Hitachi D4R Distributor
(Redirected from D4R)
Categories: Distributor | Engine Electrical System | Ignition Modifications
The Hitachi D4R electronic distributors are used by the early E-series engines. These can these be modified to work in A-series engines. See E15 Electronic Distributor Swap for details.
These have an inboard transistor ignition unit, compared to earlier 1978-1982 A-series USA distributors with the outboard "matchbox" ignition.
Interior High-Energy Ignition Unit
 mpi/2-7008-1.jpg
4534.jpgAlbum 4534
Compare to older Exterior Matchbox (Hitachi D4K)
19607.jpgAlbum 19607
Also see: E-Series Distributor
Hitachi D4R series Electronic Ignition distributors are used by E-series Datsun/Nissan, such as the E15 Pulsar. This can be modified for use in a Datsun 1200. It has a much-improved advance bearing plate, which was the bane of the 1974-1982 D4A points distributor, as well D4F and D4K EI distributors. This new D4R type uses a screw-on cap and improved rotor.
E-series shares basic distributor features with A/J/E/L distributor (shaft diameter & length) but uses an L-series style tang drive instead of A-series gear drive. The hold-downs vary, otherwise the cast body is the same.
One-piece Ignitor & Pickup
4534.jpgAlbum 4534
Hitachi D4R type dizzy e.g. from N12 Pulsar
23263.jpgAlbum 23263
* Hitachi E12-61
* Nissan 22020-15M00, 22020-15M20
* NOTE: Hitachi D4N module looks similar
  but has more than two connectors
* BWD CBE507 $110 O'Reilly Auto
* SMP LX515
** Nissan 22020-15M00
** Honda 30120-PA0661, 30120-PH4005
* 12336248
* 30120PA0661
* 30120PH4005
* 491467401
* 8942433440
* 94243344
* E1922
Stator has only two poles (compared to the previous "teethed" stator with 4 poles) but the magnet appears to be stronger.
22163-15W00 STATOR
22136-D4700 PLATE ASSY-BREAKER
22162-15M01 CAP ASSY-DISTRIBUTOR
* 22162-15M02, 22162-15M03, 22162-15M04
22157-H9560 ROTOR-HEAD
Variations
3952.jpgAlbum click to view
4194.jpgAlbum 4194
D4R air gaps
174_5785b1cb85a89.jpgUpload click to view
D4R80
N10 E15S USA, N12 E16S USA, B11 E15S+E16S
22163-15M00 STATOR [Sheet metal type]
22115-15M00 SIGNAL ROTO ASSY [Reluctor]
22136-21M00, 22136-D4700 PLATE ASSY-BREAKER
22159-15M00 HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00 SHAFT ASSY [weight & spring shaft]
22020-15M00,22020-15M20 TRANSISTOR IGNITION UNIT
22109-W0560 WEIGHT-GOVERNOR 79-83 Z/E/CA/A Engine
22132-21M00 CAM SET
D4R82
Appears to be very similar to D4R80.
0882-0588 B11 E15S+E16S USA, 0285-0986 N12 E16S USA
0882-0986 N12 USA
DISTRIBUTOR ASSY
* 22100-32M01,22100-32M01 HITACHI D4R82-24
* 22100-32M03,22100-32M04 HITACHI D4R82-24 W/VENT
* 22100-33M01,22100-33M02 HITACHI D4R82-12
* 22100-33M03,22100-33M04 HITACHI D4R82-12 W/VENT
* 22100-34M01,22100-34M02 HITACHI D4R82-13
* 22100-34M03,22100-34M04 HITACHI D4R82-13 W/VENT
22162-15M02 CAP ASSY-DISTRIBUTOR
22162-15M03 CAP ASSY-DISTRIBUTOR
22162-15M04 CAP ASSY-DISTRIBUTOR
22162-52A01 CAP ASSY-DISTRIBUTOR
22157-03A00 ROTOR-HEAD
22136-D4700 PLATE ASSY-BREAKER [22173]
* 22159-11M00,22159-11M03,22159-11M05,22159-15M00
* HARNESS ASSY-DISTRIBUTOR [Wiring]
22108-15M00, 22108-11M03 SHAFT ASSY [weight & spring shaft]
22132-33M00 CAM SET
22132-33M03 CAM SET
22132-34M00 CAM SET
D4R83
D4R83 is a great Hitachi distributor, used on 1980s Nissans and Hondas. The austin boys swap them into A-series engines too.
