Hitachi D4R Distributor
Revision as of 04:31, 14 July 2016; view current revision
Categories: Distributor | Engine Electrical System | Ignition Modifications
The Hitachi D4R electronic distributors are used by the early E-series engines. These can these be modified to work in A-series engines. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior High-Energy Ignition Unit
Compare to older Exterior Matchbox (Hitachi D4K)
Also see: E-Series Distributor
Hitachi D4R series Electronic Ignition distributors are used by E-series Datsun/Nissan, such as the E15 Pulsar. This can be modified for use in a Datsun 1200. It has a much-improved advance bearing plate, which was the bane of the 1974-1982 D4A points distributor, as well D4F and D4K EI distributors. This new D4R type uses a screw-on cap and improved rotor.
E-series shares basic distributor features with A/J/E/L distributor (shaft diameter & length) but uses an L-series style tang drive instead of A-series gear drive. The hold-downs vary, otherwise the cast body is the same.
One-piece Ignitor & Pickup
Hitachi D4R type dizzy e.g. from N12 Pulsar
* Hitachi E12-61
* Nissan 22020-15M00, 22020-15M20
* NOTE: Hitachi D4N module looks similar
  but has more than two connectors
* BWD CBE507 $110 O'Reilly Auto
* SMP LX515
** Nissan 22020-15M00
** Honda 30120-PA0661, 30120-PH4005
* 12336248
* 30120PA0661
* 30120PH4005
* 491467401
* 8942433440
* 94243344
* E1922
Stator has only two poles (compared to the previous "teethed" stator with 4 poles) but the magnet appears to be stronger.
22163-15W00 STATOR
22136-D4700 PLATE ASSY-BREAKER
22162-15M01 CAP ASSY-DISTRIBUTOR
* 22162-15M02, 22162-15M03, 22162-15M04
22157-H9560 ROTOR-HEAD
Variations
D4R air gaps
D4R80
N10 E15S USA, N12 E16S USA, B11 E15S+E16S
22163-15M00 STATOR [Sheet metal type]
22115-15M00 SIGNAL ROTO ASSY [Reluctor]
22136-21M00, 22136-D4700 PLATE ASSY-BREAKER
22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00 SHAFT ASSY [weight & spring shaft]
22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
D4R82
Appears to be very similar to D4R80.
0882-0588 B11 E15S+E16S USA, 0285-0986 N12 E16S USA
0882-0986 N12 USA
DISTRIBUTOR ASSY
* 22100-32M01,22100-32M01 HITACHI D4R82-24
* 22100-32M03,22100-32M04 HITACHI D4R82-24 W/VENT
* 22100-33M01,22100-33M02 HITACHI D4R82-12
* 22100-33M03,22100-33M04 HITACHI D4R82-12 W/VENT
* 22100-34M01,22100-34M02 HITACHI D4R82-13
* 22100-34M03,22100-34M04 HITACHI D4R82-13 W/VENT
22162-15M02 CAP ASSY-DISTRIBUTOR
22162-15M03 CAP ASSY-DISTRIBUTOR
22162-15M04 CAP ASSY-DISTRIBUTOR
22162-52A01 CAP ASSY-DISTRIBUTOR
22157-03A00 ROTOR-HEAD
22136-D4700 PLATE ASSY-BREAKER [22173]
* 22159-11M00,22159-11M03,22159-11M05,22159-15M00
* HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00, 22108-11M03 SHAFT ASSY [weight & spring shaft]
22132-33M00 CAM SET
22132-33M03 CAM SET
22132-34M00 CAM SET
D4R83
D4R83 is a great Hitachi distributor, used on 1980s Nissans and Hondas. The austin boys swap them into A-series engines too.
D4R83-39
20213.jpg D4R83-36 shaft with no collar
20215.jpg D4R83-30 shaft with collar
20215.jpg D4R83-30 Shaft
20213.jpg D4R83-36 Shaft
20212.jpg D4R83-36 Unit
22100-P4000 D4R83-39 5505
22100-P4000 D4R83-39 4702
4532.jpg 4533.jpg 4534.jpg 4535.jpg 4536.jpg 4537.jpg 4538.jpg 4604.jpg 4605.jpg 4606.jpg 4607.jpg 4608.jpg 4609.jpg
For Hitachi D4R Distributor
** Master Pro 2-4870A
** BWD C708
** Beck/Arnley 174-6861
** ACDelco E303E
CAP & ROTOR KIT
* Bosch 06089
Fits these USA models
** 1982 Datsun 310 (N10) E15
** 1983 Datsun Pulsar (N12) E16
** 1983-1986 Datsun Pulsar NX (KN13) E16
** 1982-1986 Datsun Sentra (B11) E15S,E16
** 1983-1984 Subaru Brat 1800,1800 Turbo
** Master Pro 2-3774
** BWD D575
** BWD D680 "Nascar"
Fits:
* 1976 Accord
* 1975-1975 Civic
* Many Datsun. See B-210_Electronic_Distributor_Swap#Rotor
22132-21M00 CAM SET
D4P
See Hitachi D4P Distributor
Source Vehicles
  • Chevrolet S10/Blazer 1982-1985 1.9/2.0
  • GMC S15/Jimmy 1982-1985 1.9/2.0
  • Honda 1980-1990
  • Isuzu 1986-1995
  • Nissan 1983-1987 E-series, CA16DE
  • Subaru 1981-1989
  • 22100-24B01 JDM Nissan March K10 with MA10S.AT (PK10) 8901-
    • Looks similar to E-series dizzy and engine. PLASMA is 1.0 liter range
Subaru uses same part code as Nissan (22100 for distributor) as stamped on the distributor body.
Isuzu D4R uses a different case hold-down
Unknown
This looks like D4R electronic distributor. It was found in Australia:
This has the one-piece ignitor & pickup (Nissan 22020-15M00/22020-15M20)
Advance Bearing Plate
It has a simplified design compared to the earlier D4 distributors. The plastic bearing race contains 4 ball-bearings (up from 3) and slightly beefier design.
The bottom race is similar to the older Hitachi, but slightly smaller.
th_20120530224458DSC01938.jpg th_20120530224507DSC01939.jpg th_20120530224516DSC01940.jpg th_20120530224516DSC01940.jpg th_20120530224528DSC01941.jpg
th_20120530224118DSC01933.jpg th_20120530224126DSC01934.jpg th_20120530224155DSC01936.jpg
