Fog Lamps
Revision as of 07:57, 29 September 2021; view current revision
Category: Lighting System
<-- Back to: Lighting System
Fog Lights were an Option.
B110
Factory Fog Lamps options for the B110 1200 include
  • #H1010 Rectangular yellow
  • #H1012 Rectangular
  • H1014 Round 126mm diameter
  • H1016 Round 122mm diameter
  • H1018 Round 160mm diameter
  • #257 Round 160mm diameter yellow
20634.jpgAlbum 20634 27847.pngAlbum 27847
b1101971companybrochure1.jpgbrochure b110071.jpgbrochure sunny1200_catalog_p2021.jpgbrochure img_254596_7869102_5x.jpgbrochure
26150-H1010
Type 265     designed for 1969 510 Coupe.L16
The H10 housing is unique to the Datsun 1200. The lens and rim comes from the 510 SSS.
Appears to be same as #H1012 except for color
H1010 White Bulb   Yellow Lens
H1012 Yellow Bulb  Clear Lens
26151-H1012
Stud-mount type with 'S' icon embossed in the glass
174_611c2c2b43092.jpgPost 495730 174_611c2c76bba60.jpgPost 495730 174_611c2c8582e6e.jpgPost 495730 174_611c2c91079b8.jpgPost 495730
174_611c2c176f781.jpgPost 495730
Switch
25160-H1010 ASS'Y-SWITCH, lighting ALL (except GL)
25160-H1110 ASS'Y-SWITCH, lighting GL
* 1200 GL
* 1400 (PB110)
24100-H1000 ASS'Y-CABLE, fog lamp
B120
Datsun New Zealand dealer-installed OPTION driving lamps — Cibie 10DE
28049.jpgAlbum 28049 28051.jpgAlbum 28051
PB110
Datsun Sunny 1400 had the fog lamps built into the grille.
Aftermarket/Custom
11676.jpgAlbum 11676 21151.jpgAlbum 21151 21496.jpgAlbum 21496 48.JPGAlbum 48
Unknown -- found on 1200 with facelift grille
4124.jpgAlbum 4124 19867.jpgAlbum 19867
Datsun 1000
B10 Fog Lamp LENS 160mm
B10
* 89901 Ichikawa 35W (op.) ALL
* 18001 Ichikawa 35W (op.) ALL
* 18010 Koito sealed beam (op.) ALL
* 257 Koito 55W 160mm (op.) Coupe
* KB10#Sports Options iodine(沃素)
* KB10#Sports Options small
Ichiko 市光
Ichikawa 市川
Koito 小糸
26151-25710
174_611b7483beb32.jpgPost 20709
(optional) Coupe KB10
10 26150-25710 ASS'Y-LAMP, fog with bracket (小糸 Koito) (2)
   26750-89900 BULB 12V-55W (2)
   26151-25710 LENS (2)
   26152-25710 RIM (2)
Fog Lamps 26151-25710 LENS 160mm KOITO
20709.jpgAlbum 20709
Adjustable pivot
174_611b60c8cb31d.pngPost 495728
Datsun B210
Fog Lamps for B210 Grille
EARLY -1975
* ROUND
  26150-H5527 K-GX K-DX,K-GL OPTION > 26150-H5525 <> 26150-H5526
* RECTANGLE S,V OPTION
  26150-H5027 LAMP KIT-fog > 26150-H5025 <> 26150-H5026
25160-H6001 SWITCH COMP.-lighting with fog
LATE 1976-
LAMP KIT-FOG 30W bulbs (3-bolt type, sloping lens)
* top bolt centered
  25160-H5827 PB210 GX (op.)DX,GL > 25160-H5825 <> 26150-H5826
* top bolt offset
  26150-H7525 S.A14.GX *S.A12,A14-GX *V
  26150-H7526 K.A14.GX *K.DX,GL-L16
  26150-H7925 L16.GX *L16.GL
  26150-H7427 *S,V F/OKINAWA [lens differs from non-OKINAWA]
  26150-H7428 *K F/OKINAWA
  26150-H7926 *L16 F/OKINAWA
25160-H6001 SWITCH ASSY-LIGHTING W/FOG
25160-H5201 SWITCH ASSY-LIGHTING W/FOG&ILLUMI
25160-H5800 SWITCH COMP.-lighting with fog PB210 GX (op.)DX,GL
H55 Early Coupe
11320_4a64275c3fdc9.jpgUpload click to view
H58 PB210
737_54c21bb7b86e4.jpgPost 463127 19067.jpgAlbum 19067
Late Sedan (B211)
14242.jpgAlbum 14242 13864.jpgAlbum 13864 B211fl.jpg 17237.jpgAlbum 17237
Late Coupe (B211)
10994_4aefbc82e6507.jpgUpload click to view
H79 L16-powered (B211)
B110-style fog lamps on B210
24058.jpgAlbum 24058 4229.jpgAlbum 4229
B310
Round headlight B310 Grille only.
LAMP KIT-FOG IKI
26150-H8525 A12
26150-H8925 A14
25370-H8500 SWITCH ASSY-FOG LAMP
25375-S0100 KNOB-FOG LAMP SWITCH
LAMP ASSY-FOG RH
26150-H8500
* #S,K.A12S -7909
* #V.A12
26150-H8900
* K.GX #S.GX #W #DX,GL -7909
* #V.A14
A12
grille.jpg 174_58882cd75cc3f.jpgPost 483450
A14
'S' lamps - A12 grille
20639.jpgAlbum 20639 20640.jpgAlbum 20640
'NISSAN' lamps with adjuster - A14 grille
Aftermarket fog lamps fitted - Strap-fastened to the grille
174_588972636b78d.jpgPost 483480 174_588972bc0de34.jpgPost 483480
(SEV MARCHAL 750 759)
174_588972af27399.jpgPost 483480
フォグ ランプ
