Neutral Switch
From Datsun 1200 Club
Category: Transmission
Some manual transmissions were fitted with an electrical Neutral Switch to signal when the gearbox is not in gear. Automatic Transmissions are fitted with a an Inhibitor Switch which also signals when the automatic is in Neutral.
Neutral Switch was first used in 1973 USA models.
Neutral Switch was used for:
* EGR (some years e.g. 1990 1200, 1975 B210)
* Fuel Shut-Off System on B310
* Starter interlock on automatic cars
* Throttle Opener used the Inhibitor Switch to detect neutral
* TCVAS spark control used the Top Switch to detect neutral
Location
56-Series Transmission Neutral Switch
is near top of 4-speed
19052.jpgAlbum 19052
56-series Neutral Switch (yellow arrows)
21404.jpgAlbum 21404
60-Series Transmission Top Switch
on the tail extension, near top
25456.jpgAlbum 25456
63-Series Transmission
Tail Housing, near top, above (T)op and (R)everse and switches
24141.jpgAlbum 24141
Also See:
* Inhibitor Switch for automatics
* 63-Series_Transmission#Switches
32130, 32006
32005-21101 SWITCH ASSY-REVERSE LAMP
32006-G6200 NEUTRAL POSITION SWITCH
B310 USA
A12 56-series 4-speed
* 32005-H5000 SWITCH COMP-REVERSE LAMP <> 32005-K1201 <> 32005-K1202
* 32006-K2400 SWITCH COMP-NEUTRAL <> 32006-K2401
  CAL 0879-
* 32006-K2000 SWITCH COMP-4TH <> 32006-D0120 <> 32006-D0102
A14/A15 60-series 4-speed
* Reverse same as 56-series 4-speed
* Neutral same as 56-series
  CAL 0879-
  CAN
* SWITCH COMP-TOP (0879-) - same as 56-series
  FED, CAN
A14/A15 FS5W60L & FS5W60A
 32005-K1000 SWITCH COMP-REVERSE LAMP <> 32005-K1001 <> 32005-K1002
 32006-D0102 SWITCH COMP-TOP <> 32006-D0120
 32006-K2000 SWITCH COMP-TOP
 32130-H9000
 32130-H9010
 32130-H9705
  CAL
  COUPE
NOTE: Sometimes misspelled as 'Nuetral Switch'
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Neutral_Switch"
This page has been accessed 10,892 times. This page was last modified 09:06, 26 February 2017. Content is available under Datsun 1200 Club.
