Towing
From Datsun 1200 Club
Category: Owner's Manual
Yes, your Datsun may be towed safely by another vehicle, with a few considerations.
Operation
See the Owner's manual: Operating the Car
1972 USA Owners manual (Page 17 ... ):
TOWING
If the car is being towed with the rear wheel on the ground, do not exceed 17 MPH (30 km/h). The selector lever should be in the "N" position. If the transmission is inoperative, it is advisable to two with the rear wheels raised off the ground, or with the propeller shaft removed.
1974 B120 Owner's Manual (Page 25 ... )
If your vehicle must be towed, it is important that the towing rope be fastened only to the tension rod brackets as illustrated. The rope must be routed under the bottom edge of the bumper. To tow another vehicle, always tie the rope to the rear spring hanger.
Being towed by the rear wheels
However, these instructions were updated later. The 1980 owner's manual says:
TOWING
CAUTION
  • It is necessary to use proper towing equipment to avoid possible damage...See the Towing Procedure Manual at dealer side.
  • All applicable government laws regarding the towing operation must be obeyed.
  • Before towing, make sure that the transmission, axles, steering system and power train are in good order. If any unit is damaged, a dolly must be used.
  • If the transmission is inoperative, tow the car with the rear wheels off the ground, or with the propeller shaft removed.
  • When the car is towed with its front wheels on the ground, secure the steering wheel in a straight ahead position with the ignition key turned in the "OFF" position.
  • When towing an automatic transmission model, try to restrict towing speed below 30 km/h (20 MPH) and towing distance less than 30 km (20 miles).
  • With manual transmission model, try to restrict towing speed below 80km/h (50 MPH) and towing distance less then 80 km (50 miles).
  • If the speed or distance must necessarily be greater, remove the propeller shaft beforehand to prevent damage to the transmission
  • Release the parking brake and set the gearshift lever in the "Neutral" position before starting to tow the car.
Nissan Patrol Y60 towing 1200 Coupe
4815.jpgAlbum 4815
Factory-suggested Tow Points
Front - place rope around tension rod bracket
Rear - place rope around spring shackle
Rope-towed
13182.jpgAlbum 13182
Towbar
Being towed by towbar
Trailering
Being towed on a trailer seems very popular too.
Flatbed/flattray towing
277_5312bf8ba50e4.jpg 9139.jpgAlbum 9139 13807.jpgAlbum 13807 5923.jpgAlbum 5923 8600.jpgAlbum 8600 8601.jpgAlbum 8601 9256.jpgAlbum 9256 13720.jpgAlbum 13720 14040.jpgAlbum 14040 15402.jpgAlbum 15402 19580.jpgAlbum 19580
6167.jpgAlbum 6167
Tie-down
Trailer Queens
14355.jpgAlbum 14355
21482.jpgAlbum 21482
B10
18866.jpgAlbum 18866 14827.jpgAlbum 14827
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Towing"
This page has been accessed 16,084 times. This page was last modified 06:10, 28 December 2023. Content is available under Datsun 1200 Club.
