Datsun 1200s had optional AM and AM/FM radios. Original Equipment Manufacturers (OEMs) included Clarion, Hitachi, and Ferrisᴳ.
Operation
1972 USA Owners manual (Page 20 ... 20):
The radio has five push buttons
Radio Instruction Card
Here's a radio instruction card, for the Hitach AM radio:
Radio Delete Plate
Perhaps most 1200s came without a radio and were factory-fitted with a delete plate.
Factory Options
- Monoraul AM, single speaker
- Mono AM/FM, with single speaker
- Stereo AM/FM, with dual speakers
Stock AM Radio, Ferris - Datsun (Australia)
Stock AM Radio, Hitachi - Datsun (USA, 1972)
Stock AM Radio, Philips - Datsun (Australia)
Stock AM/FM Radio, Clarion (JDM, 1972)
Stock AM/FM Radio, Hitachi (USA)
Speakers
Modern 2-Shaft Receiver
A few companies still offer a Shaft-style audio receiver in a modern design, with USB and flash card memory playing MP3 and WMA, etc.
Example 2016 August Pyle In-Dash AM/FM-MPX MP3 Shaft Style Dual Knob Radio * with USB/SD Card * $45 Amazon.com![]()
For a few hundred you can get a decent retro fit style radio made by Retrosound that has positionable shafts. http://www.retrosoundusa.com
Antenna
Stock 1200 aerial mounts along the A-pillar and is manually collapsible/extendable.
The antenna is listed in the B110 factory parts catalog as "radio with antenna", but for the B210 the antenna was seperately listed as part 27962-H5000. It appears to be similar.
510/B110/B210, compatable with both left & right hand drive vehicles. This replacement (aftermarket unit) mast extends to 126cm & the cable length is 127cm.
Slightly different is: S10 200SX, F10, 310, 620, 210. Pillar mount. Extends to 42-55". Cable lengh 49-51".
Aftermarket upright antenna on a 1000
There are just three wires:
- Speaker drive -
- Speaker drive +
- ACC (power)
ACC on the Ignition Switch feeds the Radio:
Newer 1200s can use this connector, still with the same basic wiring:
Datsun B310 used this connector, still with three-wire setup:
The ones marked '?' are not used (no connection)
Mounting
* Factory location * Console or glovebox mounting * DIN chassis * Modern 2-shaft head units
Cassette Stereo
From 1976 GB211 sedan -- Hitachi CS-220N option
Aux Input Radio
Late 70s/early 80s Datsun AM/FM radios have an Auxiliary input. These style radios debuted 1977 and came in S10 200SX/Silvia, B11 Sentra/Sunny, N12 Pulsar, A10 510/Stanza's & the P910 Maxima/Bluebirds.
It has a DIN connector, the round 5-pin type. The 5P DIN was originally used as a connection for factory option external tape decks. Today it allows you to play portable CD players or iPods throught the car stereo.
5-pin DIN connector 1: No Connection (n/c) 2: AUX signal ground 3: Radio power (center pin) 4: AUX Right signal input 5: AUX Left signal input
- Get a standard 3.5 mm jack/cable from a set of earphones or such. One of your friends probably has one from a cell phone that they've never used.
- Cut off the earbuds
- Connect the three wires to a length of 5 pin DIN cable which has a male connector
- Get a 2-way switch to toggle power between inputs (radio or aux)
- Disconnect the radio power wire from the dash harness
- Connect the radio power in the harness to the 2-way switch input
- Wire one of the 2-way switch outputs back to the Radio power (the cut wire)
- Wire the other 2-way switch output to the DIN Pin #3
- Plug the male DIN cable end into the radio
- Plug the 3.5mm jack into CD or Ipod or other device
Flip the switch to toggle between Radio and Deck (auxiliary) inputs.
NOTE: It may come out a bit louder through the AUX input than expected — depending on the volume level of the device. Just be prepared to expect this.
The best thing is, if you couple it with an amp that has high level input, you can keep it looking completly stock but with decent quality audio. Modern tunes for free!