D4R83-39
4534.jpgAlbum 4534
20213.jpgAlbum 20213 D4R83-36 shaft with no collar
20215.jpgAlbum 20215 D4R83-30 shaft with collar
20215.jpgAlbum thumbs/20215 D4R83-30 Shaft
20213.jpgAlbum thumbs/20213 D4R83-36 Shaft
20212.jpgAlbum thumbs/20212 D4R83-36 Unit
22100-P4000 D4R83-39 5505
18020.jpgAlbum 18020 18021.jpgAlbum 18021 18022.jpgAlbum 18022
22100-P4000 D4R83-39 4702
4532.jpgAlbum 4532 4533.jpgAlbum 4533 4534.jpgAlbum 4534 4535.jpgAlbum 4535 4536.jpgAlbum 4536 4537.jpgAlbum 4537 4538.jpgAlbum 4538 4604.jpgAlbum 4604 4605.jpgAlbum 4605 4606.jpgAlbum 4606 4607.jpgAlbum 4607 4608.jpgAlbum 4608 4609.jpgAlbum 4609
For Hitachi D4R Distributor
** Master Pro 2-4870A
** BWD C708
** Beck/Arnley 174-6861
** ACDelco E303E
CAP & ROTOR KIT
* Bosch 06089
Fits these USA models
** 1982 Datsun 310 (N10) E15
** 1983 Datsun Pulsar (N12) E16
** 1983-1986 Datsun Pulsar NX (KN13) E16
** 1982-1986 Datsun Sentra (B11) E15S,E16
** 1983-1984 Subaru Brat 1800,1800 Turbo
** Master Pro 2-3774
** BWD D575
** BWD D680 "Nascar"
Fits:
* 1976 Accord
* 1975-1975 Civic
* Many Datsun. See B-210_Electronic_Distributor_Swap#Rotor
22132-21M00 CAM SET
D4P
See Hitachi D4P Distributor
Source Vehicles
  • Chevrolet S10/Blazer 1982-1985 1.9/2.0
  • GMC S15/Jimmy 1982-1985 1.9/2.0
  • Honda 1980-1990
  • Isuzu 1986-1995
  • Nissan 1983-1987 E-series, CA16DE
  • Subaru 1981-1989
  • 22100-24B01 JDM Nissan March K10 with MA10S.AT (PK10) 8901-
    • Looks similar to E-series dizzy and engine. PLASMA is 1.0 liter range
Subaru uses same part code as Nissan (22100 for distributor) as stamped on the distributor body.
12841.jpgAlbum 12841
Isuzu D4R uses a different case hold-down
Australia
This looks like D4R electronic distributor, which was found in Australia:
12841.jpgAlbum 12841 12842.jpgAlbum 12842 12843.jpgAlbum 12843
This has the one-piece ignitor & pickup (ignitor part number Nissan 22020-15M00/22020-15M20)
Advance Bearing Plate
It has a simplified design compared to the earlier D4 distributors. The plastic bearing race contains 4 ball-bearings (up from 3) and slightly beefier design.
The bottom race is similar to the older Hitachi, but slightly smaller.
20120530224458DSC01938.jpg 20120530224507DSC01939.jpg 20120530224516DSC01940.jpg 20120530224516DSC01940.jpg 20120530224528DSC01941.jpg
20120530224118DSC01933.jpg 20120530224126DSC01934.jpg 20120530224155DSC01936.jpg
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Hitachi_D4R_Distributor"
This page has been accessed 26,585 times. This page was last modified 03:40, 24 September 2017. Content is available under Datsun 1200 Club.
