<-- Back to: Lighting System
Fog Lights were an Option.
B110
Factory Fog Lamps options for the B110 1200 include
- #H1010 Rectangular yellow
- #H1012 Rectangular
- H1014 Round 126mm diameter
- H1016 Round 122mm diameter
- H1018 Round 160mm diameter
- #257 Round 160mm diameter yellow
26150-H1010
Type 265 designed for 1969 510 Coupe.L16
The H10 housing is unique to the Datsun 1200. The lens and rim comes from the 510 SSS.
Appears to be same as #H1012 except for color
H1010 White Bulb Yellow Lens H1012 Yellow Bulb Clear Lens
26151-H1012
Stud-mount type with 'S' icon embossed in the glass
Switch
25160-H1010 ASS'Y-SWITCH, lighting ALL (except GL) 25160-H1110 ASS'Y-SWITCH, lighting GL * 1200 GL * 1400 (PB110) 24100-H1000 ASS'Y-CABLE, fog lamp
PB110
Datsun Sunny 1400 had the fog lamps built into the grille.
Aftermarket/Custom
Unknown -- found on 1200 with facelift grille
Datsun 1000
B10 Fog Lamp LENS 160mm
B10 * 89901 Ichikawa 35W (op.) ALL * 18001 Ichikawa 35W (op.) ALL * 18010 Koito sealed beam (op.) ALL * 257 Koito 55W 160mm (op.) Coupe * KB10#Sports Options iodine(沃素) * KB10#Sports Options small
Ichiko 市光 Ichikawa 市川 Koito 小糸
26151-25710
(optional) Coupe KB10 10 26150-25710 ASS'Y-LAMP, fog with bracket (小糸 Koito) (2) 26750-89900 BULB 12V-55W (2) 26151-25710 LENS (2) 26152-25710 RIM (2)
Fog Lamps 26151-25710 LENS 160mm KOITO
Datsun B210
Fog Lamps for B210 Grille
EARLY -1975 * ROUND 26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526 * RECTANGLE S,V OPTION 26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026 25160-H6001 SWITCH COMP.-lighting with fog
LATE 1976- LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens) * top bolt centered 25160-H5827 PB210 GX (op.)DX,GL > 25160-H5825 <> 26150-H5826 * top bolt offset 26150-H7525 S.A14.GX *S.A12,A14-GX *V 26150-H7526 K.A14.GX *K.DX,GL-L16 26150-H7925 L16.GX *L16.GL 26150-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA] 26150-H7428 *K F/OKINAWA 26150-H7926 *L16 F/OKINAWA
25160-H6001 SWITCH ASSY-LIGHTING W/FOG 25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI 25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
H79 L16-powered (B211)
B310
Round headlight B310 Grille only.
LAMP KIT-FOG IKI 26150-H8525 A12 26150-H8925 A14
25370-H8500 SWITCH ASSY-FOG LAMP 25375-S0100 KNOB-FOG LAMP SWITCH
LAMP ASSY-FOG RH 26150-H8500 * #S,K.A12S -7909 * #V.A12 26150-H8900 * K.GX #S.GX #W #DX,GL -7909 * #V.A14
'NISSAN' lamps with adjuster - A14 grille
Aftermarket fog lamps fitted - Strap-fastened to the grille
(SEV MARCHAL 750 759)
フォグ ランプ
