Datsun 1200, unlike the Datsun 1000, was designed with air conditioning in mind. However, it was still a dealer-installed add-on option and so varied by country and region. In April 1978 it became a factory option for Japanese market Sunny Truck. The interior cooler protrudes into the passenger legroom and precludes using a package tray.
Parts Needed
- Pump
- Condensor (cooling radiator)
- Double crankshaft pulley. (The extra pulley runs the compressor)
- Under-dash vents
- Hoses
- Wiring
Since B110 A/C is fairly rare, you can source most of the parts from a B210 or B310. Only the interior vent setup is needed for a B110. They are fairly common on late model B122 Sunny Trucks.
Compressor
The compressor pump bolts to the engine and is driven by a v-belt
Crankshaft pulley double belt
Engine Brackets
Various types were used. Early A12 and late A12 brackets differ.
Left-hand Drive
Ecuador
USA Type 1
USA Type 2
Optional Fan
Nissan option flex-fan
Dealer item
From USA catalog:
- 21060-H1001 FAN-COOLING A12 (standard B110 fan)
- 21060-A4605, 21060-N0100 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter)
B122 Sunny Truck Kit
This kit is beautiful and easy to install. Unfortunately the interior cooler unit is bulky and protrudes farther into the passenger legroom than other types.
You need all these parts:
- condensor (before radiator, radiator horizontal)
- capacitor for electric fans
- high-pressure pipe
- low-pressure hose
- Receiver tank
- relay harnesses
Vents may be opened or closed:
Condensor & Dryer with High and low pressure hoses
High and low pressure hose routing:
Compressor mounted low left engine side
Legroom
Since the cooler unit takes up some of the passenger legroom, what to do? One enterprising 1200 fan mounted the cooler unit in the dash:
Of course the downside is there is no glove box.
