Rear Brakes
From Datsun 1200 Club
Category: Brake System
<-- back to Brakes
Rear brakes are traditional twin-shoe type, with manual adjusters of the wedge-and-tappet kind.
The same rear brake drum was used 1967-1994. It is an 8" diameter cast iron drum, that fits 1-3/8 wide brake shoes.
Starting from Oct 1989, Sunny Trucks started using a different brake shoe — while still using the same drum as early 1200s. These late model 1200s use a self-adjusting rear brake system. Aside from the drum, all the parts differ from earlier rear brakes.
Maintenance
Don't let this happen to you!
16075.jpgAlbum 16075
Installation
B110 rear brake parts
6726.jpgAlbum 6726 25049.jpgAlbum 25049
Order of Wheel Cylinder shims:
25050.jpgAlbum 25050 25051.jpgAlbum 25051
21648.jpgAlbum 21648 21649.jpgAlbum 21649 21650.jpgAlbum 21650 21651.jpgAlbum 21651 21652.jpgAlbum 21652 21653.jpgAlbum 21653 21654.jpgAlbum 21654 21655.jpgAlbum 21655
Specs
  • Linings (shoes)
    • 35 x 4.8 x 195 mm (width x height x thickness)
    • 1.378 x 0.189 x 7.68 inch (W x H x T)
    • 1-3/8 x ~3/16 x ~7-11/16 inch (W x H x T)
  • Total breaking area: 273 cm² (42.3 sq. in.)
  • B110: (manual adjusting)
    • Cylinder: 11/16" with front discs
    • Cylinder: 13/16" with front drums
  • B310: Drum LT-20 (auto adjusting)
    • Cylinder: 13/16" (20.64 mm)
1978-1989 B120 ute used rear type Drum-LT20 with front type Drum2L20.
Finned Alloy Brake Drums
Works Racing
Finned drums like these were offered by Datsun Competition in Japan.
6262.jpgAlbum 6262
quote
Datsun Competition Dept supplied it's favoured teams with many experimental parts that were never sold over the counter. 1200s had alloy drums and calipers fitted as wellas the alloy diff heads from the wagons.
Isuzu Bellett
1969-1971 Isuzu Bellet 1600 GT (model G161) featured ALFIN rear brake drums.
1692.jpgAlbum 1692 16780.jpgAlbum 16780
* 3 outer holes on face
* keyhole-shaped slot for adjusting brakes on face
* 8" diameter
* marked "Izumi Al-Fin"
* about POST 2.22 kg each
  25517.jpgAlbum 25517
Datsun Z-car
Larger 9" alloy drum are used on all S30 models (1971-1978 Fairlady/240Z/260Z/280Z). All 1200 brakes are 8", so the backing plate with brake shoes needs to be switched.
Type E41: MAX. DIA. 2300MM. 9.055"
30675.jpgAlbum 30675 30676.jpgAlbum 30676
POST h165 drum brake set up
9665_54952dcd684af.jpgPost 461948
NOTE: Photos shows ex-race brakes so have extra holes drilled
  • Fit under 13" wheels (as with original 240Z/260Z)
  • The fins look like structural type, not cooling type.
  • There are cast iron inserts where the brake shoes touch.
  • The rest is aluminum
25519.jpgAlbum 25519
* round slot for adjusting brakes on face
* 230 mm (9") diameter
  25521.jpgAlbum 25521
Nissan 43206-E4100 DRUM-BRAKE REAR
* approximately 6.45 lbs.
  25520.jpgAlbum 25520
Cast Iron version
* approximately 12.5 lbs
* Centric 123.42002 Standard Finish
* Centric 122.42002 Premium Finish
specifications:
25516.jpgAlbum 25516
RockAuto.com
Fitted Sunny Truck H165
Datsun Roadster
1968-1970 Datsun roadster 1600/2000 used a finned alloy brake drum similar to the 240Z unit. 1965-1967 used cast iron version.
Nissan 43206-25500
* 9" diameter
* lug holes for 7/16" studs (240Z uses metric studs)
* center hole 70mm? (240Z is 68mm)
* no brake adjuster hole (which 240Z requires)
* squared-off fins (240Z fins are tapering)
* height is about .090" different vs 240Z drums
Roadster axles do not have a centering flange, so the size of the lug holes is critical for correct drum centering. The 240Z drums have slightly larger holes and so will not center positively on roadster axles. An adapter can be fabricated for use in fitting 240Z drums on a roadster, which will also correct the drum height. It is close enough that some have used no adapter with varying success.
