Grille
Revision as of 16:40, 31 August 2008; view current revision
Category: Body
Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the grilles changed for 1972.
Coupe-type Grilles
  • Black headlight surrounds: Coupe
  • Silver headlight surrounds: Late Ute (1978-up)
Silver oval with Silver across the middle (all except late GX coupe):
Late GX (1972-1973) - black center:
Early GX:
Transitional GX? - black center, early hood
Late South Africa GX with GL grille (1973 brochure)
Flipped Grille (upside down)
865.jpg GX-5 Coupe grille "winged 'S'" (flying 'S')
Sunny Truck Grille
Early Truck
1973-1977 Sunny Truck, ute and bakkie
Late Truck
1978-up Ute. This grille looks nearly identical to the Coupe grille:
  • Silver headlight surrounds (coupe has black surrounds)
  • Center Badge mounts Horizontal (Coupe is vertical)
Square Headlight Truck
JDM - From October 1989
Bakkie B140
7403.jpg7404.jpg with "Nissan" oval badge
1123.jpg With "N I S S A N" letters
Sedan Grille
Sedan grille "D" and "S" emblems
Late JDM intricate "S" grille emblem
Customized Grilles
Color Matched
  • Coupe-grille with custom insert