Clarion RN-454M
circa 1984 factory Datsun North America
Europe
UKW/MW Band Radio (Western Europe)
B110
1970-1971 DX, GL, GX * 27900-H1105 KIT-RADIO, with antenna (帝国電波) ** Radio Empire changed name to Clarion December 1970 ** supercedes 27900-H1105
27900-H1112 KIT-RADIO, with antenna (日立 [Hitachi])
STD * 68470-H1000 MASK-radio (sunny mark) 1970-1971 * 68470-H3100 MASK-radio 1972 ** 08915-43510 WASHER-plain (2) ** 08915-53610 WASHER-plain (2) ** 08911-10510 NUT (2) * 27978-H1000 PLUG-RUBBER 3.6 (2) ** antenna bolt holes - A-pillar * 27979-H1000 PLUG-RUBBER 12 ** antenna cable hole - A-pillar
1972 (op.) STD * 27900-H3200 RADIO-KIT-with antenna (CLARION) * 27900-H3211 RADIO-KIT-with antenna (HITACHI) * 27900-H3213 RADIO-KIT-with antenna (HITACHI) from '72-1
1972 (op.) ALL
* 27900-H3320 RADIO-KIT-with antenna (AM-FM) (CLARION)
B120
B120 Options catalog C-288 1974
- 27900-H1105 Radio Kit-with antenna (CLARION)
- 27900-H1112 Radio Kit-with antenna (HITACHI)
- 27900-G1010
B120
- 27900-H1105 RADIO KIT-with antenna (Radio Empire) DX, (op.) STD
- 27900-G1011 RADIO KIT-with antenna (Hitachi) DX, (op.) STD
- 27900-G1010 RADIO KIT-with antenna (Hitachi)
- replaced 27900-H1112 RADIO KIT-with antenna
- 68470-H1000 MASK-radio STD
- 08915-53610 WASHER-plain 2
- 08911-10510 NUT 2
- 27978-H1000 PLUG-rubber (3.6ø) 2 STD [plug for a-pillar, antenna]
- 27979-H1000 PLUG-rubber (12ø) 1 STD [plug for a-pillar, antenna]
- 27900-G1101 RADIO KIT HITACHI A608 7510-7803
- 27900-G1060 RADIO KIT HITACHI A608 7804-8109
- Hitachi Model No. TM-411G
- 28001-G1660 RADIO KIT HITACHI A608 8110-8503
Clarion RN 1006M
Datsun Accessory Kits
- Datsun 99993-00105 8 TRACK CAR STEREO WITH AM RADIO
- includes Hitachi CST-113BA 8 TRACK CAR STEREO PLAYER WITH RADIO [AM]
- Datsun 99993-00008 FM MPX CARTRIDGE TUNER
- includes Hitachi KP-1000NE FM STEREO TUNER PACK [FM tuner fits into 8-track slot]
Nissan Accessory Kits
- 99993-00132 Hitachi AM/FM Radio model A-1681
- 99993-00119 Hitachi AM/FM Radio model A-1581
B110
- 27900-H1110 KIT-RADIO WITH ANTENNA (HITACHI) OP
- 27900-H1105 KIT-RADIO WITH ANTENNA (CLARION) OP
- supercedes 27363-18200
- 27900-H1102 KIT-RADIO WITH ANTENNA (CLARION) OP
- 27962-H1110 ASSY-ANTENNA OP
- 27962-H1100 ASSY-ANTENNA OP
- Same as Datsun 620 pickup
- 27984-H5001 CONDENSER-TYPE B OP
- supercedes 27984-89900
- 68470-H1100 MASK-RADIO DATSUN MARK
- 27978-H1000 PLUG-RUBBER 3.6 diameter (2)
- 27979-H1000 PLUG-RUBBER 12 diameter
- 27910-H7225 KIT-RADIO AM (CLARION) OP 0875- 27910-H6225
- 27910-H6226 KIT-RADIO AM FM MONO. (CLARION) OP 0774-0775
- 27910-H7226 KIT-RADIO AM FM MONO. (CLARION) OP 0875- 27910-H6226
- 27910-H6228 KIT-RADIO AM FM MULTI. (CLARION) OP 0774-0775
