Datsun 1200 and Truck variants were fitted with a variety of steering wheels.
Variations
PB110 used the same steering wheels as B110 (at least with early PB110)
B10
The Datsun 1000 (B10) wheels were different:
See main article: B10 Steering Wheel
Removal and Installation
Occasionally you can remove the nut and "pop" it off by hitting it from behind with your fists, but you risk the chance of having it hit you in the face.
Other wheels fit the hub but may not match the trim. The B110 steering wheel hub uses the same bolt pattern as:
- 1977-79 SX200, F10, N10
- 1974-78 B210
- 1971-73 1200
45mm between bolts (1-15/16 inch)
B110 and PB110 (at least early PB110)
OPTIONAL
- 48400-H1200 ASS'Y-WHEEL-steering (wood) OPTION ALL (1973 AU: only op. on Coupe)
- 48400-H2310 ASS'Y-WHEEL-steering (foam skin) OPTION ALL
The optional wheels are different from the B10 mainly in the horn button. The 1200 horn button is wider at the top, and narrower where it bolts to the wheel. The 1000 horn button is the opposite (narrower at the top).
Sunny Truck
- 48400-G1000 up to 7803 - Std style wheel
- 48400-G1010, 48400-G1660, 48400-95W00 from 7804 - B210 style wheel
- 48400-H5000, 48400-H5001 STD, DX, PB210 DX
- 48400-H5100, 48400-H5103 black (wood-like) GL
- 48400-H5102,H5105 black (wood-like) PB210 GL, op. PB210 DX
- 48400-H5101,H5104 brown (wood-like) PB210 GL, op. PB210 DX
- three-spoke
- 48400-H5104 brown (wood-like) L16 GL
- 48400-H5105 black (wood-like) L16 GL
- 48400-H5200, 48400-H5202, 48400-H5203 (leather-like) GX, op. ALL
- 48400-H5600, 48400-H5800, 48400-H5802 (wood) OPTION ALL, PB210 OPTION ALL
- three-spoke, five rectangular holes in each spoke
- 48400-H6000, 48400-H6001, 48400-H6002 (leather-like) PB210 GX, L16 GX, L16 GL
- 48400-H7509 A14T
- 48400-H7800 Van Super Deluxe (black wood-like)
Aftermarket Adapter Hubs
Grant steering wheel installation kit (adapter hub a.k.a "boss kit") will work with APC and Grant wheels.
No. 470-4590 fits
- 1977-79 SX200, F10, 300FX, 310
- 1974-78 B210
- 1971-73 1200
No. 470-3592 does *not* fit the 1200, but fits:
- 1970-83 240Z,260Z 280Z
- 1978-85 Nissan pickup
- 1980-83 Nissan SX200
- 1979-83 Datsun B310
- 1973-75 Datsun 610
- 1974-75 Datsun 710
Momo No. 3503 Will fit on all steering wheels with 6 x 2.75" bolt pattern (such as MOMO, SPW, Netami, Sparco, Mugen ... etc). 2-6/8" distance between center of both opposite screw holes.
- Datsun 240, 260, 280Z, 280ZX,
- Datsun 510, 610, 810 all yrs
- Datsun/Nissan Trucks up to 1986
