Fenders
From Datsun 1200 Club
Categories: Body | Fibreglass
Mudguards (guards) are called fenders by Nissan. The stock steel fenders are thin and light. A nice compromise. All 1200 fenders fit coupe, sedan, van/wagon and pickup/ute to March 1978. Fenders for USA differ by having larger side light holes.
Aside from the size of the side lamp hole, all fenders interchange.
North America fenders have larger holes for larger side lamps, to meet FMVSS 108 Lighting Standard of 1970
3636.jpgAlbum 3636 20844.jpgAlbum 20844
Fenders (Guards/Wings) in rest of world
15977.jpgAlbum 15977 26130.jpgAlbum 26130 6104.jpgAlbum 6104 3245.jpgAlbum 3245 12528.jpgAlbum 12528 19751.jpgAlbum 19751 12063.jpgAlbum 12063 13594.jpgAlbum 13594
Care
Foremost, take care when working on the engine. Leaning into the fender will cause a dent.
5646.jpgAlbum 5646
The fenders tend to rust in two spots: Front lower corner and bottom rear. So wash these spots of dirt, grass and other matter occasionally.
1412.jpgAlbum 1412 11148.jpgAlbum 11148 8293.jpgAlbum 8293
If rolling the fender lip, you might consider sealing the crease:
7132.jpgAlbum 7132 6104.jpgAlbum 6104
Removal and Installation
Bolts: There are ten (10) bolts per fender: 2 at front (behind grille), 4 along top edge (visible with hood open), and 2 at the back edge (visible with door open). Also two bolting the apron to the fender. Total of 20 per car, 10 per side.
Open the front doors to gain access to the two bolts on the rear edge of each fender.
Black: 01111-00022 BOLT-HEX WITH WASHER (fixing fender) (16)
Red: 77720-89908 SCREW-with plain washer -8007 (4)
     63140-78500 NUT -8007 (4)
Also replace the two sealing foam strips:
63810-H1001 SEALER-COWL TOP (L=250MM)
63811-H1000 SEALER-FRONT FENDER
See main article: Front Body Panel Part Numbers
Front Fender Panel and associated parts.
JDM
63100-H1003 ASS'Y-FENDER, front (R.H.)
63101-H1003 ASS'Y-FENDER, front (L.H.)
77720-89908 SCREW-FENDER 7510-8503 (16)
63810-H1001 SEALER-cowl top [fender] (L=250mm)
63811-H1000 SEALER-front fender [vertical strip]
63100-H1900 ASSY-FENDER,FRONT,RH USA
63101-H1900 ASSY-FENDER,FRONT,LH USA
01111-00022 BOLT-HEX WITH WASHER FENDER FIX (16)
08915-43610 WASHER-PLAIN FENDER FIX (16)
JDM Late Truck
63100-G1030 FENDER-FRONT, RH 7804-8012
63100-G1230 FENDER-FRONT, RH 8101-8408
63100-G1231 FENDER-FRONT, RH 8408-8910
63100-G1060 FENDER-FRONT, RH 8910-
63101-G1030 FENDER-FRONT, LH 7804-8012
63101-G1230 FENDER-FRONT, LH 8101-8408
63101-G1231 FENDER-FRONT, LH 8408-8910
63101-G1060 FENDER-FRONT, LH 8910-
01436-00093 SCREW-FENDER 8910- (16)
63810-G1000 SEALING RUBBER-FENDER [top] 7510-8105
63810-G1900 SEALING RUBBER-FENDER [top] 8106-
Fibreglas
The Datsun Competition fibreglass fenders were reportedly heavier than the stock steel fenders. Advantage is that they can be more easily repaired after each race.
There have been some thin aftermarkets, too thin for street usage really, but light.
See Body panels
Suppliers
  • Nissan Australia
  • Nissan Japan
  • Nissan Europe
  • NOT Nissan USA
  • Ocassionally for sale on eBay
  • Showcar BodyParts -- fibreglas and steel
  • ProdBodies formerly Japco - fibreglas hood, fenders, flares, door, trunk, spoiler, air dam
AG Parts REPLACEMENT PART FENDER FOR (DS101-01 XY-R) RH
31250.jpgAlbum 31250
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Fenders"
This page has been accessed 23,379 times. This page was last modified 04:41, 19 November 2025. Content is available under Datsun 1200 Club.
