Wiring Harness
Revision as of 06:39, 27 May 2016; view current revision
There are four main wiring harnesses in a Datsun 1200.
The four main harnesses:
  • 24012 Engine Room Harness (includes front light wires)
  • 24013 Instrument Harness (dashboard)
  • 24014 Body Harness: goes from firewall to rear of car, under floor mat
  • 24015 Tail Harness (rear lights)
Generally speaking, the main difference between LHD and RHD harnesses is in the Instrument Harness, with the dash gauges and switches being on opposite sides of the car.
Changes over time include:
* 1972: USA changed to electric choke with relay
* 1974: alternator moved to opposite side of engine
* 1978: Australia changed some connectors to tab-lock
* 1978: Japan changed some connectors to Pin type
* 1989: Feedback Carburetor with ECU
Also see: Wiring Diagrams
Engine Room Harness
Many, many different cables. See Wiring Part Numbers. This harness includes the front lights and transmission wiring.
* Automatic Transmission Kick Down solenoid & Inhibit Switch
* 1974: alternator moved to the opposite side of the engine
* 1976: two-piece harness using a "sub-harness" extension
USA/CANADA 24012
* H1900 1970   MANUAL TRANSMISSION
* H2118 1970   AUTOMATIC TRANSMISSION
* H2108 1971.4 MANUAL
* H2111 1971.6 AUTOMATIC [Auto choke intro]
* H2101 1971.6 MANUAL    [Auto choke intro]
* H2102 1972.1 MANUAL
* H2112 1972.1 AUTOMATIC
* H7001 1972.3 MANUAL
* H7000 1972.7 MANUAL
* H7005 1972.7 AUTOMATIC
Grommet
The engine room harness comes into the cabin a few inches. There is a grommet at the firewall.
24545A GROMMET
24250-89927 TO 8012
06510-00093 8101-8503
01551-00093 8504-8910
06510-00093
Engine Sub-Harness
On newer 1200s, ENGINE ROOM SUB-HARNESS ASSY is the branch that goes down to the transmission. Starting October 1975.
The sub-harness is a small harness that connects to the starter motor, reverse light switch, etc. Connects to Engine Room Harness (engine compartment) via a circular pin connector.
post
Instrument Harness
The dash harness is the same Part Number for Coupe or Sedan. However, rectangle dash differs from round dash (Coupe is always round dash. Sedan may be either). It also varies by year.
Hazards (emergency) Flasher system
* JDM: Hazard system with single Flasher
* USA: Hazard system with separate Hazard Flasher and T/S Flasher
* Export non-USA: No Hazard System (OPTION for later Australia utes)
Variations include:
* Automatic Transmission Kick Down switch on gas pedal
* Automatic Choke and relay
* ACC circuit added to Ignition Switch (radio and heat glass)
* rear Heated Glass wiring
Export
24013-G1270 1980 Australia (reported)
1970-1971
GL and GX have round-gauge dash. All Coupes including DX Coupe have round gauge dash. STD and DX sedan have rectangle-gauge dash.
Deluxe Sedan rectangle gauge dash
Deluxe Coupe round gauge dash
After 71-4
After the April 1971 rationalization, only four harnesses were used:
* STD/DX    [rectangle gauge]
* GL/GX     [round gauge]
* Automatic [round gauge, with kickdown switch plug]
NOT COMPATIBLE with earlier versions
From '71 April
* 24013-H1206 COMP.-CABLE, instrument harness 3-speed, VDT  [rectangle]
* 24013-H1216 COMP.-CABLE, instrument harness 2DA, 4DA      [AUTO rectangle (Sedan Deluxe)]
* 24013-H2206 COMP.-CABLE, instrument harness 2GL, 4GL, GX  [round]
* 24013-H2016 COMP.-CABLE, instrument harness 2GA, 4GA, CGA [AUTO round (Sedan/Coupe GL)]
* Coupe Deluxe Auto?
* Coupe GL?
* Sedan 4-speed?
* 3-speed only available on Std and S-Dx/V-Dx (not available on Coupe)
* GX Automatic - not available
Before April 1971 many harnesses were used: (3,4 or Auto) and (DX/STD vs GL/GX) and "cold option" versions of every one of those.