- 27910-H7227 KIT-RADIO AM FM MULTI. (CLARION) OP 0875- 27910-H6228
- 27910-H6225 KIT-RADIO MW (CLARION) OP -
- 27910-H6100 SET RADIO RECEIVER MW (CLARION) OP -
- 27910-H6205 SET RADIO RECEIVER AM FM MONO (CLARIO OP 0774-
- 27910-H6210 SET RADIO RECEIVER AM FM MULTI (CLARI OP 0774-
- 27924-H6100 ESCUTCHEON-RADIO OP -
- 27923-H5025 SET-KNOB WITH WASHER & NUT OP 0774-
- 27923-H5025 SET-KNOB WITH WASHER & NUT AM FM MULTI OP 0774-
- X3803-43700 KNOB-INNER MW (CLARION) OP -
- X3803-43800 KNOB-OUTER MW (CLARION) OP -
- 27962-H6100 ASSY-ANTENNA (CLARION) OP -176
- 27962-H6101 ASSY-ANTENNA (CLARION) OP 0276- 27962-H6100
- 27962-H6110 ASSY-ANTENNA (HITACHI) OP -
- 27962-H6111 ASSY-ANTENNA (HITACHI) OP 0476- 27962-H6110
- 27984-H5000 CONDENCER TYPE B OP -
- 27984-H5001 CONDENCER TYPE B OP - 27984-H5000
- 27933-H5010 ASSY-SPEAKER MW (HITACHI) OP -
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0774-0775
- 27933-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) OP 0875-
- 29440-H5001 ASSY-SPEAKER AM FM MULTI. (CLARION) RE OP 0875-
- 27933-H5001 ASSY-SPEAKER MW (CLARION) OP -
- 68470-H5000 MASK-RADIO -
- 27978-H1000 PLUG-RUBBER -
- 27979-H1000 PLUG-RUBBER -
- 27979-H5000 COVER-ANTENNA OP. -
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT CAN -
- 68480-H7302 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0875- 68480-H7301
- 68480-H7301 ASSY-INDICATOR LAMP,BELT CATALYST & F CAL 0974-0775 68480-H6200
- 68480-H7302 ASSY-IND LAMP,SEAT BELT, CATALYST & F FED(GFU) 1276-
- 68480-H7200 ASSY-INDICATOR LAMP,SEAT FED 0974-0776 68480-H6200
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT BELT -874
- 68480-H6200 ASSY-INDICATOR LAMP,SEAT FED 0876- 68480-H7200
- F8480-H6200 ASSY-SOCKET WITH HARNESS FORINDICATOR LA -874
- 26261-89900 BULB-INDICATOR LAMP -
- 26261-89900 BULB-INDICATOR LAMP FED 0974-
- 26261-89900 BULB-INDICATOR LAMP CAL 0974-
- 27989-H5000 ASSY-BONDING WIRE OP -
- 24875-H7201 DETECTOR-DRIVE COUNTER FED 0974-
B310
- B7910-H9111 RADIO KIT-AM/FM MONO (HITACHI) OP
- B7910-H9101 RADIO KIT-AM/FM MONO (CLARION) OP
- B7910-H9161 RADIO KIT-AM/FM MPX (CLARION) OP
- B7910-H8501 RADIO KIT-AM(CLARION) OP
- 27901-W5800 RADIO UNIT-AM OP
- 27907-W5800 RADIO UNIT-AM/FM MONO OP
- 27911-W5800 RADIO UNIT-AM/FM MPX OP
- 27933-89925 KNOB SET-RADIO,OUTER/INNER OP
- 27933-89901 KNOB-RADIO,OUTER OP
- 27934-89901 KNOB-RADIO,INNER OP
- 08915-44010 WASHER-PLAIN OP
- 27939-89900 NUT OP
- 27927-H8500 BRACKET-RADIO RH OP
- 27928-H8500 BRACKET-RADIO LH OP
- 08310-50812 SCREW(FOR UNIT) OP
- 08540-51242 SCREW(FOR INST) OP
- 24210-89962 CLIP OP
- 24210-89932 CLIP OP
- 99604-H1400 CLIP OP
