Datsun 1200 has a service brake system with the handle conveniently located between the two front seats. Also known as "emergency brake" or "hand brake" (the primary brakes are called the "service brakes").
Handbrake cover is called by Nissan the "parking brake lever COVER".
36310 Hand Brake Lever Assembly (comes in black, brown and grey)
36400 rear cable (complete set)
UTE: Parking Brake Cable goes out the back wall
Hand Brake Cover
B210 cover also fits.
Top: replacement part, same as B210 | Bottom: original B110 design
ブレーキカバー
Cable Routing
Front half is same for all 1200
Ute - cable come out the cab lower rear panel
Dash-top Indicator Lamp
Some utes had a PARK BRAKE lamp on top of the dash that lit up when the handbrake was activated and IGN was ON.
Light Switch
See main article: Brake Wiring#Hand Brake Switch
Also see: Hand Brake Part Numbers
- 74965-H7300 BOOTS-HAND BRAKE [Large style]
- 74965-G1060 B120 7804-8910 [Brown]
- 36011-89901 SWITCH-HAND BRAKE USA
- 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
- Also fits B210 USA
- Also fits B210 JAPAN from '75-4
Aftermarket Cable
- 48-1/4" Overall Length, 2 Per Car
- RAYBESTOS BC92888 $39.79
- ACDELCO 18P154, 18033072 $48.79
