Muffler
From Datsun 1200 Club
Category: Exhaust System
See also: Exhaust Piping
The Datsun 1200 used a 1.5 inch exhaust system with a very, very, very quiet muffler — the factory Datsun 1200 muffler was so quiet you couldn't hear the engine running at idle. The muffler included a permanently attached tail pipe.
Exhaust Pipe, Muffler, Tail Pipe
26085.jpgAlbum 26085
Original mufflers came with integrated tail pipe This rear-most pipe was part of the muffler. Aftermarket replacement mufflers usually had a separate tail pipe to reduce shipping costs.
22334.jpgAlbum 22334
The muffler should flow at least 2.2 cfm per flywheel HP. For a 69 hp A12, that is 152 cfm, easily achieved with the factory 36mm piping.
Muffler for truck is located in front of the Rear Axle but can be relocated to after the rear axle. Later models have a resonator behind the cab
31384.jpgAlbum 31384 25945.jpgAlbum 25945
Muffler for sedan/coupe/wagon is located just in front of the Rear Axle
174_61886c76ce02c.jpgPost 496137
Coupe & Sedan have the same muffler location, only the bend shape of the tailpipe portion differs a little. This bend allows the pipe to go over the rear axle.
174_61896f59b21f2.jpgPost 496141
The body of the muffler is suspended by two rubber rings and contributes to quietness of the exhaust system (there are no rattles from the exhaust).
174_61896f6a2702e.jpgPost 496141
Tailpipe exits at the rear, below the bumper
174_6186e90530c7c.jpgPost 496134
Size
Muffler measurements from my 1200 sedan with factory original muffler:
* 11-5/8" Shell length
* 8-1/4" Shell oval width
* 3-3/4" Shell oval height
* 1.5" front inlet, centered
* 1.5" rear outlet, on far left of oval
There is enough room under a sedan that a muffler about 2" longer may fit.
The 1200 GX exhaust system is finished with a small resonator and a muffler later on. The resonator terminates the air column at an exact lenght for optimum power, and also reduces harmonic noise.
12778.jpgAlbum 12778
A15E EGI dual exhaust (92 hp). This one has been modified to remove the muffler for racing where noise limits do not apply
174_5d3784513e627.jpgPost 491958
Nissan JDM Catalog
20010-H1000 TUBE ASS'Y-exhaust, front - ALL (exc. GX, Automatic)
20010-H1020 TUBE ASS'Y-exhaust, front - Automatic
20010-H2301 TUBE ASS'Y-exhaust, front - GX 4-speed
20010-H3400 TUBE ASS'Y-exhaust, front - GXA (GX Automatic)
20010-H7200 TUBE ASS'Y-exhaust, front - GX-5
20603-H2300 GASKET-exhaust tube - GX and GX-5
20602-27700 NUT-fixing, tube end (2) - ALL (except GX, GX-5)
20602-27700 NUT-fixing, tube end - GX-5
08915-13810 WASTHER-spring lock (3) - GX-5
20635-18000 STOPPER-muffler bound - ALL
20100-H1000 MUFFLER ASS'Y-with rear tube - Sedan
20100-H1400 MUFFLER ASS'Y-with rear tube - Van
20100-H2500 MUFFLER ASS'Y-with rear tube - Coupe
20630-18000 RING-rubber, muffler clamp (2)
20620-H1000 CLIP-tube, exhaust
06915-43810 WASHER-plain (2)
08915-13810 WASHER-lock
08110-85510 or 08110-86010 BOLT
08911-10810 NUT
20640-18000 STRAP-exhaust hanger
20641-18000 WASHER-plain (2)
08911-10810 NUT (2)
08915-13810 WASHER-lock (2)
08110-82210 BOLT (2)
20321-H2500 FINISHER-exhaust - GL, GX
20720-N2225 SEALER KIT-exhaust tube joint - ALL
USA Catalog
20010-H3100 ASSY-TUBE EXHAUST FRONT Sedan Manual Trans > 20010-H1000 $34.92
20100-H7001 ASSY-MUFFLER WITH REAR TUBE Sedan Manual Trans > 20100-H1000 $84.72 NLA
20321-H2000 FINISHER-EXHAUST (chrome extension) NLA
20321-H2500 FINISHER-EXHAUST (chrome extension) $18.36 NLA
Clamp
When it's time to fit the muffler to the exhaust pipe, the muffler inlet tube slips over the exhaust pipe coming from the front of the car.
