Grille
Revision as of 23:29, 23 December 2016; view current revision
Category: Body
Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grille changed for 1972.
#Stainless Grille: Sedan, Wagon & 1971-1978 ute
#Facelift Grille (1972 JDM Sedan & South Africa sedans)
#Coupe Grille (black headlight surrounds)
#1978-1989 Ute Grille (silver headlight surrounds)
#Late Sunny Truck/Bakkie Grille (1989-2007)
#Sunny Excellent Grille
Stainless Grille
Early sedan grille
20857.jpgAlbum 20857
See Main Article: Sedan Grille
Sedan grille "D" and "S" emblems
917.jpgAlbum click to view 6001.jpgAlbum click to view
Facelift Grille
Late sedan grille
Late JDM grille + intricate "S" grille emblem
457.jpgAlbum click to view 752.jpgAlbum 752
Plastic Grilles
20861.jpgAlbum 20861
1. Silver headlamp surrounds (#mid-model ute)
2. Black headlamp surrounds (#coupe GX)
3. With Silver center strip (#coupe non-GX)
Black headlight surrounds: (#coupe)
1741.jpgAlbum 1741
Silver headlight surrounds: Mid #Pickup (1978-1989)
Emblems: Rectangular for pickup, Round for coupe
26382.jpgAlbum 26382
Coupe Grille
See Main Article: Coupe_Grille
GX Coupe | DX/GL Coupe
8580.jpgAlbum 8580 3918.jpgAlbum 3918
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck/ute/bakkie used the stainless Sedan Grille.
15804.jpgAlbum 15804 736.jpgAlbum 736
Mid-Model Truck
1978-up Truck/ute/bakkie. This grille looks nearly identical to the Coupe grille:
  • Silver headlight surrounds (coupe has black surrounds)
  • Rectangular center emblem (Coupe is round)
  • Emblem screws have horizontal arrangement (Coupe is diagonal)
Coupe or Ute grille accepts both emblems
Coupe emblem - screws arranged diagonally
Pickup emblem - screws arranged (nearly) horizontally
385.jpgAlbum 385
To fit a Plastic grille to an early ute or sedan, add these tabs:
21713.jpgAlbum 21713
Square Headlight Truck
See Main Article: Square Light Grille
From October 1989
* JDM Sunny Truck (late B122)
* South Africa bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Coupe
Coupe continued to use the original grille during the 1972 facelift.
Sedan
See Main Article: Sedan Grille, Facelift
Customized Grilles
Blackout center ornament
24625.jpgAlbum click to view
120Y grille
174_55ea1becdb6be.jpgPost 471955
four-eye
10528.jpgAlbum 10528
Chrome highlights
26395.jpgAlbum 26395
FRP
20646.jpgAlbum 20646
Kustom grille
11725.jpgAlbum 11725
Color Matched
2099.jpgAlbum 2099 2100.jpgAlbum 2100
JDM look
Coupe-grille with custom insert
5859.jpgAlbum 5859 6761.jpgAlbum 6761 7497.jpgAlbum 7497 16539.jpgAlbum 16539 9956.jpgAlbum 9956 9955.jpgAlbum 9955 grille.jpg
Flush
2843.jpgAlbum 2843 7061.jpgAlbum 7061
Datrotor: Made up my own mirror finish stainless grill that deffenetly is a 1off.every single bolt that isn't hi tensile has been mirror polished finish and is all stainless
D24072E4-2A90-459A-B283-0524CDAE5C9B-2750-0000029234EC224E.jpgPost click for topic D7822A8C-D64F-42CF-9EAA-5F02EE2BF7FF-2750-00000291C170DCDC.jpgPost click for topic 3bcf07cd.jpg
Blackout Grille
Coupe/Ute grille painted black
3972.jpgAlbum 3972 15846.jpgAlbum 15846 22270.jpgAlbum 22270
Square Eye Retrofit
rectangular headlights - dual or quad
Billet
Aluminum Slat
174_549787fb031b9.jpgPost 461992
174_54978870025dd.jpgPost 461992 26394.jpgAlbum click to view 174_54978883e992b.jpgPost 461992
GDM Style
Mercedes
8584.jpgAlbum 8584
BMW
VW Caddy look (see post for more pics)
174_56d798f9ac013.jpgPost 476836 5668.jpgAlbum 5668
Bimmer E30 datsunb120
fgjfgj435.jpgPost click for topic 103_0143.jpgPost click for topic
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
24815.jpgAlbum 24815 24814.jpgAlbum 24814
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
18436.jpgAlbum 18436
See:
* Sedan Grille Mounting
  19558.jpgAlbum click to view
* Coupe Grille Mounting
  19571.jpgAlbum click to view
* Coupe Grille in Sedan: add the missing brackets.
* Sedan Grille in late Sunny Truck
* Coupe Grille in late Sunny Truck
  20859.jpgAlbum click to view
For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Dimensions
Coupe/Mid-ute/Late-ute
* 123 x 22 x 10 cm box
Sedan/Early-ute
TBD
PB110
PB110 Sunny Excellent Grille
PB110 Custom
PB110 sedan retrofitted with chromed B110 Coupe grille. The chrome matches nicely with the PB110 corner lights
U00017593481_10_001.jpg U00017593481_18_001.jpg U00017593481_1_001.jpg U00017593481_16_001.jpg
See Main Article: Grille Photo Index
keywords: グリル
