<-- Back to Wheels (includes 1200 & Sunny wheels)
R30 Rims
15 X 6 Skyline#R30 wheels, 20-spoke hurricane-type. #R31 Skyline was 24-spoke
R31 Skyline
R31 Skyline spare steel wheels
"Pursuit/chaser" style wheel may be used on Datsun 1200.
R32 Skyline
5-lug
8" wide, fit with PCD adapters?
R32 GTS wheels 16 x 6.5 with 205/40R16
GTS 18 x 8.5 front, 18 x 9.5 rear
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims. Looks like Bridgestone#Zona Special Antares.
SSS wheels reportedly not fit 1200 without spacers.
C22
USA C22 40300-V6104 5.5-JJX14 +40 <> 40300-V6120 40300-V8000 SPARE <> 40300-V8077 [8-hole steel] 40300-17C25 AL [turbine]
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
810
Datsun 810 Bluebird/810/200B/180B
14" styled steel wheel | 13" 8-slot steelie
C-type 13" (also used by S10) & E-type 14"
A-type 5.5x14 40300-R4625 with nut set KOHBE <> 40300-U9625 40300-R4626 with locking nut set KOHBE <> 40300-U9626 40300-R4671 40300-U8925 A-type 14" (export option)
A-type
Datsun 810 factory OPTION B & OPTION C wheels: 13" x 5"
B-type 6-spoke
40300-U7527 B-type 5Jx13
40300-U7528 B-type 5Jx13 locking
C-type 8-slot
40300-W6027 C-type 5Jx13
40300-W6028 C-type 5Jx13 locking
B-type
Australia 200B Aspen GL (optional GX) 14x6 (20-spoke)
E-type 32-spoke SSS, LN 5.5JJx14 40300-S0625 with nuts 40300-S0626 locking nut
910
AUS/JAP Bluebird
14" steel 8-slot/8-square hole
USA 910 "Datsun 810" and "Maxima" 40300-N8810 40300-N8870 <1> 40300-N8804 40300-W1000 40300-W1004 <5> 40300-W1014 40300-W1070 <5> 40300-W1004 40300-W2426 40300-W2428
40300-W2426
U11
1985-1988 U11 Maxima used 15x6 +40 wheels -- same dimensions as #S13 wheels. They use the Datsun bolt pattern 4-on-4.5" (114.3mm). Can be used on 1200s by utilizing wheel spacers. 1987-1988 came with 15x6+40 wheels in 4-lug and 5-lug versions.
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
Pulsar
Nissan Pulsar/Cherry/Langley, FWD small car.
N12
Pulsar N12 4.5x13 FC/FL/SSS/GF (Prince Liberta Villa, sold by Nissan Bluebird Shop)
?40315-01M20 WHEEL DISC ORNAMENT
Pulsar N12 5Jx13 Alumi 40300-01M25/40300-01M26/40300-01M28/40300-01M85/40300-01M86/40300-01M88 40300-01M70/40300-01M76
N12 ET
The Pulsar ET was the sedan/multiback version of the N12 Turbo, and came with the legendary E15ET engine. (The coupe version was the EXA, or NX in USA)
EXA
The EXA was the coupe/sporty version of the Pulsar Turbo, and the N13 EXA came with the legendary CA16DE or CA18DE engine. Badged "Pulsar NX" in USA (SE with CA, XE with E15/G16).
For 24-spoke, see Cheviot Classic 13x5.5
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
8-hole aero fan
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30 slanted 8 slot 15 x 6.5 +25 4 on 4-1/2 bolt circle Pilot hole diameter 66 mm 23 lbs left & right wheels
F31 Japan 8602-8808 14x5.5+30 7-slot styled steel 40300-58L05 8602-8702 VG20 [F31,C32] 40300-58L07 8702-8808 VG20 [F31,C32] 15x6+30 10-slot styled steel 40300-59S00 8602-8702 V20T.XS [F31,C32,R31] 40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31] 8808-9805 VG20E *(VG20DT+VG30#) 40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31] 8602-8808 spare steel 4x15 4-slot VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15 VG30.ULTIMA 40300-59S15 8602-8808 ALL 40300-59S15 8808- 8602-8603- alloy 8-slant/spoke 6.5x15 40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E 40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E 40300-F6627 LH <> 40300-F6225 40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS) 40300-F6527 LH
Spare Tire
15x4T+40 40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15 * C23 Vanette * M10/M11 Prairie * S12/S13/RS13 Silvia * W10 Avenir * T12/T12Y Violet/Stanza/Bluebird * A31 Cefiro * F31 Leopard * R31/R32 Skyline * C32/C33 Laurel * P10/P10E Primera * U11/U12/U13 Bluebird
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15 * B15 * C23 * K30S * P11/P11E * R33 * RS13/S14 * U14 * W10/WP11 * C34 * U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS 40300-N8810 4TX16 SPARE 40300-N8900 5JX14 0179-0783 40300-N8910 5JX14 0781-1081 40300-N8427 5.5JJX14 AL [16-spoke] 40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25] 40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]
40300-S6027 32-spoke hurricane
S13
?40300-15U28 15X6JJ silver Hitachi [K504]
* RS13 Type-X 9505- option
* R33 some
* S14 option K.2WS.QS
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole USA * Base: 195/60R15 * SE: 205/60R15
10-hole Spare 15" x 4", 4 Lug, 4.5" Bolt Pattern http://i297.photobucket.com/albums/mm219/ddgonzal/Datsun%201200/wiki/th_nissan-240sx-wheels-62253.jpg
40300-50F26 silver top 15x6JJ+40 7-star * RS13 (S13 Hatchback/180SX) * A31 aero type silver * C33 * R32 including V Selection 2 and 60th Anniversary
Z-car Rims
Datsun S30 "Fairlady Z" or 240Z/260Z/280Z Datsun S130 "Fairlady Z" or 280ZX