  • Cold Region (寒冷地向) may have wiring for heater?
  • STD is square gauge, GL/GX is round gauge, DX-Sedan/DX-Van is rectangle, DX-Coupe is round
Full Listing
3-speed, VDT (Van Super-Deluxe 4-speed) [3-speed available only on STD & S-Dx,V-Dx]
24013-H1206 COMP.-CABLE, instrument harness (from '71-Apr.) 3-speed, VDT
24013-H1002 COMP.-CABLE, instrument harness 3-speed, VDT
24013-H1022 COMP.-CABLE, instrument harness (寒冷地向) (op.) 3-speed, VDT
24013-H2206 COMP.-CABLE, instrument harness (from '71-Apr.) 2GL, 4GL, GX
through '71-March
 * 4-speed (exc. VDT, GL, GX)
   24013-H1200 COMP.-CABLE, instrument harness
   24013-H1220 COMP.-CABLE, instrument harness (寒冷地向) (op.)
 * 2GT, 4GT, CG
   24013-H2000 COMP.-CABLE, instrument harness
   24013-H2020 COMP.-CABLE, instrument harness (寒冷地向) (op.)
 * GX
   24013-H2020 COMP.-CABLE, instrument harness GX
Automatic Deluxe Sedan [rectangle gauge]
24013-H1216 COMP.-CABLE, instrument harness (from '71-Apr.) 2DA, 4DA
24013-H1105 COMP.-CABLE, instrument harness 2DA, 4DA
24013-H1125 COMP.-CABLE, instrument harness (寒冷地向) (op.) 2DA, 4DA
Automatic Deluxe Coupe
24013-H1305 COMP.-CABLE, instrument harness CA
24013-H1325 COMP.-CABLE, instrument harness (寒冷地向) (op.) CA
Automatic GL [round gauge]
24013-H2016 COMP.-CABLE, instrument harness (from '71-Apr.) 2GA, 4GA, CGA
24013-H2005 COMP.-CABLE, instrument harness 2GA, 4GA, CGA
24013-H2025 COMP.-CABLE, instrument harness (寒冷地向) (op.) 2GA, 4GA, CGA
1972
1972 moved to all-round gauge, even for STD
Even Van had round gauge for 1972
Truck
See main article: Sunny Truck Wiring
HARNESS ASSY-INSTRUMENT/Instrument Harness Cable 24013
24013-H1002 (up to '73-3)
24013-H1022 (up to '71-3) (op.)
24013-H1206 (up to '71-4)
24013-G1000
24013-G1602 -7803
24013-G1661 7804-8109
24013-G1900 8110-8608
24013-G1901 8608-8910
24013-95W00 8910-
LHD with round-gauge dash.
USA/CANADA 24013
H1905 1970   MANUAL
H2118 1971.4
H2112 1971.7 AUTOMATIC
H7000 1972.7 AUTOMATIC
1972.1 Parts for Seat Belt Warning System
Body Harness
The Body Harness goes from the firewall, under the floor mats to the rear of the car.
Also see Wiring Part Numbers
* 24014-H1011 HARNESS-BODY SEDAN
* 24014-H1811 HARNESS-BODY COUPE
HARNESS ASSY-BODY TRUCK
 24014-G1000
 24014-G1601 7510-8109
 24014-G1900 8110-8608
 24014-G1901 8608-8910
 24014-95W00 8910-
1979 Ute - Yellow arrow points to Body Harness Connector
post
Sedan Trunk - body harness
Late Sunny Truck
full
UTE: Hand Brake Switch wire goes up back wall, then over to the upper grommet
Late Sunny Truck flat wire over to Oxygen Sensor
full
Late Sunny Truck flat wire Connector
full
Branch Cables
* 24029 Fuel Tank Unit Cable
* 24039 Hand Brake Switch Cable
* 24150 Automatic Transmission Indicator Lamp Cable
* 25442 Fusible Link (Type C)
* 24110 Battery Cable (+)
* 24080 Battery Cable (-)
* 24160 Room Lamp Cable (dome light)
* 24100 Fog Lamp Cable (option)
* 24163 Heated Glass Cable D (option) dash switch wiring
  * 24161 Cable A
  * 24162 Cable B
  * 24163 Cable C
