Water Pump Suction Pipe connects to the front the engine block, and is the inlet for the the cooling system.
B110 A12 uses plain straight pipe
The pipe can be shortened for a cleaner look:
Removal & Installation
The suction pipe is a press fit into the block. Put vice-grips on it and tap the vice-grips until the pipe comes out.
Tap the new pipe into place. It is a taper fit, and needs no sealant.
Remove the suction pipe in exactly the same manner as the breather pipe:
Regular 1200 uses a straight pipe.
21045-18000 PIPE-SUCTION WATER PUMP 21045-H2300 PIPE-suction, water pump GX [small outlet straight up]
The GX inlet pipe at front of block has an additional hose fitting for the manifold coolant hose.
21045-18000 B120 21045-M0100 B120 7510-7907 [one small fitting, curved] 21045-M3000 B120 7908-8910 21045-G5105 B120 8910- [two small fittings near top of pipe]
Regular B210 uses a pipe with one small hose connection.
B210 21045-M0100 A12S,A14S [one small fitting, curved] 21045-M0800 A12T B210 [two small fittings, one straight up] 21045-H8400 A14T B210 [two small fittings, both curved]
Left: 21045-H8400. Right: 21045-M0100
21045-H8400 B310 A12S.S,K,A14-V A13,A15 S,K.A14,K.A12S 21045-H8410 B310 A14S.S,K+AT A15S S,K.A14S 21045-M0100 B310 Van <> 21045-M0110 21045-H8400 A10 A14S.S,K 21045-H8410 A10 A14S.S,K 21045-M0100 A10 A14S.V A14S-7803 21045-M0110 A10 A14S.V
21045-G2501 C120 A12 A14.(V,T) [single small connector] 21045-G2800 C120 A15 A14.K [twin upper curved connectors] 21045-H8400 C120 A15 [two small fittings, both curved] 21045-G5105 C22/TC22 A12+A15 [Twin upper connectors] 21045-G5105 GC22 A15
21045-M0100
21045-M0100 * one small heater hose fitting, curved * for use with Heat Riser manifolds
APPLICATIONS * B120 7510-7907 * B210 A12S,A14S * B310 Van * A10 A14S.V A14S-7803