- 27984-K0100 CONDENSER(FOR IGN COIL) OP
- 01461-00061 SCREW-TAPPING(M6) OP
- 27984-M0900 CONDENSER(FOR REGULATOR) OP
- 08510-61612 SCREW-TAPPING(M6) OP
- 27987-W5000 WIRE-BONDING(ENGINE DASH) OP
- 27960-H9100 ANTENNA SET (CLARION) OP
- 27960-H9110 ANTENNA SET (HITACHI) OP
- B7945-H8510 SPEAKER KIT-AM/FM MONO (HITACHI) OP
- B7945-H9301 SPEAKER KIT-AM/FM MPX (CLARION) OP WAGON
- B7945-H9161 SPEAKER KIT-AM/FM MPX OP SEDAN
- B7945-H8500 SPEAKER KIT-AM/FM MONO (CLARION) OP
- B7945-H8500 SPEAKER KIT-AM (CLARION) OP
- B7945-H9101 SPEAKER KIT-AM/FM MPX (CLARION) OP COUPE
- B9315-H9200 CASSETTE DECK KIT OP
- 24325-H8663 HARNESS-ADOPTER OP
- 29337-U7800 CABLE-ADOPTER EARTH OP
- 08540-51212 SCREW OP
- 96926-H8903 MASK-CONSOLE(FOR STEREO) (BLUE) OP
- 96926-H8901 MASK-CONSOLE(FOR STEREO) (BLACK) OP
- 96926-H8902 MASK-CONSOLE(FOR STEREO) (BROWN) OP
F10
- B7920-M5906 KIT-RADIO(AM/FM) (CL COUPE,OP 0278- Y B7920-M5905
- B7920-M5910 KIT-RADIO(AM/FM) (HI COUPE,OP -
- B7920-M4900 KIT-RADIO(AM) (CLARI OP -
- B7920-M5905 KIT-RADIO(AM/FM) (CL COUPE,OP -178 8
- 27911-M5905 TUNER (AM/FM) (CLARI COUPE,OP -178 8
- 27914-M5906 TUNER (AM/FM) (CLARI COUPE,OP 0278- Y 27914-M5905
- 27914-M5910 TUNER (AM/FM) (HITAC COUPE,OP -
- 27914-M4900 TUNER (AM) (CLARION) OP(SEDAN WAGON) -
- 27935-M3825 SET-KNOB WITH WASHER OP - Y 27935-M0225
- 27935-M5925 SET-KNOB WITH WASHER COUPE,OP -
- 27935-M3825 SET-KNOB WITH WASHER COUPE,OP - Y 27935-M3825
- 27935-M0225 SET-KNOB WITH WASHER OP -
- 27935-M0227 PLATE-ESCUTCHEON (FO OP -
- 27935-M5927 PLATE-ESCUTCHEON (FO COUPE,OP -
- 08313-51698 SCREW-PAN HEAD WITH COUPE,OP -
- 27933-H5001 SPEAKER COUPE,OP -
- 08510-41297 SCREW-PAN HEAD TAPPI COUPE,OP -
- 27984-M3060 SUPPRESSOR-NOISE,FOR COUPE,OP -
- 27984-M3061 SUPPRESSOR-NOISE,FOR COUPE,OP - Y 27984-M3060
- 27984-M0900 SUPPRESSOR-NOISE,C F COUPE,OP -
- 27982-M0200 TERMINAL-EARTH COUPE,OP -
- 27964-M3000 ANTENNA-PILLAR COUPE,OP -476 6
- 27964-M3001 ANTENNA-PILLAR COUPE,OP 0576- Y 27964-M3000
- 08510-51612 SCREW COUPE,OP -
- 08530-51690 SCREW COUPE,OP -
510
- 27900-21610 KIT RADIO OP. CANADA
- 27900-26110 RADIO KIT OP. USA -0768
- 27900-A0810 RADIO KIT OP. 0868-0669 supercedes 27900-26110
- 27910-A4625 RADIO KIT OP 0769- supercedes 27900-A0800
- 27910-A4626 RADIO KIT OP. 0769-0172 supercedes 27900-A0810
- 27900-N0225 RADIO KIT OP 0272- supercedes 27910-A4626
Datsun 620 Pickup
- 27914-89909 UNIT-RECEIVER,RADIO (AM) (CLARION) to 0775
- replaces 27914-89903
B11
1984 Nissan B11 Sentra was found to have this Datsun AM/FM radio:
It comes with an AUX jack (see section above):
Click any thumbnail to see it full size in our Club Photo Album. Read details or post a comment!ラジオ アンテナ
