Tension Rod
From Datsun 1200 Club
Category: Front Axle And Front Suspension
Tension Rod, also known as compression rod, strut rod, or caster/castor rod. Sometimes called a radius rod or reaction rod, or even a tie bar (although that suggests a tie-rod bar).
The tension rods keep the front wheels located fore/aft. It forms one leg of the virtual lower A-arm. The LCA makes up the other leg of the "A".
H10 1973-1975 1200 rods
H74 1976-1994 1200 rods (also used by 1976-up 120Y)
22682.jpgAlbum 22682 26639.jpgAlbum 26639
1976 and later tensions rods have a different bolt spacing at the end, to match the updated bolt pattern on the 1976 and later LCAs. Because of the changed patterns, H74 requires notched Tension Rods with bolt holes drilled farther apart
23764.jpgAlbum 23764 23765.jpgAlbum 23765
The tension rod is the lower bar attached to the LCA, the other bar is the anti-sway bar
9433.jpgAlbum 9433 8712.jpgAlbum 8712 174_5866e81325cbf.jpgPost 483002 12526_53f7d901e3a1f.jpgPost click for topic
With bushes in place:
13474.jpgAlbum 13474 24594.jpgAlbum 24594
Red poly bushings for a stiffer ride
15218.jpgAlbum 15218 11936.jpgAlbum 11936 11937.jpgAlbum 11937
Rods
Early 1200 (B110, un-notched)
* 54470-H1000 ROD-TENSION FRONT SUSPENSION RH
* 54471-H1000 ROD-TENSION FRONT SUSPENSION LH
1975.October-1979.October (notched) B120 & B210
* 54470-H7400 Tension rod R.H
* 54471-H7400 Tension rod L.H
79.November and newer B121/B122 also all B310
* 54470-H8500 Tension rod R.H
* 54471-H8500 Tension rod L.H
Bolts
For the two bolts that fix the Tension Rod to the ball joint & LCA, see see Ball Joints.
54472-18000 WASHER-SPECIAL TENSION ROD -7910
54472-H8500 WASHER-THRUST TENSION ROD 7911-
54630-H1001 COLLAR-BUSH TENSION ROD
08915-44210 WASHER-PLAIN M12
08912-34210 NUT-HEX SELF LOCK M12
Bushings
Bushes 1200/120Y/B310 - approximately 21 mm thick
* 54476-W5000 Tension rod bushing (2 per side) (replaces 54476-H1001) $2.73
24595.jpgAlbum 24595
Rockauto B110 Rockauto B310
* MCQUAY-NORRIS FA1320
* RAYBESTOS 5781039
* ACDELCO 45G25039 or 88913237 $4.70/side (bushings, collar, washer & nut)
* MOOG K9217 $6.23/set of four
JAPAN
Early B210
 54474-H5000 ROD ASS'Y-tension, front suspension (R.H.)
 54475-H5000 ROD ASS'Y-tension, front suspension (L.H.)
Late B210 Van 1075-, sedan/coupe 1275-
 54474-H7400 ROD ASS'Y-tension, front suspension (R.H.)
 54475-H7400 ROD ASS'Y-tension, front suspension (L.H.)
54472-18000 WASHER-special, tension rod (4)
54630-H1001 COLLAR-bush, tension rod (4)
54476-H1001 BUSH-tension rod (4)
08915-44210 WASHER-plain (2)
08912-34210 NUT (2)
54880-H5000 BRACKET ASS'Y-tension rod (R.H.) A12 & A14
54480-H5900 ASSY-BRACKET,TENSION ROD RH USA & L16 JDM
NORTH AMERICA (HLB210, fits PB210 LCA)
54474-H5900 ASSY-ROD,TENSION RH
54475-H5900 ASSY-ROD,TENSION LH
54537-21003 WASHER-SPECIAL (4)
54479-21000 COLLAR-BUSH TENSION ROD (2)
54476-21000 BUSH-TENSION ROD (4)
08915-54210 WASHER-PLAIN (2)
08912-34210 NUT-SELF LOCK TYPE N M12 (2)
B310
54470-H8500 ROD-TENSION,FRONT SUSPENSION RH
54471-H8500 ROD-TENSION,FRONT SUSPENSION LH
54472-H8500 WASHER-SPECIAL TENSION ROD TO BRACKET (4)
54630-H1001 COLLAR-BUSH,TENSION ROD TO BRACKET (2)
54476-W5000 BUSH-TENSION ROD TO BRACKET (4)
08915-44210 WASHER-PLAIN (2)
08912-34210 NUT-HEX,SELF LOCK TYPE (2)
Brackets
The tension rod chassis brackets are welded to the front side member (front rail)
74830, 74831
54532-H1001 BRACKET-SUSPENSION ROD, RH
54533-H1001 BRACKET-SUSPENSION ROD, LH
24597.jpgAlbum 24597 24596.jpgAlbum 24596 174_619c2111abf3b.jpgPost 496241 27033.jpgAlbum 27033 12653.jpgAlbum 12653
If it cracks, re-weld and reinforce as necessary. A large washer can be welded to reinforce the opening
7199.jpgAlbum 7199
If battery rust corrodes the right bracket, replace it
12016.jpgAlbum 12016 12018.jpgAlbum 12018 12593.jpgAlbum 12593
Custom Rods
For custom or adjustable rods, see main article:
Custom Caster Rods
Nissan Competition
This kit prevents suspension geometry changes under high cornering forces, and reduces front end dive while braking.
See Tension Rod Bearing Kit
Increased Caster
Cut the collar (metal tube) shorter. See:
Main Forum - How To: More Castor
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Tension_Rod"
This page has been accessed 35,860 times. This page was last modified 00:28, 24 November 2021. Content is available under Datsun 1200 Club.
