Adorning the extreme ends of the Datsun 1200 are chrome bumpers. Although the front bumper is shared by all models, the rear bumper differs between Coupe, Sedan, and Van/Wagon(VB110). The front bumpers have bolt holes for USA and Japan license plates (two sets of holes).
Front
The front bumper of a 1200 is a fairly straight chrome bar and has two small notches on the bottom for the front turn-signal lights:
The front bumper is in three pieces:
- Two long front sections (left and right) that curve and the end to wrap around the side just a little
- a shallow degree binding piece (the front bumper is a slight V)
It is sold as one piece.
Late Sunny Truck
1978-up Sunny Truck used a rubber-ended chrome bumper:
B140 Bakkie
The B140 Bakkie has a larger flat bumper, painted black, with lights in the face.
Rear
- Coupe bumper has a notch for the license plate:
- Wagon is smooth with no notch and no lights:
The regular rear bumper is in three pieces:
- Long center section that varies between Sedan, Coupe and Wagon
- Two end caps, left and right, that wrap around the side a little bit
It is sold as three pieces.
B120
Ute had two small rubber pads, and two black corner bumperettes:
B140 Bakkie
The B140 Bakkie rear has the standard two rubber pads, and also black corner bumperettes, with lights in the face.
1973 USA Bumpers
For 1973, USA models got large bumper pads to meet FMVSS No. 215. They also used redesigned bumper-to-body brackets. The chrome parts look similar but are different.
New Zealand
Some B120 SportStar utes had black bumpers:
Overriders Removed
Some models may have come without front overriders, but I think all models had rear overriders.
OPTION Overriders
Available from Datsun USA dealers were steel tubular overriders from ARMCO:
Custom Bumpers
Heavy-Duty Bumper with Bilby Guard
Bumperless Look
NOTE: 1973 parts fit older brackets, but older bumper doesn't fit newer brackets.
Front Bumper (Coupe & Sedan)
- 62651-H7000 ASSY-BUMPER,FRONT Sedan, Coupe from 0772 $178
- 62651-H1000, H1001, H1900 ASSY-BUMPER,FRONT Sedan, Coupe
Rear Bumper, sedan
- 85011-H7000 BUMPER-REAR CENTER Sedan from 0772
- 85011-H1900 BUMPER-REAR CENTER Sedan
- 85012-H1000 BUMPER-REAR RH Coupe, Sedan
- 85013-H1000 BUMPER-REAR LH Coupe, Sedan
62663-18000 BOLT-SPECIAL M6 FIX BUMPER CENTER TO SI 08915-13610 WASHER-LOCK FIX BUMPER CENTER TO SI 08911-10610 NUT-HEX M6X1.0 FIX BUMPER CENTER TO SI 08915-53610 WASHER-PLAIN FIX BUMPER CENTER TO SI 85204-H1000 STAY-BUMPER REAR 85204-H7000 STAY-BUMPER REAR 62663-18000 BOLT-SPECIAL M6 FIX STAY TO BUMPER 08114-01610 BOLT 08915-43610 WASHER-PLAIN M6 FIX STAY TO BUMPER 08915-44010 WASHER-PLAIN 08915-13610 WASHER-LOCK M6 FIX STAY TO BUMPER 08915-14010 WASHER-SPRING 08911-10610 NUT-HEX M6 FIX STAY TO BUMPER 85206-H7000 BRACKET-BUMPER REAR SIDE RH 85206-H1000 BRACKET-BUMPER REAR SIDE RH 85207-H1000 BRACKET-BUMPER REAR SIDE LH 85207-H7000 BRACKET-BUMPER REAR SIDE LH 62663-18000 BOLT-SPECIAL M6 FIX BRACKET TO BUMPER 08915-43610 WASHER-PLAIN M6 FIX BRACKET TO BUMPER 08915-13610 WASHER-LOCK FIX BRACKET TO BUMPER 08911-10610 NUT-HEX M6X1.0 FIX BRACKET TO BUMPER 08110-82062 BOLT-HEX WITH WASHER FIX STAY TO BODY 08915-53810 WASHER-PLAIN FIX STAY TO BODY 62685-73000 WASHER-RUBBER FIX STAY TO BODY 62678-21000 SHIM-BRACKET BUMPER SIDE FIX BRACKET TO 08110-61862 BOLT-HEX WITH WASHER FIX BRACKET TO B 08915-53610 WASHER-PLAIN FIX BRACKET TO BODY
Rear Bumper, Coupe
- 85011-H7100 BUMPER-REAR CENTER Coupe from 0772
- 85011-H1905 BUMPER-REAR CENTER Coupe
Overriders
85020-H1900 OVERRIDER-REAR BUMPER RH 85021-H1900 OVERRIDER-REAR BUMPER LH 85020-H7000 OVERRIDER-REAR BUMPER RH 1973 85021-H7000 OVERRIDER-REAR BUMPER LH 1973 62674-H1900 OVERRIDER-FRONT BUMPER RH 62675-H1900 OVERRIDER-FRONT BUMPER LH 62674-H7000 OVERRIDER-FRONT BUMPER RH 1973 62675-H7000 OVERRIDER-FRONT BUMPER LH 1973 85024-H1900 RUBBER-OVERRIDER (4)
Catalog
- 62651-H1000 ASSY-BUMPER,FRONT
- 62651-H1001 ASSY-BUMPER,FRONT from 0870 (interchanges with former)
- 85011-H1000 BUMPER-REAR CENTER Sedan
- 85011-H1800 BUMPER-REAR CENTER Coupe
- 85011-H1400 BUMPER-REAR CENTER Van
NOTE: PB110 front bumper is unique, but PB110 rear bumper is same as B110.
Sunny Truck
- 62651-H1025 ASSY-BUMPER,FRONT Truck 7510-7803 (one piece)
- 62650-G1060 ASSY-BUMPER,FRONT Truck 7804-8910 (three-piece)
- 62650-95W00 ASSY-BUMPER,FRONT Truck from 8910
- 62024-G1060 BUMPER-FRONT RH from 7804
- 62025-G1060 BUMPER-FRONT LH from 7804
- 85010-G1001 RUBBER-REAR BUMPER, SIDE RH 7510-7611
- 85010-G1002 RUBBER-REAR BUMPER, SIDE RH 7612-
- 85011-G1001 RUBBER-REAR BUMPER, SIDE LH 7510-7611
- 85011-G1002 RUBBER-REAR BUMPER, SIDE LH 7612-
