Datsun 1200 has a parking brakeᵂ system with the handle conveniently located between the two front seats. Also known as "emergency brake", "parking brake" or "handbrake" (the primary brakes are called the "service brakes").
74965 #Hand Brake Cover is called by Nissan the "parking brake lever COVER".
36310 Hand Brake Lever Assembly (comes in black, brown and grey)
36315-H1001 GRIP-HAND BRAKE (Hand Brake Lever Handle)
36402 front handbrake cable
The front cable is different lengths to suit different body shapes, there is some interchangeability but sometimes you end up too short
36402-H1025 CABLE ASSY-hand brake, front B110 supercedes 36402-H1001 36402-G1000 CABLE ASSY-hand brake, front B120 (up to 1973-11)
36400 rear cable (complete set)
UTE: Parking Brake Cable goes out the back wall
Hand Brake Cover
B210 cover also fits and is the offical supersession part.
Top: replacement part, same as B210 | Bottom: original B110 design
ブレーキカバー
Cable Routing
Front half is same for all 1200
Ute - cable comes out the cab lower rear panel
Warning Light
Dash-top Indicator Lamp
Some utes had a PARK BRAKE lamp on top of the dash that lit up when the handbrake was activated and IGN was ON.
Light Switch
The light switch was added to the hand brake lever.
Light
Parking Brake Lever1972 USA Owners manual (Page 13 ... 13):
When the parking brake is applied, the brake warning light will glow
Dash-top Lamp (AUSTRALIA)
Cluster Gauge Lamp (USA/late JAPAN)
Dash Lamp (early JAPAN)
- 74965-H7300 BOOTS-HAND BRAKE [Large style]
- 74965-H1000 COVER ASSY-PARKING BRAKE LEVER B120 8910-
- 74965-G1060 B120 7804-8910 [Brown]
- 36011-89901 SWITCH-HAND BRAKE USA
- 36011-H1900 SWITCH-HAND BRAKE WARNING 0570- USA
- Also fits B210 USA
- Also fits B210 JAPAN from '75-4
Aftermarket Cable
- 48-1/4" Overall Length, 2 Per Car
- RAYBESTOS BC92888 $39.79
- ACDELCO 18P154, 18033072 $48.79
B140
2005 bakkie with Bench Seat has the hand brake lever next to the door.
