- 11010-G1600 7510-7907
- 11010-G1618 7908-8503
- 11110-H5000 PAN ASSY-OIL 7510-8503
- 11010-G1619 8504-
- 11110-G3401 PAN ASSY-OIL 8504-8910
- All use 13035-H1000 Timing Chain Cover
- 11110-H9701 PAN ASSY-OIL 8910-
B310 JDM
- 11010-H5000 Van -7909
- 11010-H9460 Van 7910-8010
- 11010-H8500 Sedan, Coupe -8010
- 11010-H9463 Van 8011-8109, 8110-
- All use 11110-H5000 PAN ASSY-OIL
- All use 13035-H1000 or 13035-H1010 COVER-timing chain
H10 A12 B110 etc. H72 A14 B210 etc. rear wheel drive M72 A14 N10 Front wheel drive H85 - B310 A12 H86 - A12A/A13M79 - A12
No drain plug (undrilled boss) Single drain plug Dual drain plugs (M22? casting number)![]()
New A12 has offset center core plug (same as original A12), but with two drain plug bosses.
A14 has re-spaced center core plug and single drain plug boss
M2 Block
A12 block with a large 'M2' cast mark on left side
L-series, Z-series, KA-series and A-series were all available with blocks marked M2. Apparently M2 indicates a factory replacement block.
Also cast 'M22' in the usual place, and cast 'A12' above the fuel pump boss
pic
pic
pic
A12 M2 block * Late model design (A Engine Redesign) * Twin drain plugs on left side * Late model scalloped crankshaft * reportedly has small 25mm welch plugs on left side
1974 A13
USA model B210 came with unique pre-A14 tall block engine. B210 USA uses Mid Sump oil pan.
- 11010-H6200 [1974] A13 BARE BLOCK 73mm/2.87" bore size
- 11110-H6200 ASSY-PAN OIL
- 11110-H7200 ASSY-PAN OIL FOR SERVICE
- 11110-H7201 ASSY-PAN OIL FOR SERVICE
- Uses 13035-H1000 Timing Chain Cover
A14
USA B210 11010-H7200 B210 USA * B210 USA uses Mid Sump oil pan * 11110-H6200 ASSY-PAN OIL -0275 * 11110-H7200 ASSY-PAN OIL 0375-0875 * 11110-H7201 ASSY-PAN OIL 0975- * Uses 13035-H1000 Timing Chain Cover
North American B310 11010-H7200 -0779 USA, -1179 CAN 11010-H9905, 11010-H9900 0879- USA 11010-H9115 1279-0780 CAN * 11110-H5000 OIL PAN [same as JDM B210 A12/A14]
A14 cast "A14" above fuel pump H72 Casting mark with "29027A03" cast mark![]()
M79 casting![]()
G34 casting * A14/A15 block![]()
A15
North America B310 * 11010-H9700 -0779 [different from A14] * 11010-H9905 0879- [Shared with A14] ** 11110-H9700 OIL PAN [unique to A15]
Nissan Competition * 11010-H9700 A14/A15 BARE BLOCK 76mm/2.99" bore size
G34 cast mark, also "8" and "238193"
A12A
75mm/2.95" bore size
North America B310
- 11010-H8500 CAN 1278-0779
- 11010-H8502 CAN
- 11010-H9001 CAN 0879-
- 11010-H9960 USA 0879-
- 11110-H5000 OIL PAN
