Search results
For query "Modifications"
There is no page titled ":Modifications". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
  1. Ignition Modifications Overview (597 bytes)
    2: [[Category:Ignition Modifications]]
  2. Body Modifications Overview (450 bytes)
    19: [[Category:Body Modifications]]
  3. Cylinder Head Modifications (569 bytes)
Page text matches
  1. Datsun 1200 encyclopedia (3415 bytes)
    41: * [[:Category:Engine Modifications|Engine Modifications]]
    42: ...* [[:Category:Suspension Modifications|Suspension Modifications]]
    43: * [[:Category:Brake Modifications|Brake Modifications]]
    44: * [[:Category:Body Modifications|Body Modifications]]
    45: * [[:Category:Ignition Modifications|Ignition Modifications]]
  2. 5-Speeds (19568 bytes)
    46: ...rive 5-speed will bolt up to any A-engine. Slight modifications may be needed to fit into Datsun 1200.
    274: [[Category:Transmission_Modifications]][[Category:Transmission]]{{End}}
  3. QR25DE Engine (6399 bytes)
    1: [[Category:Engine Modifications]] [[Category:Engine Swaps]] [[Category:Nissan Eng...
  4. Engine Swaps (25633 bytes)
    69: ... just like the A14 would need special valve train modifications and for highest RPMs need a scavenging oil pump w...
    193: ...mods, chiefly involving engine setback and tunnel modifications.
    544: [[Category:Engine Modifications]] [[Category:Engine Swaps]]
  5. Strut Insert Part Numbers (10856 bytes)
    107: These will require some modifications to use, including spacers in the bottom of the st...
    320: [[Category:Suspension Modifications]]
  6. Rear Axle Swaps (25587 bytes)
    146: ...ses coil springs so it's not a good choice (needs modifications). It's also 4-link, so you have to do some signif...
    242: ...ars be be swapped in the 1200 with minor or major modifications. Advantages are strength, LSD and gear ratio choi...
    490: ...y:Rear Axle And Rear Suspension]][[Category:Brake_Modifications]][[Category:Propeller Shaft And Differential Carr...
  7. Emission Controls (28391 bytes)
    109: * [[Carburetor]] modifications
  8. Gilmer drive (4896 bytes)
    81: [[Category:Engine Modifications]] [[Category:Engine Mechanical]] [[Category:Force...
  9. 200SX EFI (11723 bytes)
    10: ...00SX parts can be used with some bracket-mounting modifications for the A-series factory EFI manifold. The Z-seri...
  10. Datsun 1200 SSS (14109 bytes)
    18: ...e Development in {{wiki|Papakura}} did the engine modifications.
    27: ...earbox and diff remained unaltered. However these modifications alone were enough to give these little cars a hea...
  11. A-series Cylinder Heads (27332 bytes)
    608: {{See|Cylinder Head Modifications| Raised-Ports}}
  12. Using Newer Distributor (1313 bytes)
    4: ...ible by using the distributor plate with a slight modifications to the bolt-down bracket.
  13. Using Older Distributor (1072 bytes)
    22: [[Category:Ignition Modifications]]
  14. B310 Electronic Distributor Swap (3084 bytes)
  15. B-210 Electronic Distributor Swap (12611 bytes)
    268: [[Category:Ignition Modifications]]{{End}}
  16. CA-Series Engine Swaps (11330 bytes)
    404: [[Category:Engine Modifications]]
  17. Ignition Modifications Overview (597 bytes)
  18. Body Modifications Overview (450 bytes)
  19. Wide gearbox crossmember (2711 bytes)
    57: {{End}}[[Category:Transmission Modifications]]
  20. 56-Series Transmission (22608 bytes)
    150: ...bstance of this section, as it is a near-quote -->Modifications have been made on the following points to strengt...
Search in namespaces :
List redirects   Search for
