R31 Rear Disc Brake Swap
From Datsun 1200 Club
You can add rear disc brakes to H145 with a Australia-built R31 Skyline/Pintara setup. Fits over 13" steel wheels.
H145
It will also fit H150 as H145/H150 housing ends are the same.
Click each photo to read the comments and find more detail.
Use a Brake Proportioning valve to set the balance. These are large rear brakes.
R31 Caliper bracket modified to fit H145
22645.jpgAlbum 22645
Holes re-drilled for H145 housing pattern
Remove the axles. Cut the axle bearing retainers and remove the axle bearings. Now you can remove the drum backing plate, and but more importantly will be able to fit the adapter over the axles. New bearings can then be fitted.
Lay H145 drum brake backing plate over Adapter, mark the holes to drill
22672.jpgAlbum 22672
Finned R31 caliper bolts to the adapter
22618.jpgAlbum 22618 22620.jpgAlbum 22620
Fit over 13" steel wheels
22619.jpgAlbum 22619
The factory adapter is thin, but adequately strong
10076_4cf2aefa484bb.jpgPost 347550
Fitted to 1200 Coupe
10076_4cf2acdd6c123.jpgPost 347549
10076_4cf2acec2d865.jpgPost 347549
Consider use appropriate shims inside of the caliper bracket to prevent the bearing from moving. The stock H145 setup using shims between backing plate and housing.
Rear Caliper
18391.jpgAlbum 18391
Handbrake Considerations
Not this:
9665_4cf0ca67db5f0.jpgPost 347474
Fit the calipers facing forward so you can run the cables back and loop around and utilise the existing hand brake bracket and cabling on the diff.
9665_4cf1f6a57c85e.jpgPost 347499
You can use one of the R31 cables to do the RH side but the LH side is not the correct length. Have a brake shop make a new cable or mix-match at the wreckers
10076_4cf2acfc5bda1.jpgPost 347549
10076_4cf2ad1229ff3.jpgPost 347549
10076_4cf2aecee320d.jpgPost 347550
10076_4cf2aee4a208c.jpgPost 347550
10076_4cf2af0f01464.jpgPost 347550
H165
R31 rotors on H165 ute axle housing
P3290804.jpgPost click for topic
GM calipers fitted (for a handbrake-less setup). Commodore VK rear calipers are same as Australia-assembled Skyline R31 calipers -- but without the external fins of the R31 caliper which limit rim selection.
P3290803.jpgPost click for topic
R31 brakes to H165? Mockups:
10951.jpgAlbum 10951 11018.jpgAlbum 11018 11019.jpgAlbum 11019 11020.jpgAlbum 11020
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=R31_Rear_Disc_Brake_Swap"
This page has been accessed 18,329 times. This page was last modified 23:54, 31 July 2018. Content is available under Datsun 1200 Club.