174_6901ce28606ac.jpgPost 499091
This clamp tightens it down with an M8 bolt
174_690296d3a4b76.jpgPost 499094
replaced by
20643-B5000 CLAMP-exhaust tube (from 1973-11)
31087.jpgAlbum 31087
Alternative, you may use a 1.5" muffler u-bolt.
To make sure the exhaust seals, use the factory Datsun muffler seal in the exhaust pipe groove
20720-N2226 EXHAUST TUBE SEALANT
or a tube of generic muffler sealant:
174_690290aa1cd2b.jpgPost 499094
Muffler Stopper
The rubber muffler stopper prevents the muffler from banging against the floor panel.
* B10 (all except earliest)
* B110
174_69025583b1da5.jpgPost 499093
Early B210 to 1975 and all VB210 use the similar 610 bumper 20635-K0101
Rubber Hangers
These factory parts make your exhaust absolutely quiet. With an original muffler, you couldn't hear the engine idling
Google search and japanese search
The muffler clamp RINGs and the hanging STRAP take all the vibrations out. Generic versions of these parts work OK
174_6901a1f013f44.jpgPost 499088 174_6901a2010130e.jpgPost 499088
The rubber hangers have B10 Datsun 1000 part numbers
26030-18001 RING-rubber, muffler clamp
26030-H5000 RING-rubber, muffler clamp 30x39mm inside diameter, 13mm diameter
Early B210 to 1975 (including 120Y) looks the same, but as usual has an H50 part type, so they may be slightly different, but are sold to fit the B110.
Ohno SN-2013 from 5825 Ohno Rubber Industrial Co., Ltd.
31439.jpgAlbum 31439
Oh, by the way, when you get new rings, they seem too small. But they stretch to fit
Datsun 910/S110 Silvia and Nissan R30 Skyline/C31 use similar rings, but they are thicker (15 mm). Nissan 20630-N8200
Buy at Bprojects or https://datsun1200.jp
25604.jpgAlbum 25604
The strap (rectangular) rubber hanger uses M8 bolts and washers. It would be easy to make one, with some kind of heat-resistent material: 90x30x12mm with 2 M8 holes on 60mm centers. Or get one off a 280ZX, 810 Maxima, Urvan, Vanette, 240Z or 510/610/710 20640-18000
Original Muffler
19077.jpgAlbum 19077
The muffler connects to the Exhaust Manifold
31096.jpgAlbum 31096 31095.jpgAlbum 31095 31093.jpgAlbum 31093
B210 muffler looks identical to the B110 part, but is a little longer at 329mm (1-3/8" longer than B110). There is plenty of room in a B110 sedan for this. this one conveniently has the tailpipe cut off for storage and shipping.
20100-H5000 B210 NICHIRA muffler 229 x 205 mm
174_6901cdb253e98.jpgPost 499091 174_6901ce5c8e001.jpgPost 499091 174_6901cdee08dd2.jpgPost 499091 174_6901ce44482f5.jpgPost 499091 174_6901cdfbdb28f.jpgPost 499091 174_6901ce10d5f84.jpgPost 499091 174_6901ce28606ac.jpgPost 499091
Aftermarket Replacements
Matuko muffler MB-067 for VB110, equivalent to Nissan 20100-H1400
174_6903d425518c7.jpgPost 499097
HST muffler 026-14 for B210 with A12/A14/L16 engines hst-muffler.com
174_69015e01097b9.jpgPost 499087
Toyo N-150 Gold Muffler
174_690250ae91b0b.jpgPost 499091
Aftermarket Alternatives
Aftermarket 1.5
  • Dynomax 17700 ("Thrush turbo"),similar shape to stock. Oval 3.25 in. x 7.75 in. Case Length: 11 in. Overall length: 16 in. Width: 7.750 in. Thickness: 3.25 in.
