Search results
For query "1.Anti-diesel_valve"
There is no page titled ":1.Anti-diesel_valve". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Anti-diesel valve (4205 bytes)
    3: ...ove the idle range &mdash; if the engine is above 1500 RPM it will still keep running.</blockquote>
    6: Anti-Diesel solenoid valve comes on some 1973 and newer carbs.
    8: 1973 JAPAN Datsun B210
    9: 1973 USA Datsun 1200
    10: 1981 AUS Datsun 1200
  2. Anti-sway bar (9448 bytes)
    11: ...ch stiffer bar works well and doesn't overpower a 1200.
    15: ...459163}} {{UploadPostH|12526_53f7d8a6c7d65.jpg|459163|300}}
    18: '''B210 Sway Bar Upgrade'''
    20: Bolt a B210 (1974-1978 Sunny) swaybar on. For around $20 and an hour ...
    25: {{SeeMainArticle!|B210 Sway Bar Upgrade}}
  3. Anti-Tramp (2963 bytes)
    18: ...nsion_Manual#Rear_Suspension_Modifications|Datsun 1200 Competition Suspension Manual}}
    20: {{Album!|15793}} {{Album!|27694}}
    24: ...m|10862}} {{Album|10863}} {{Album|10864}} {{Album|10865}}
    29: ...Post|1333_56ea4a5f99847.jpg|477320}} {{UploadPost|1333_56ea4a8c33a87.jpg|477320}}
    33: <br>{{Photo!|SlapperBars.jpg}} {{Album|2831}}
Page text matches
  1. QR25DE Engine (6399 bytes)
    2: ... into a Datsun 510, so you know it will work in a 1200 too.
    5: ...ies into a 1200? They've been on the market since 1999 ...
    7: ...[[wikipedia:Nissan_QR_engine#QR25DE|QR25DE]] (152-165 hp)
    8: 177 hp Australia [[wikipedia:Nissan_X-Trail#Engines...
    9: ...issan_Sentra#SE-R/SE-R_Spec_V_(2007–2012)|2007-2012 QR25DE Spec V]]
  2. Carburetor Overview (3188 bytes)
    3: ...mm (Secondary). However, the [[Body Styles|Datsun 1200 GX models]] used twin Hitachi 38 sidedraft car...
    15: * [[#DCG286]] 1967-1970 Datsun B10
    16: * [[#DCG306]] 1970-1975 Datsun B110
    17: 1973-1980 Datsun B210
    18: 1977-1983 Datsun B310
  3. Carburettor Diagnosis (3654 bytes)
    31: * Anti-diesel valve not working (1973 and newer carburetors)
    40: The Anti-diesel Valve started with 1973 models and is also known as the '''idle cutoff...
    43: <br>{{Album|1006}}
    63: #: {{Album|9815}}
    72: The A12 engine is very smooth and quiet. High idling is ...
  4. Ignition Timing (9164 bytes)
    8: The stock Datsun 1200 distributor orientation &mdash; vacuum advance...
    14: ...t them back in. Spec is 0.028-0.032 inch for the A12. Use 0.035" for the smoothest idle. Re-gap if ne...
    29: point gap (new points): 0.018-0.021 in (0.45 - 0.55 mm)
    31: Spark plug gap: 0.31-0.35 in (0.8 - 0.9 mm)
    35: == Late 1200 Electronic Ignition ==
  5. Fuel pump pressure test (3334 bytes)
    13: ...h engine running should be '''2.6 psi''' for the A12 engine. For other Datsuns between 3.0 and 3.8 is...
    20: ...t $25 at [http://www.sears.com/shc/s/search_10153_12605?vName=Tools&cName=Auto+%26+Mechanics+Tools&vi...
    29: # Start engine and run at 1,000 rpm for one minute (use a stopwatch)
    37: .... The engine won't start until the bowl is about 1/2 full.
  6. Emission Controls (28449 bytes)
    1: ...mance, including some of those used by the Datsun 1200.
    4: ...ers to three types of emission controls for the B110 model series:
    5: * CRANK: Signifies all B110 with crankcase emission control device [PCV, etc...
    6: * EXHAUST: Signifies B110 with crankcase emission control and exhaust emis...
    7: * EVAPO: Signifies B110 with crankcase emission control, exhaust emissio...
  7. Carburetor Specifications (5963 bytes)
    3: ...sed bigger venturis up to A15s which have bigger 21/27 or 23/27 venturis.
    7: DCH - electric automatic choke from 1972 USA
    9: DCx-306: 26/30 Datsun B110
    10: DCx-286: 26/28 Datsun B10
    11: DCx-340: Datsun 510/620
  8. Steering wheel (9931 bytes)
    1: ...(overall diameter 15.75"/40cm). They have a 5/8" (16mm) thick rim section.
