NIS2000 wrote:
Hey, good find Dodgeman, I've been trying to find a source for these for some time without success. Do you mind weighing one cause I'd be keen to know how much weight they save over cast iron drums.
Well, as can be seen, these babies showed up yesterday & are better than I had expected.
I don't have an accurate scale, so the bathroom one had to do. I weighed both together to try & get a better reading so some simple math will get an average 'per unit' weight.
OK, the bathroom scale says that the PAIR of drums comes in at under 10Lbs [about 4.45Kg] They sure don't feel like an iron drum when I pick them up.
I suspect that they will get either washed with high pressure water blasting like my alloy oil pan, or bead blasted & painted black with polished fin tops.
Note what appears to be a makers name on this one. "IZUMI AL-FIN" Both are the same.
