There is no page titled ":Coilover". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- MADDAT Ultimate Race Coilover Package (404 bytes)
3: Product No - URCP $1495 Ultimate Race Coilover Package
6: * Adjustable Coilover Kit fitted with 65mm, 250lb King springs
Page text matches
- Tires (15252 bytes)
149: ... coilover springs to racing-style small diameter[[coilovers]] - Brake Swaps (21279 bytes)
9: * Coilover swaps permit wider tires
482: 'universal' type coilovers for a Civic donated the springs - 280ZX Strut Swap (9179 bytes)
20: * Aftermarket coilover springs
124: * Remove the spring perch and use a [[Coilover Springs]] kit. It allows lowering the car more in... - B310 Strut Swap (10100 bytes)
104: ... remove the spring perch and fit small-diameter [[Coilover Springs]]. You can lower the car more by getting ... - Coilovers (10589 bytes)
1: ...nt the leaf springs. One advantage of aftermarket coilovers is that many spring rates are available for cust...
4: Stock Datsun 1200 [[strut]]s are coilovers from the factory, but with fixed, large diameter...
30: * Coilovers do not change the extended length. That is set b...
37: ....88" diameter up to larger-than-Datsun-springs 5" coilover springs. The common aftermarket size used with Da...
50: ...ates for coilovers like you would for any spring. Coilover springs are available in many different rates fro... - Ddgonzal's Sunny Truck (21199 bytes)
152: * Coilover front struts (though doesn't appear to be lowered... - Shortening struts (4949 bytes)
12: ...y choose to re-position the lower spring seat (or coilover adjustable sleeve) in a way that the leaves enoug... - Offset (16590 bytes)
211: ...to gain more clearance. Changing from the factory coilover springs (110 mm diameter) to aftermarket small-di... - Strut swaps (17866 bytes)
43: * aftermarket coilovers
46: = Coilover conversion =
47: ...d), or convert them to aftermarket small-diameter coilover springs. Advantages include:
56: {{Main|Coilovers}}
219: ...my 200b struts to baz at datsport to be shortned, coilovers camber tops - Strut Tops (10411 bytes)
131: ...t threaded sleeves. See [[Coilovers#Coilover_Kits|Coilover Kits]].
254: * as part of a [[Coilovers#Coilover_Kits|Coilover Kit]] - Fastening Spring Seats (4472 bytes)
1: ...h stock spring perches or with thread collars for coilovers.
19: Using stock coilover springs (factory 1200 springs) with adjustable fa...
23: = Coilover Seats =
24: Coilover seats are suitable for the small diameter springs... - Camber (4548 bytes)
58: Small coilover type springs and adjustable strut tops are good f... - Spring Rates (2957 bytes)
1: ...er using stock-diameter springs or small-diameter coilover setups, choose your spring rates for your style o... - Brewskie Ute (18257 bytes)
16: fully adjustable coilover suspension all round - Stanza Strut Swap (15469 bytes)
83: * Remove the spring perch and use a weld-on [[Coilover Springs]] kit. You can lower the car more by gett...
85: Coilovers also give you more room for wider tires, as well... - Maddat (2556 bytes)
23: ...DDAT_Ultimate_Race_Coilover_Package|Ultimate Race Coilover Package]] - MR 12QQ (2463 bytes)
39: 120Y struts shortened with HSD coilover sleeves welded on, externally adjustable KONI sho... - Lancer strut swap (1063 bytes)
13: * Coilover threaded sleeves of 316 stainless with 6061 alloy... - L18 Coupe (3537 bytes)
43: ...mall-diameter springs & camber tops (Otomoto 45mm coilover kit with the 4kg springs) - MADDAT Ultimate Race Coilover Package (404 bytes)
