Speedometer Cable
Revision as of 01:26, 8 October 2017; view current revision
A flexible-shaft cable attaches the Speedometer to the driven gear at the rear housing of the transmission.
19291.jpgAlbum 19291
B110
25050 SHAFT ASSY-FLEXIBLE, SPEEDOMETER
JAPAN
* 25050-H1000 L=1500
* 25050-H1001 L=1400mm
* 25050-G1600 8108-8910 > 25050-H1001
* 25050-95W00 8910-
USA - manual or automatic
* 25050-H1602 ASSY-SHAFT FLEXIBLE L=1700
1700mm
Rockauto.com $7.76
ATP Y885 $7.62
B10
25058-89914 ASS'Y-SHAFT, flexible M/T
25058-89915 ASS'Y-SHAFT, flexible Automatic
25050-H5000 ASS'Y-SHAFT, flexible Length=1700 A12
* B5050-Y8101 supercedes 25050-H5000 $51.22
25050-H5900 ASS'Y-SHAFT Length=1650 w/Master Vac NLA
25050-H7403 ASS'Y-SHAFT 63-series trans
25050-H7410 ASS'Y-SHAFT A14 automatic
25050-H7411 ASS'Y-SHAFT A12 late
B310
* NOT compatible with B110/B210
Cable Breaks
The speedometer cable usually lasts forever. There are two common reasons why it will break:
  1. Mechanical kink or breakage, for example if you drive over a tree branch and it pulls the cable
  2. Bad or missing engine ground wire.
Additional reasons
* Lack of grease
* Break in cable allows water which freezes in winter
17711.jpgAlbum 17711
I think you'll find this is caused by poor/dirty ground strap from the engine to the body inside the engine bay.
It only takes once, and the cable it screwed, as it melts the nice polyethylene coating on the inside.
See how the cable's protective plastic appear worn..I'd say it melted during starter crank. Then when the cable gets some speed up, the plastic grabs and the cable snaps.
Swap Cables
All 56-series (4-speed or 5-speed) use the same cable.
For 60-series (4-speed or 5-speed), the speedo driven gear is slightly further back on the transmission. Some stock 1200 cables will work, but not all (depending on length).
22337.jpgAlbum 22337 1674.jpgAlbum 1674
For 63-series transmission a longer cable is required.
14289.jpgAlbum 14289
For 63-series gearbox, use a 610/710/810 cable, or a B210 cable.
NOTE: The B310 featured a clip-on cable instead of screw-on to the speedometer head. So the B310 cable will not interchange with the 1200 speedometer.
NOT interchangeable
910 1980- 810/Bluebird
A10 Stanza/510
B310 Sunny/210 78-90cm
Comparison:
24189.jpgAlbum 24189
The 810 cable (1977-1979 810/200B) is of the same type as a 1200 but longer (about 1950mm).