    3: {{AlbumH!|21325}} {{AlbumH!|30602}} {{AlbumH!|21781}}
    12: = B110 =
    14: ...bumLinkH|Facelift_Coupe#Back_Cover|27308|brochure|168}}
    16: ...d on Standard and Deluxe trims. Also used by 1971-1978 Truck.
  9. Weber 32/36 Carburetor (22613 bytes)
    8: {{Album|15241}}
    10: [{{Post|50418}} Did you notice a performance increase?]
    13: * designed for engines displacing 1200cc-2300cc
    24: ...427213}} {{UploadPost|13419_50f10d84b15b3.jpg|427213}}
    32: x can be either: 1) none - manual choke 2) E - electric choke or 3) ...
  10. Fuel Injection (19606 bytes)
    1: Your Datsun 1200 can be converted to fuel injection. Benefits c...
    4: ...cars have used injection since at least the early 1960s. Electronic fuel injection (EFI) has made it ...
    8: {{Album|1048}} {{Album|14626}}
    10: {{Album|1713}}
    12: = A12 EFI =
  11. Wiring (8463 bytes)
    1: Datsun 1200 wiring is relatively uncomplicated.
    6: ...ry. Please double-check the wiring in your Datsun 1200 before connecting parts according to this arti...
    35: <br>{{Album|21177}}
    40: ...|r41847922darumasan0124-img600x450-1.jpg|Datsun%201200/Parts2}}
    49: {{Album!|16498}}
  12. 200SX EFI (13119 bytes)
    1: ...m the S110, and an A-series EFI manifold from a B310.
    3: ...04.jpg|368}} {{WikiCommons|Nissan_Silvia#110|8/8c|1982_Datsun_200SX_SL_by_Nissan%2C_3-dr%2C_rear_left...
    6: ...in as many of the parts as you can from a donor S110.
    8: You can use either the S110 parts or the B310 parts, or a mixture. Additionally, many of the p...
    18: ...nifold. Same design, but runner flanges suit L16/L18 engine
  13. E15 Electronic Distributor Swap (19123 bytes)
    1: ...from an E-Series engine such as from an [[Pulsar|N12 Pulsar]]. Fit a drive gear from an A series dist...
    3: {{UploadPost|13822_52b7eb4df2d4b.jpg|449414}}
    7: * E15S (single carburetor)
    8: * E15I (Injected, central throttle body injection)
    9: * E16S
  14. Strut (11854 bytes)
    1: Datsun 1200 uses front '''MacPherson strut''' [[Front Susp...
    12: The original 1200 strut is a rebuildable oil filled tube with sh...
    14: {{Album|15173}} {{Album|14291}}
    17: <br>{{Album|14297}}
    20: <br>{{Album|15857}}
  15. Fuel Requirements (12778 bytes)
    1: ... grade of {{wiki|petrol}} (gasoline). Even the [[A12GX Engine|GX]] "low gas" engine runs on regular g...
    4: For a factory stock A12 engine, what does the Owners Manual say?
    5: * 1971 Export Coupe (9.0:1 compression): "gasoline above 90 octane"
    6: ...1972 Export (8.5:1 compression): "gasoline above 91 octane"
    7: * 1973 Export (8.5:1 compression): "minimum octane rating of 87 ... av...
  16. Turbo (10692 bytes)
    4: ...es more power and torque than a worked non-turbo A14, for a fraction of the build cost.
    6: {{Main|$1200 EFI Turbo A12}}
    10: {{Album|21789}}
    12: {{Discussion|9752|regarding Turbocharging A12}}
    19: = Stage 1 =
  17. Anti-diesel valve (4205 bytes)
  18. Facelift (3770 bytes)
    1: ...ld 1970-1972 in Japan, with the B210 debuting for 1973.
    3: {{AlbumLinkH|1972_Blue_GL|28295|brochure|height=}}
    6: ...&#12434;&#22823;&#12365;&#12367;&#22793;&#12360;&#12427;|Changing the radiator grille, which is the f...
    8: ...>&#12469;&#12491;&#12540;1200GL|Facelift<br>Sunny 1200GL}}
    16: 1972 lineup
  19. Tachometer (10680 bytes)
    1: Optional for the Datsun 1200 was an 8,000 RPM Kanto-Seiki tachometer. It wa...
    4: {{OwnersManual2x|29368|p1=08|29369|p2=09|The tachometer is electrically ope...
    7: <br>{{Album|21197}}
    9: [[PB110]]
    10: <br>{{Album|2129}}
  20. Brake Pads (9387 bytes)
    1: Left: B110, Center: B120, Right: JDM B310
    2: ...3438 http://datsun1200.com/modules/myalbum/photos/13438.jpg]
    5: ...10 and HB310 use similar-looking but wider Type D117 63.5 mm pads.
    7: ...12 http://datsun1200.com/modules/myalbum/photos/8912.jpg]
    8: <br>B110 vs HB210/HB310
Search in namespaces :
List redirects   Search for
