K Gearbox
From Datsun 1200 Club
Categories: Transmission | Transmission Modifications
<-- back to Toyota 5-speed
Can't find a good Datsun gearbox? Toyota K gearbox is the K40 4-speed and K50 5-speed light/medium-duty transmissions found in Toyota Corollas and Starlets. It is readily available. It is good for up to 103 ft. lb. torque, so appropriate for a naturally aspirated A engine. Not strong enough for a turbo or supercharged engine.
Source
     Starlet K engine
     Corolla K engine
1986 Corolla 3A-U, 4A-U (up to 101 ft. lb.)
KM20 Liteace with 4K, 5K, 7K engine (up to 103 ft. lb.)
Stripped 3rd on a K40 (don't use with a supercharged A15)
12299.jpgAlbum 12299
Ratios
Ratios
      K40    K50
1st: 3.769  3.789
2nd: 2.250  2.220/2.124
3rd: 1.405  1.435/1.323
4th: 1.000  1.000
5th:        0.865
REV: 4.316  4.136
Swap
3rotor shows how he swapped the K40 into his ute.
See main article: Cut-n-shut
11870.jpgAlbum 11870 11872.jpgAlbum 11872 11873.jpgAlbum 11873 11874.jpgAlbum 11874 11875.jpgAlbum 11875 11876.jpgAlbum 11876 11877.jpgAlbum 11877 11878.jpgAlbum 11878 11880.jpgAlbum 11880
Release Lever
11881.jpgAlbum 11881
Release Bearing. Make a sleeve adapter for the Nissan unit
11882.jpgAlbum 11882
Yoke must be adapted to Datsun driveshaft
11871.jpgAlbum 11871
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=K_Gearbox"
This page has been accessed 5,516 times. This page was last modified 08:59, 24 November 2021. Content is available under Datsun 1200 Club.
