Nissan Gasket Kits
10101 full engine gasket kit contains head set + other engine gaskets
11042 Head Set (valve regrind set) every thing needed to change a head
11044 cylinder head gasket
[edit]
10101
GASKET KIT-ENGINE REPAIR * 10101-H1027 GASKET KIT-engine [1970-1973 A12] $208 USD![]()
10101 includes:
Head Set (REGRIND) Gasket Kit * Head gasket * Valve Cover gasket * Thermostat gasket * Valve Seals * Manifold Gasket Intake/Exhaust Manifold gasket * EGR gaskets
Other Seals Included in Engine Kit * Timing Cover gaskets & Seals * Fuel Pump gaskets * Oil Pump gaskets * Distributor O-ring * Crankshaft seals * Water pump gasket * Oil pan gaskets
[edit]
Aftermarket
Your local auto parts store carries non-Nissan gasket sets of various manufacture.
Or, buy at RockAuto.com
DJM FGS6004 comes with wet and dry manifold gasketsITM 09-00526.jpg comes with round-port and oval-port gaskets
[edit]
11042
A15 North America Head Set (B310) 11042-H9527 KIT-VALVE REGRIND A14,A15(CAN) - 2 11042-H9526 11042-H9526 KIT-VALVE REGRIND A14,A15(CAN) 0880- 2 11042-H7226 11042-H7226 KIT-VALVE REGRIND A14,A15(CAN) 0879-0780 0 11042-H8927 KIT-VALVE REGRIND A14,A15(USA) - 2 11042-H9826 11042-H9826 KIT-VALVE REGRIND A14,A15(USA) 0880- 0 11042-M6726 11042-H9527 KIT-VALVE REGRIND A14,A15(CAN) - 2 11042-H9526 11042-H9527 KIT-VALVE REGRIND A14,A15 CAL A14 FED(KFU) A14 CAN -0779 2 11042-H9526 11042-H8927 KIT-VALVE REGRIND A14,A15(USA) 2 11042-H9826 11042-H9527 KIT-VALVE REGRIND A14,A15 CAL A14 FED(KFU) A14 CAN -0779 2 11042-H9526 11042-H7227 KIT-VALVE REGRIND A14,A15 FED (EXC KFU) -0779 2 11042-H7225 11042-H7227 KIT-VALVE REGRIND A14,A15 FED (EXC KFU) -0779 2 11042-H7225
[edit]
11044
B310 North America Catalog 11044-H9821 GASKET-CYLINDER HEAD A14,A15 0880- 2 11044-H9802 11044-H9820 GASKET-CYLINDER HEAD A14,A15 0880- 0 11044-H7201 11044-H7201 GASKET-CYLINDER HEAD A14,A15 -0780 0 13270-H1000 PACKING-ROCKER COVER A14,A15 11132-H5025 GASKET SET-OIL PAN A12A,A14,A15 13044-H1000 GASKET-TIMING CHAIN COVER A14,A15
