Sedan Grille
Revision as of 04:00, 26 March 2016; view current revision
Category: Body
Datsun 1200 Sedans were fitted with a stainless metal grille. 1200 Pickups from 1971-1977 use this too. The 1972 JDM facelift introduced a new grille, but it too was different from the plastic Coupe grille.
Also see: Grille Overview, Badges
Original Grille
Head Lamp Rim
Rim with side-moulding
Emblems
For grille trim badges and part numbers, see Badges
Sedan grille "D" and "S" emblems (marks, badges):
  • Japan market 1200s used "S" mark
  • Export market 1200s used "D" mark
Fitting
Click for full size pictures of the grille mount points:
grille mounts on Core Support
And the eyebrow trim mount points:
Fitting to Others
Fitting Sedan grille is done in Japan to nearly all Datsun 1200 trucks (change from Coupe-type grille to Sedan grille). Also you can fit it to a Coupe.
  1. Fit one L-shaped bracket to center top of front body. The top of bracket should be 1/8" from top of ledge.
  2. Fit two thin brackets to back of sedan grille
  3. Drill four holes in radiator support to correspond to the holes in the sheet bracket
    • Drill them 20mm to the side of the headlight rim screw holes
  4. Screw sheet loops to front of car
  5. Screw grille to sheet loop ends
Installing Round Headlights in Late Truck
Fit the headlight Rims (easiest to do with grille off car)
  1. coupe and late ute are missing the outer bracket:
  2. All core supports have the inner two eyebrow mount holes, though you may need to add the little square screw hole wedgies:
    96706-B0700 GROMMET for screw
See main article: Grille Part Numbers
(1-3) ASS'Y-grille, radiator
62302-H1003 Sedan (exc. GX), Van, Truck DX -7803 $169.65 USD
62302-H2300 Sedan GX
62302-G1000 Truck STD [painted]
(14-19) ASS'Y-RIM, head lamp (Eyebrow Trim\head lamp Rim)
62320-G1000 STD SUNNY TRUCK RH 1971-1975 [NON-CHROME]
62321-G1000 STD SUNNY TRUCK LH 1971-1975 [NON-CHROME]
62320-H1002 chrome (R.H) $39.17 USD
62321-H1002 chrome (L.H) $39.17 USD
(20-25) Surround Trim Coupe, Sedan and Van, Truck
62322-H1001 SURROUND-radiator grille, upper $40.27 USD
62323-H1001 SURROUND-radiator grille, lower $27.13 USD
62324-H1051 SURROUND-radiator grille, side with rubber (R.H) $29.50 USD
62326-H1001 RUBBER-SURROUND,RADIATOR GRILLE (1 per side)
62325-H1051 SURROUND-radiator grille, side with rubber (L.H) $29.50 USD
LOWER SURROUND
Core Support Panels
See Body#Radiator Core Panels
1972 Minor Facelift
The 1972 JDM facelift introduced a new grille for sedans. It featured a wire mesh insert.
new grille
62302-H7200 black GX
62302-H7200 GX Grille [Black] with square mesh
62302-H3100 STD, DX and GL grille [Argent] with square mesh
67829 62302-H3100 Grille with honeycomb mesh
South Africa GX version with 'D' badge
Retro-fitted to Sunny Truck:
62380-H3215 inserts (2 needed)
cast marked "62380-H3100"
th_62380-H3100-1.jpg th_62380-H3100-2.jpg th_62380-H3100-4.jpg th_62380-H3100-3.jpg
Emblems
See main article: Badges
CENTER ORNAMENT & TRIM BADGES
22828.jpg 22513.jpg th_GL-Sedan-grille-1972.jpg th_yunakiti-img600x450-1277628693ok47g777311.jpg th_62330-H7225.jpg
Parts List
Customized
