Weber DGV Adapters
From Datsun 1200 Club
Category: Fuel System
<-- back to Weber 32/36 Carburetor
The Weber 32/36 (DGV) carburetor has a larger bolt pattern than the stock Hitachi on a Datsun A-series engine. You can modify the stock manifold, or use an adapter plate.
174_59868ad1eaea0.jpgPost 485784
Comparo: DGV vs Hitachi 306
10870.jpgAlbum 10870
You can make a DGV-compatible intake:
11269.jpgAlbum 11269 5178.jpgAlbum 5178 7236.jpgAlbum 7236 3038.jpgAlbum 3038
But most of us use an adapter plate:
589.JPGAlbum 589 7235.jpgAlbum 7235
Adapters for many models are available for sale, or just #Make Your Own Plate for the Nissan A12 engine out of a block of aluminum:
820.jpgAlbum 820
Custom machined adapter (left for A-series) and kit-provided cast adapter (for L-series)
Be sure to use the Weber-type (thick) gasket under the carburetor. If you use a thin gasket it may tear during operation.
11219.jpgAlbum 11219 11220.jpgAlbum 11220
2976.jpgAlbum 2976 500.jpgAlbum 500 3067.jpgAlbum 3067 5315.jpgAlbum 5315 11270.jpgAlbum 11270
Plate Numbers
A-series adapters
L-series
left, for A-series modded for larger Datsun L-series carburetor (right)
26875.jpgAlbum 26875
Fits all with 80mm x 43mm carb base
Chrysler/Mitsubishi Colt, Galant,Lancer, Sigma
- Citroen CX2200, CX2400
- Daihatsu with 80mm x 43mm carb base
- Datsun 1600, 180B, 200B, 240K, 260C, Bluebird, 510, 610
- Fiat 125 coupe, X-19, 131
- Ford Courier with mazda engine
- Holden Gemini 1600 OHC (Isuzu)
- Isuzu, Bellet, Gemini, Luv
- Mazda 1200, 1300, 808, 323 rear wheel drive model, 1500, 1800,929,
  Capella 121, mazda 1400
- Mitsubishi Express L300, Mitsubishi Colt, Galant,Lancer, Sigma
- Toyota corolla 1100,1200 1300 1966-1984
3K,4K 5K, 1983-1987 corolla/sprinter/seca
Corona, Celica, Crown, Celica 1600 TA22 1971-75
KC112 (Australia) for Nikki/Hitachi 80x43mm pattern
2646.jpgAlbum 2646
Weber 99004.300 uses special dual-diameter studs to go from the 43mm Hitachi spacing to 46mm Weber
99004_300.thumb.jpg.a49eeef94732075745ab226f8bc5ecfc.jpg 99004.300_dimensions.thumb.jpg.74239ab8e7ab21aa02aadc33049c8e23.jpg
Suppliers
Most local auto parts store can custom-order this part for you.
Or buy mail order
http://redlineweber.com
Pierce Manifolds $45 USD
Make Your Own Plate
Weber bolt-pattern: 93x46mm
5450.jpgAlbum 5450
A-series manifold bolt-pattern: 61x37mm
174_59868adec9885.jpgPost 485784
  1. Dimensions: 1 x 2.75 x 5 inches (minimum would be approximately 10 x 6.7 x 11.4 mm)
  2. Using a Nissan gasket as a template on one side, and the Weber gasket on the other, mark the holes.
  3. Drill two bores ~30mm and 27mm to match the intake manifold. You might have a machine shop do this; I had access to a lathe with a large bit chuck into it.
  4. Drill and Countersink holes for stock Nissan pattern using a drill press to get them straight.
  5. Thread holes for Weber pattern
  6. Use a round rasp file to smooth out the transition from the small Nissan bore holes to the larger Weber holes you drew from the template
Custom machined adapter (left, for A-series) and kit-provided cast adapter (L-series)
820.jpgAlbum 820
Angle
Angle adapters for bolting DGB to SU-type manifolds
11589.jpgAlbum 11589 11590.jpgAlbum 11590 11591.jpgAlbum 11591 11596.jpgAlbum 11596
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Weber_DGV_Adapters"
This page has been accessed 25,617 times. This page was last modified 19:41, 20 April 2025. Content is available under Datsun 1200 Club.