1-1/2 pipe clamps:
* Merit M112 or U112
* Napa BK 7335325
Rubber Donut Hangers
* Merit 8166 ???
Aftermarket GX (is it the same as the S110 gasket?)
* Gasket: Merit 8696
* Pipe: (1981 Nissan 720), Merit 48316
Exhaust Tip - 1-1/2" diameter
* Merit 9821
Aftermarket 1.75
Can Muffler
Hot-dog style mufflers (cannons or "fart cans") are mainly for looks. Having the muffler at the very end of the exhaust makes it louder, and most cans are fiberglass packed tubes ("glass-pack") which are by nature noisy. They are simply a straight-through pipe with baffles in the tube sides.
2539.jpgAlbum 2539 2951.jpgAlbum 2951 4397.jpgAlbum 4397 21044.jpgAlbum 21044
When fitting a can muffler, it is advised to also fit a large normal muffler under the car.
17076.jpgAlbum 17076
Dual Outlet
174_5d8159050dcc3.jpgPost 492625
Arms
マフラー (アームズ)
arms-eng.comᴬᴿᶜᴴᴵⱽᴱ
2025 prices
* Stainless: ~900 USD
* Titanium: ~1700 USD
ARMS - Side Muffler with stainless side tubes to fit 1200 ute. Volume 94db. Main pipe φ50, tail end φ50 (2" pipes). Dual slash cut or straight cut.
25595.jpgAlbum 25595 25603.jpgAlbum 25603 25596.jpgAlbum 25596 25597.jpgAlbum 25597 24947.jpgAlbum 24947
Nismo
"FISCO" and "NISMO" was fitted to Sunny Truck with A15
25539.jpgAlbum 25539 25540.jpgAlbum 25540 25541.jpgAlbum 25541
Finish Mufflers
Add a stylish stainless steel muffler at the end of a full exhaust system.
21044.jpgAlbum 21044 18361.jpgAlbum 18361 18255.jpgAlbum 18255 13423.jpgAlbum 13423
rotary style dumpy
15642.jpgAlbum 15642
straight-through "cannon" muffler (a straight pipe, peforated with holes and fiberglass-packed chamber) is VERY loud
13422.jpgAlbum 13422 4131.jpgAlbum 4131
10512.jpgAlbum 10512 10511.jpgAlbum 10511 10513.jpgAlbum 10513
Bush Mufflers
16569.jpgAlbum 16569 21118.jpgAlbum 21118
Finisher
For sharp looks, you can fit a stainless extension which looks good forever. Needs to fit a 1.5 inch pipe, and while most aftermarket tips are larger they fit a range of smaller pipe sizes.
or a cheaper chrome tip like this factory B110/B210 option, which looks fabulous for a few years
31086.jpgAlbum 31086
This is a vintage Nissan Muffler Cutter with part number 20321-H2500. It is a new old stock (NOS) part, meaning it is an original, unused part from a past production run.
  • This type of part is often sought after by collectors and restorers of classic Datsun and Nissan vehicles.
  • The packaging indicates it is a genuine Nissan part.
  • The item is a chrome exhaust tip, designed to be fitted to the end of the tailpipe
20321-H2500 Muffler-Cutter マフラーカッター B110
174_6901d3b7e6a58.jpgPost 499090
174_6901d3d492c26.jpgPost 499090 174_6901d3f3f06af.jpgPost 499090 174_6901d401929a3.jpgPost 499090
Dual Exhaust
Dual exhaust is not possible on a Datsun 1200
the exhaust was a full system headers back and split in two just above the diff
5067.jpgAlbum 5067
Stealth
For the sleeper look
12687.jpgAlbum 12687 12698.jpgAlbum 12698
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Muffler"
This page has been accessed 8,879 times. This page was last modified 05:45, 3 December 2025. Content is available under Datsun 1200 Club.
