There is no page titled ":Main". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
No page title matches
Page text matches
- History of Datsun 1200 (17010 bytes)
68: {{Main|Facelift}}
81: ...ere were many different specifications the cars remained relatively unchanged throughout production. Ini...
94: ...s mounted in the front edge of the fenders. Three main specifications were available, GL, GX and Deluxe....
103: {{Main|Australia-assembled}}
111: {{Main|South Africa}} - Movies (20445 bytes)
3: ...ese or other movies by posting a note in the Club Main Forum topic "[{{Post|56741}} Datsuns in movies (h...
95: ...;雪 anime movie {{wiki|Wolf Children}}, the main farming character drives a Sunny truck
98: {{Main|Drawings#Anime}}
237: ... At 120 minutes (scene lasts about 4 minutes) the main character drives past the (12 story?) Nissan Nort...
248: <br>Comments: Light blue 1200 sedan at 8:56 remaining - Magazine Articles (24401 bytes)
109: {{Main|Zoom magazine}} - 5-Speeds (19568 bytes)
160: ...e between the centres of the countershaft and the main shaft. 56 series 56 mm, 60 series 60 mm, 63 serie...
178: See main article: [[Gearbox Weights]]
192: See main article: [[Speedometer Gears]]
197: {{Main|Toyota 5-speed}}
205: {{Main|5-speed Identification}} - Racing History (26063 bytes)
94: {{Main|1972 Grand Prix}}
150: {{Main|1973 Grand Prix}} - Engine Swaps (25981 bytes)
8: {{Main|A-series Engine Swaps}}
20: {{Main|A-series Engine Swaps}}
32: {{Main|A-series Engine Swaps}}
45: {{Main|A-series Engine Swaps}}
113: {{Main|L-series Engine Swap}} - Heater (11024 bytes)
146: {{Main|Heater Part Numbers}} - Strut Insert Part Numbers (10856 bytes)
134: See main article: [[Shortening_struts#Choosing_A_Short_Sho...
261: See main article: [[2-inch Strut Inserts]]
270: * diameter: main housing - 37.6mm (1.48 in) - A12GX Engine (12809 bytes)
40: {{SeeEx|see=Main|A-series_Cylinder_Heads#A12GX_Head|A12GX Head}}
95: {{SeeEx|see=Main|PCV|Block Ventilation}}
102: {{Main|Hitachi Twin Carb}}
130: {{SeeEx|see=Main|Choke_Cable#GX|GX Choke Cable}}
135: {{Main|GX Air Cleaner}} - Rear Axle (11620 bytes)
31: See main article: [[Borg Warner Differential]]
37: See Main Article: [[Diff ID]]
42: See main articles: [[H145]] | [[H165]]
80: See main article: [[Rear_Axle_Swaps#Strength_of_Differenti...
106: = Maintenance = - Rear Axle Swaps (24555 bytes)
115: ... ring gear, good for ~125 lb. ft. of torque). The main spring is 55mm longer, so use the 1200 spring pac...
117: {{SeeEx|see=Main|H150#Using_H150_Rear_Axle_in_B110|Using H150 Rear...
124: {{SeeEx|see=Main|H150#Swap_Into_H145_Housing|Swap H150 Into H145 H...
163: {{Main|Borg Warner Differential}}
298: {{Main|BW78}} - Puerto Rico (4691 bytes)
12: See Main Article: [[Steidel_Racing_Datsun_1200#Visit_To_Au... - Performance (21399 bytes)
254: {{Main|Weight}}
257: {{Main|Fuel_economy}}
262: {{Main|Aerodynamics}} - Carburetor Overview (3188 bytes)
83: See main article: [[DFC306]] - Carburettor Diagnosis (3654 bytes)
55: ... droplet in the fuel bowl, partially blocking the main jet. Solution: drain the fuel bowl.
62: # With engine cold, remove the main jet plugs from the bottom of the carburetor (firs...
64: ...hen it is out, spray with carb cleaner. Screw the main jet back in.
65: # Refasten the main jet plugs and snap the lock strap back over the n...
69: ...an. See [[Carburetor_Specifications#Jet_Locations|Main Jet Removal]]. - Ignition Timing (9164 bytes)
62: ...ast -- or the belt is too loose ([[Fan belt#Minor Maintenance|tighten it]]!)
155: {{Main|Spark Curve}} - Choke Operation and Adjustment (6774 bytes)
102: {{Main|Choke Adjustment}}
111: {{Main|Electric Choke Wiring}} - Emission Controls (28459 bytes)
120: {{Main|Japan Emissions}}
132: {{Main|PCV}}
182: {{Main|TCVAS}}
280: ...throttle operation, not being tested by US law, remained rich.
331: See main article: [[EGR]] - Carburetor Specifications (5963 bytes)
48: Main jets are accessible without removing the carburet...
58: ...he fuel bowl has dirty fuel like this, remove the main jet plugs (bottom of carb) to drain the fuel and ...
76: |+Primary Main Jet - North American Models
104: |+Main Air Bleed
121: |+Secondary Main Jet - Float Level Adjustment (1455 bytes)
35: {{Main|Float repair}}