Roadster drums lack the adjuster hole which 240Z drums have
174_576610234a9f0.jpgPost 479341
Weight
* B110 iron drums: 8 lbs
* 240Z iron drums: 12.5 lbs
* 240Z alloy drum: 6.45 lbs
* Roadster alloy:  7.9 lbs
* Bellet alloys:   8.9 lbs
Rear Brake Shoe
30674.jpgAlbum 30674
set (8 x 1-3/8, fits B110, B210 and B310)
  • RAYBESTOS 371PG $15.36
  • WAGNER PAB371 $16.52
  • ACDELCO 17371B $19.02
  • WAGNER BD60368 $39.89
6726.jpgAlbum 6726
Rear Drum Brake
  • 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
  • 44060-G0325 7612-8910
  • 43206-18000 DRUM BRAKE-REAR
  • 44060-G1225 8910-
1989 October and newer Sunny Truck feature auto-adjust rear brakes:
19112.jpgAlbum 19112 24998.jpgAlbum 24998 24999.jpgAlbum 24999
Adjusters
44200-18000 B110 adjusters (manual, square adjustment nut)
24997.jpgAlbum 24997 21654.jpgAlbum 21654 21655.jpgAlbum 21655
44200-18000 ASSY-ADJUSTER REAR BRAKE
44204-18000 WEDGE-adjustor
44205-18000 TAPPET-adjustor
27292.jpgAlbum 27292
1200 late star aduster (self-adjusting with star wheel)
44200-W5211 ADJUSTER ASSY-REAR BRAKE, RH
44201-W5211 ADJUSTER ASSY-REAR BRAKE, LH
Same as B310 A14/A15 type
Others
B310 small H83 (automatic with star wheel, A12-powered models)
44200-H8300 ADJUST. ASS'Y RH
44201-H8300 ADJUST. ASS'Y LH
B310 A14/A15 adjuster assembly (automatic with star wheel)
44200-W5211 ADJUSTER ASSY-REAR BRAKES,RH
44201-W5211 ADJUSTER ASSY-REAR BRAKES,LH
* superseded 44200-W5210/44200-W5210
24996.jpgAlbum 24996
B310 star adjuster SCREW (A14/A15 models)
44202-W5210 SCREW RH
44203-W5210 SCREW LH
To 7302
13/16" diameter
* 44100-18000 ASS'Y-CYLINDER-rear wheel (13/16") B10, B110 to 7302
* Fits early B110 with front drum brakes
RockAuto $13
11/16" diameter
* 44100-H0500 CYLINDER ASS'Y-rear wheel (11/16")
* Fits early B110 with front disc brakes
RockAuto $30
From 7303
44100-H3100 CYLINDER ASS'Y-rear wheel (13/16")
* for late B110 with front drum brakes
44100-H3300 CYLINDER ASS'Y-rear wheel (11/16")
* for late B110 with front disc brakes
Nissan Competition
Nismo Catalog
for race, rally
41060-H1020 Ass'y pad Front Brake DS11
41060-H1021 Ass'y pad Front Brake M59
44060-27720 Ass'y-Shoe Rear Fore (B10 op.)
44070-27720 Ass'y-Shoe Rear After AM4 (B10 op.)
44100-H2320 CYL ASSY RR Wheel 5/8"
44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4
44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4
44100-M7000 CYL ASSY-Wheel 5/8" LT20 Selective Use, N10 standard
44100-M4901 CYL ASSY-Wheel 11/16" LT20 Selective Use
44100-G2800 CYL ASSY-Wheel 1/4" LT20 Selective Use
44100-U9200 CYL ASSY-Wheel 13/16" LT20 Selective Use
1984 Nissan Competition
99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET
44060-27720 BRAKE SHOE/FORE for 1200 and early B210
44070-27720 BRAKE SHOE AFT for 1200 and early B210
44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210
44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210
44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
27720 Race-only rear brake shoes
30673.jpgAlbum 30673 30672.jpgAlbum 30672
30671.jpgAlbum 30671
レース専用部品
注意 この部品を装着して公道上を走行するごさは出まません
日産自動車 スポーツ相談室
Race-only Parts
Caution: This part is not suitable for use on public roads.
Nissan Motor Sports Consultation Center
Rear Disc Brakes
For customizing the rear suspension, see Rear Disc Brakes
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Rear_Brakes"
This page has been accessed 46,909 times. This page was last modified 07:50, 27 September 2025. Content is available under Datsun 1200 Club.
