Carburetor Specifications
From Datsun 1200 Club
Hitachi DCx carburetors have different specifications depending on market, year, state and other factors. All A-series engines used Hitachi DCx-306 carburetors 26/30 bores, except for the A10 engine which used a smaller DCG-286 model with 26/28 bores. A12 carburetors have 20/26 primary/secondary venturis, and other engines used bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
DCG - manual choke
DCH - electric automatic choke from 1972 USA
DCx-306: 26/30 Datsun B110
DCx-286: 26/28 Datsun B10
DCx-340: Datsun 510/620
Also See: Carburetor Repair, Instruction Sheet section
Hitachi DCH306 ID boss
5919.jpgAlbum 5919 4968.jpgAlbum 4968
Flange
Hitachi DCG306/DCH306 flange - 61x37mm bolt pattern
174_59868adec9885.jpgPost 485784
Venturis
Venturi (choke) size for B110 is 20 and 26 mm. Smaller than the bore size. The A12 carburetor has small venturis to match the small 1.2 liter engine
choke size MM
A12 20 26
A14 22 27
    20 27 (China clone)
A15 21 27 (AUS B310)
    23 27 (USA B310)
20/27 is OK for an A12, but small for an A14
30462.jpgAlbum 30462
A14 Hitachi flows more air than a Weber 32/36, but is factory jetted for economy. When jetted for power it will out-perform the Weber
CHOKE TOTAL AREA
34/34 23/24        415 cm2 + 452 cm2 =  867 cm2
A12 Hitachi 20/26  314 cm2 + 531 cm2 =  845 cm2
A14 Hitachi 22/27  380 cm2 + 573 cm2 =  953 cm2
 V I D E O  Hitachi carburetor comparison (click to view)
Jet Locations
jet locations
13364.jpgAlbum 13364
Main jets are accessible without removing the carburetor
24021.jpgAlbum 24021
You will need to remove the carburetor top to identify the other jets which are installed. This can be done with the carburetor on the engine.
See Carburetor Top Removal
174_4e07f45dbd212.jpgUpload click to view
174_4e07f441e33c5.jpgUpload click to view
If the fuel bowl has dirty fuel like this, remove the main jet plugs (bottom of carb) to drain the fuel and rinse with clean gasoline or ether spray or carb cleaner. For more details, see Multiple Symptoms:Drain the fuel bowl.
North American Models
Carburator Models
Year Engine Hitachi Model
1971 A12 Hitachi DCG306
72-73 A12 Hitachi DCH306
74 A13 Hitachi DCH306
75-76 A14 Hitachi DCH306
Primary Main Jet - North American Models
Year Jet Size
1971 No. 98
1972 No. 97
1973 No. 95
1974 No. 104
1975-76 California No. 104
1975-76 No. 102
1977-78 California Manual Trans. No. 105
1977 No. 104
1978 California Manual Trans. No. 105
1978 No. 104
1978 Federal 5-speed No. 107
Main Air Bleed
71-73No. 80
74No. 65
75-77No. 95
1978 All CaliforniaNo. 95
1978 Four-speedNo. 110
1978 Five-speedNo. 65
1978 AutomaticNo. 95
Secondary Main Jet
Year Jet Size
1971 No. 135
1972-73 No. 140
1974 No. 145
1975 No. 150
1976 No. 145
1977-78 No. 145
Secondary Air Bleed
Year Jet Size
71-78 No. 80
1977 California 5-speed No. 60
Primary Slow Jet
Year Jet Size
1971-74 No. 43
1975-78 No. 45
1978 non-California 5-speed No. 46
Secondary Slow Jet
Year Hitachi Model
71-76 No. 50
1980
FED 106 original 108 countermeasure [non-GFU]
CAL 107 original 109 countermeasure
Australia Model Specifications
Hitachi DCG-306 (G indicated manual choke)
NOTE: B310 A15 uses DCF-306, which differs from DCG as follows:
* vacuum secondaries, instead of counterweighted secondaries
* replaceable sight glass with O-ring
* modified choke fast idle system
Datsun B310
source: Gregory's
Controls
 Idle Cut Off Solenoid (anti-diesel valve)
 Servo Diaphragm
 Dashpot
Venturi
  primary, A12: 20 mm
  primary, A14: 22 mm
  primary, A15: 21 mm
  secondary, A12: 26 mm
  secondary, A14/A15: 27 mm
Main jet,
 primary, A12: 96
 primary, A14: 104
 primary, A15: 100
 secondary, A12: 150
 secondary, A14: 150
 secondary, A15: 145
Main air bleed
 primary, A12: 80
 primary, A14: 65
 primary, A15: 70
 secondary, A12: 80
 secondary, A14: 60
 secondary, A15: 80
Slow Jet
 primary, A12: 43
 primary, A14: 46
 primary, A15: 43
 secondary, A12: 50
 secondary, A14: 50
 secondary, A15: 70
Slow air bleed
 primary, A12: 220
 primary, A14: 170
 primary, A15: 100
 secondary, A12: 100
 secondary, A14: 100
 secondary, A15: 100
Power jet
 A12: 60
 A14: 60
 A15: 40
Japan Market Specfications
B110
16010-H1000 DCG306-1
16010-H1001 DCG306-1A (from '70-Sept.)
16010-H1002 DCG306-1B (from '70-Nov.)
16010-H1003 DCG306-1C (from '71-Jul.)
16010-H1004 DCG306-1D (from '71-Sept.)
Controls
* manual choke (DCG)
* idle adjust CAP (from '70-Sept.)
Main jet,
 primary, A12: 98
 primary, A12: 97 (from '71-Jul.)
 secondary, A12: 135
Main air bleed
 primary, A12: 80
 secondary, A12: 80
Slow Jet
 primary, A12: 43
 secondary, A12: 50
Slow air bleed
 primary, A12: 220
 secondary, A12: 100
Power jet (Power Valve)
 A12: 60
B120
16010-H7802 -7803
16010-G1660 7804-7907
16010-G1615 7908-8109
16010-G2600 8110-8503
16010-G1900 8504-8910
16010-95W00 8910-
16010-H5001 DCG306-2
16010-H5003 DCG306-2A (from '73-8) with anti-diesel valve
            DCG306-5D with Anti-diesel valve
16010-H7802 A12S.V 7510-
16010-H7860 A14S.V
16010-H8200 A12.S,K
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Carburetor_Specifications"
This page has been accessed 100,818 times. This page was last modified 07:35, 21 August 2025. Content is available under Datsun 1200 Club.
